Question about Dryers
Hotpoint aquarius ctd40
I have a problem with my dryer it doesn,t heat up anymore.runs ok but no heat is it anything like the temp sender or would it be a pcb.
  • 4,889 Answers
It is definitely a problem with the heating element.. check for open circuits around the filament area. Look for any loose contacts or burnt wires. If none of appear fishy then you may have to get the filament replaced. If you want the spares for your dish washer just in case.. ask me i will get you the link
Posted on Feb 11, 2008
  • eagle338
    eagle338 Feb 11, 2008
    Dont forget to turn off power before you try this. Its a high voltage appliance and there's a serious risk of electric shock.
  • 749 Answers
CHECK FOR OPEN FUSE OR OPEN FILAMENT (HEATING ELEMENT)
CAREFUL IN DOING SO... BE SURE IT IS UNPLUGGED.
CHECK FOR LOOSE OR BURNT CONNECTIONS ESPECIALLY THROUGH HE FILAMENT.
  • 871 Answers
Hi there
the heating element must be busted and partly shorted which makes the dryer drawing excess current. change this with something with lower resistance. Watts = volts times amps. Volts/ohms = amps.
and check also your thermal fuse. this might be also busted. you can find a replacement in an electronics shop.
here is a site which helps troubleshoot your dryer.
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
hope this helps ^_^
  • 4,102 Answers
Hi the problem could really be either but its going to be more than likely the temp sensor failing you will need to test this to see if it is working they can be replaced relitively cheap but depending on the age or dryer its wether anything else is going to go wrong as well but this all depends on the age let me know ok
Hi I've Got A Hotpoint Aquarius CTD40 Tumble Dryer
that isn't a model number,open the door to the dryer,look around the opening where you put the clothes in and send the full model number,
Dec 21, 2017 | Hotpoint Dryers
Hotpoint dryer ctd40
hi the problem you are having is more than likely going to be associated with the pcb board failing this controls the heating element and the temp sensor you will probably find a bad solder or failing component on the pcb side of the board these can be replaced but you need to work out the age of the drier compared to what else might go wrong let me know ok
Feb 11, 2008 | Dryers
I have a hotpoint dryer ctd40, it seems to eb
either your heating element,hi-limit switch,cycling switch, thermal fuse, or missing one leg of input power i.e.120volts instead of 240 volts
Oct 29, 2009 | Dryers
Hotpoint ctd40 t dryer. wont start just ticking.
do you hear anything running?,might have broken the belt or idler wheel,motor runs but no tumble,need to look inside,warning !! unplug ,high voltage.be carefull
Sep 22, 2009 | Dryers
Hotpoint aquarius tumble dryer, drum not going round but still
If you can hear the motor going, then the belt probably needs replacing, if no motor action, then prob is more serious.
Please rate my solution.
Thanks.
Jul 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
most likely, there is a blockage in your exhaust. take it apart and check every inch from your dryer to the outdoors. i clean mine once a year, it keeps the dryer running efficiently. when lint backs up in there, the heat cannot get out and there is a sensor that will shut off the heating element when it gets to a certain temp, so your clothes will take a long time to dry
Oct 27, 2008 | Hotpoint TDC32 Electric Dryer
If motor and drum are turning then problem lies with heater- thermostat or heater relay.
It is a process of elimination
Oct 26, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint t/d ctd40
my dryer doesn,t heat up & after a while the time delay,high heat & on off button flash.
Feb 11, 2008 | Hotpoint TDL14 Electric Dryer
Dryers Logo
Top Dryers Experts
Marvin
Marvin
