Question about Dishwashers
Whirlpool dishwasher ADG 957
I started my dishwasher but we had to cut off the water yesterday (due to another problem). We forgot to stop the dishwasher before we cut off the water so when we restarted the cycle again it wouldnt work. It just keeps beeping and light keeps flashing. Any solutions?
  • Anonymous Mar 30, 2014
    my dishwasher wont start it keeps beeping and lights keep flasing
  • 4,889 Answers
When it sits there bleeping, have a look at the light by the start button, it will be flashing. Count the flashes between pauses and post the result here.
If it appears to be continuous then thats a single flash.
Posted on Feb 11, 2008
  • eagle338
    eagle338 Feb 11, 2008
    Continuous flash with no pause is a Faulty NTC (temperature sensor)
  • 86 Answers
Try opening the door and holding the start button for 5 seconds to perform a reset. Then try to restart it.
Whirlpool ADG 7560 bleeps 4 times
Valued Consumer, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id, phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 15, 2017 | Whirlpool Dishwashers
Why Whirlpool ADG-6558/1 IX stops sometimes the wash cycle after 15/30 min?
reset the panel by hitting normal-- heat dry NOT at the same time until all lights flash then push cancel and it should start. element is going bad
Jun 02, 2014 | Whirlpool Dishwashers
I have a Whirlpool Dishwasher model no. ADG 6340 IX.The inlet valve is pulsing and letting in water on every pulse. It just keeps filling, over fills and trips elcb
Hello there and thank you for choosing fixya
This is a very common problem with these types of machines the water inlet valve has a solinoid for the hot and a solinoid for the cold that opens and closes the water on demand .
When they start to pulsate like this it is trying to close the valve but it cant this is normally due to the valve being clogged with debris or the valve is failing all together and simply needs to be replaced
So what i would do is first if you can look into the inlet valve with a flashlight and see ifit looks like it has stuff in it and if so clean it out and try it again if this doesnt work than you can assum that the valve will need to be replaced here is what the one of the valves should look like or close to it .
$50.60 Quantity:
In Stock
Jun 05, 2011 | Whirlpool 24 in. ADG6340iX Built-in...
Hi. I have a problem with my dishwasher ADG 6556.
If this model has the normal wash, and heated dry buttons there is a sequence of buttons to press to do the reset, which buttons do you have, reading from left, to right on the touch panel.
Dec 29, 2010 | Whirlpool Dishwashers
Whirlpool ADG 6556 flashing code
Refer user guide for the correct meaning!
Meanwhile Check all the dispensing compartments- salt - rinse-aid, free inlet water flow and the door close.
May 20, 2010 | Whirlpool 24 in. ADG6552 Built-in...
Whirlpool dishwasher stuck on prewash cycle
the eprom memory is brocken,the main board must be changed.
Feb 14, 2010 | Whirlpool 24 in. ADG7952 Built-in...
Whirlpool ADG 957 Dishwasher not draining water?
There is a remote possibility that the drain line is clogged. Most units should have an aerator on the top of the sink area HOWEVER some are hooked up directly into the garbage disposal and it's at that point where the line can be clogged. Remove the clamp and make sure the line is clear or the hole in the disposal is clear.
Nov 09, 2017 | Dishwashers
Whirlpool dishwasher ADG 957. The manual says " Open the door and turn on the water tap". Where is the water tap and what does it look like?
They mean to turn on your water faucet at the kitchen sink and let the water get hot before starting the dishwasher cycle this insures you start the wash with hot water.
Aug 22, 2009 | Whirlpool Dishwashers
Whirlpool ADG 957. Light for rinse programme on but start light flashing intermittently. Cannot change programme, cannot start machine.
Mine was doing exactly the same. I turned off power, held down the 2 black buttons on right, switched back on and the start button flashes intermittently. It then allowed me to change programs, just testing it now!! It started, this was more then it was doing!! lol
Aug 17, 2008 | Dishwashers
Dishwashers Logo
665 people viewed this question
Top Dishwashers Experts
