Colour problems the colour on my Tv is only red and pink Colour problems, first of all everything green, now red. Set approx 3 years old
  • skieasy Feb 12, 2008
    It's a JVC Model AV24WT5EKS Serial 09669257
  • Anonymous Mar 24, 2014
    the tv has lost it's colour. only greenish and white colours
    Sergeant:
  • 395 Answers
Check for open resistor R302 on the CRT board. 150 ohm 1/8 watt SMT resistor, located at the base of Q305
Posted on Feb 12, 2008
  • 48 Answers
What brand and model ?? 3 years old does not mean anything. I've seen brand new TV's with bad CRT's and other problems. Some brands have a bad patch of CRT's I hope yours isn't one of them.
Pink color appearence when swith on tv for 1 minutes & wringles form on the screen
Hello
Pink colour denotes the absence of green colour dispay in your picture tube. I hereby gies an approximate voltages at the three cathodes of your picture tube socket solderings, and you just measure the voltages with reference to this. The voltages are approximate, and can chage up to 2% up or down.
Green Cathode = Pin number 9 [161VDC approx]; Blue Cathode = Pin number 8 [162VDC apprpx]; and Red cathode = Pin number 10 [157VDC approx]
If any of these voltage differes, the clolur related to that cahode will also rise or low, thath is if the cathode voltage goes very low, that clour will be prdominent, and if it goes high, that colour will not be there.
In your TVs case, the green cathode voltage now will be high. t may be due to a soldering loose to either to the picture tube base socket or at the terminals of the related transistor or Ic. It is best to resolder the suspected loose soldering points by applying a little more solder, as we in service field also do. It is very difficult to locate the exact loose soldering point and so I advice you to do so. If needs, replace the colour output transistors, of other devices if used. Just look at the voateg at pin number 9 at the picture tube base card. Resolder all the picture tube base socket pins. If you wants any more calrification, contact me through Fixya. Ok.
Nov 25, 2010 | Sony KV-T29CF1 TV
Hp w2007 why does the computer go pink everything that is green is now black
All the colours on the screen are created by "mixing" the 3 "primary" colours (red, blue, green).
Once the production of "green" ceases, anything that should be "100% green" becomes "100% black",
and every colour that indicates some percentage of "green" becomes a mixture of just RED and BLUE, i.e., various shades of PINK.
First, try the monitor on another computer (desktop or laptop). If the problem persists, it's time to replace the monitor. If the problem vanishes, it's the video-card in your computer that is not generating GREEN, or it is the "data" cable between your monitor and your computer that is not transmitting the GREEN request. So, you can try replacing the data-cable, or try replacing the video-card.
Jul 11, 2010 | Computers & Internet
Red colour appearing on screen
Your tv could have one of several faults. None of which are to be tackled by anyone except a qualified engineer due to the electric shock hazard.the first problem could be the crt (tube) the second could be the componets on crt base circuit board ie resistors or ic.
With a tv 9 years old it may not be economical to carry out a reair.
Jun 01, 2010 | Thomson 21DC320 21" TV
Samsung LE26R7 4BD, approx 4 years old, colour distortions
Check all of your cables on the back of the tv and your sources such as Cable,Sat box and DVD palyer to make sure they are fully inserted into the input and output connectors. Some times Component cables will work loose and you end up with a missing color. Temprature changes can affect intermittant connections. If that does work then you have a bad Main bd.
Jul 02, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Screen gone yellow and green
I have a 21'' NEC TV Screen and it about 3 year old. the colour has gone to yellow and green color and the red etc
May 10, 2009 | Samsung PPM42S3 42 in. Plasma Television
Pink colour everywhere
Assuming all power supplies are OK, you most likely have a bad CRT grid, and that respective (red) tube must be replaced. I'm sorry that it went that way, as this repair is not cheap....accordianman
Sep 12, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Colour problems
Any developments with your Hitachi?
May 18, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Color problem with TV
Are you getting Green or purple or pink patches all over the screen?
This could be a problem of Degaussing. Have you placed any Magnetic source near the TV recently? Some Tape recorder or walkie talkie or a Speaker, etc? The Magnetic field created by any of the above sources can cause coloured patches over a colour TV screen.
It also happens if you shift the TV from one location to another.
The third possibility is that the Picture Tube's Red Output stage gone faulty. Unless you are a trained Solid state Electronics Technician, there is nothing you can do. Better go for a trade in.
Feb 22, 2008 | Panasonic CT-27G21 27" TV
Colour distortion on tv screen
as you say pink& green means red+blue= pink &green means you are getting all color like b+g+r so it requires adjustment only please call skilled person to do it.
Oct 01, 2007 | Televison & Video
Picture problems
CRT green gun is not working properly , maybe dry soldered or no green drive signal. Pink and red colour is due to missing of green colour.
Sep 09, 2007 | Sanyo DS27820 27" TV
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
