Sending Reverse Line feed to Epson LX-300+II USB printer
I am in development of a bill printing system using C#.NET, for this i am using a continuous paper. Once the bill is printed then i need to advance the paper to tear it off. So obviously i need to reverse the paper for the next print.
I am using Epson dot matrix printer connected via USB, the model number for the printer i use is LX-300+II. And my problem is reversing the paper. I request you to help me to solve this issue.
Thanks in advance
Shery Varghese
sheryvarghese@rediffmail.com
  • 3 more comments
  • sheryvrg Feb 12, 2008
    Hi Riz,
    Thanks you very much for your help.
    I have downloaded the user manual and i did not find any ESC code for reverse line feed. As the manual says i call use the front panel to set the top of the form, in this case i need to so this prior to all the bills being printed.
    I am looking for some ESC code which can be sent to the printer from my code. I have tried several ESC codes using SendKeys.Send() method. I think now you can help me in this.
    Regards,
    Shery Varghese
  • sheryvrg Feb 15, 2008
    Thanks for trying, Still i am unable to reverse the printer. I think this is because of USB interface.
    Regards
    Shery Varghese
  • jhamanjit Aug 02, 2008
    how the "chr" codes along with ? command will work for a dot matrix printer connected thru usb port. my language is vfp9 sp2 and printer is epson lx 300 + II
  • Anonymous Mar 13, 2014
    I am using epson photo 1390 printer with ciss ink system installed. And the media used is vinyl temporary adhesive sheets for mobile designer skins. My problem is the paper is coming out of the roller at the end 1 inch of the photo printing and whole printing gets twisted and disturbed because of this gripless issue while printing the last 1 inch of the photo. Please do help me with this issue. Thanks in Advance
  • Anonymous Mar 18, 2014
    the printer is locked
    Guru:
  • 731 Answers
Hi Shery,
I went through the manual of LX300 printer series.I believe that if u read that manual, you can Fix the problem as it has all instruction about the Reverse feed and pull tractor mechanism.
Download Manual
http://ftp.epson.com/pdf/lx300p/lx300ppg.pdf.Any issue contact me.
Thank you
Riz (zyrixdown3@gmail.com)
Posted on Feb 11, 2008
  • 7 more comments
  • Mohammed Rizwan
    Mohammed Rizwan Feb 13, 2008
    Hi shery,
    Thanks for your response.I have retrieve possible number of ESC codes.
    The following list shows the ESC Codes that use a variable within a command.
    The ASCII characters 1 and 0, or their decimal or hexadecimal equivalent can
    be used. Most programs use the ASCII decimal equivalent as the method of
    inserting codes. However, some programs are restricted to using only decimal
    values instead of the ASCII decimal equivalent.
    Note: "*" Indicates the command is supported.
    Epson 9/24 Pin Printer Control Codes
    éíííííííííííííííííííííííëííííííííííííííííííííëíííííííëíííííííí»
    º FEATURE º ESCAPE CODE º 9 Pin º 24 Pin º
    ìíííííííííííííííííííííííêííííííííííííííííííííêíííííííêíííííííí¹
    º PITCH AND PROPORTIONAL SPACING º
    çäääääääääääääääääääääääòääääääääääääääääääääòäääääääòääääääää¶
    º Proportional On/Off º ESC p n º * º * º
    çäääääääääääääääääääääääðääääääääääääääääääääðäääääääðääääääää¶
    º PRINT ENHANCEMENT º
    º Select NLQ or Draft º ESC x n º * º * º
    çäääääääääääääääääääääää×ääääääääääääääääääää×äääääää×ääääääää¶
    º Expanded Print On/Off º ESC W n º * º * º
    º Double High On/Off º ESC w n º * º * º
    º Underlining On/Off º ESC - n º * º * º
    º Select Super/Subscriptº ESC S n º * º * º
    º USER DEFINED CHARACTER º
    º Select Character Set º ESC % n º * º * º
    º MISCELLANEOUS CODES º
    º Unidirectional On/Off º ESC U n º * º * º
    º Half Speed On/Off º ESC s n º * º * º
    èíííííííííííííííííííííííêííííííííííííííííííííêíííííííêíííííííí¼
    Contd...
  • Mohammed Rizwan
    nly the decimal or hexadecimal values may be used for the command variable(s)
    listed on the following pages. For example, the command ESC k n in basic must be
    expressed as CHR$(27)"k"chr$(0) or CHR$(&h1B)"k"CHR$(&h00) to select the Roman
    font.
    º PRINT STYLE SELECTION º
    º Select Font: º ESC k n º * º * º
    º n = 0 Roman º º * º * º
    º n = 1 San Serif º º * º * º
    º n = 2 Courier º º º * º
    º n = 3 Prestige º º º * º
    º n = 4 Script º º º * º
    º n = 5 Ocr-B º º º * º
    º n = 6 Ocr-A º º º * º
    º n = 7 Orator äää¿ ú× Available only withº º * º
    º n = 8 Orator S äù à× Multi-Font Module º º * º
    º Character Style: º ESC q n º º * º
    º n = 0 Normal º º º * º
    º n = 1 Outline º º º * º
    º n = 2 Shadow º º º * º
    º n = 3 Outline & Shadowº º º * º
    º Master Select: º ESC ! n º * º * º
    º n = 0 Pica º º * º * º
    º n = 1 Elite º º * º * º
    º n = 2 Proportional º º * º * º
    º n = 4 Condensed º º * º * º
    º n = 8 Emphasized º º * º * º
    º n = 16 Double Strikeº º * º * º
    º n = 32 Double Wide º º * º * º
    º n = 64 Italic º º * º * º
    º n = 128 Underline º º * º * º
    º Select Score: º ESC ( - n1 n2 m d1 º º * º
    º n1 Must be 3 º d2 º º * º
    º n2 Must be 0 º º º * º
    º m Must be 1 º º º * º
    º d1 = 1 Underscore º º º * º
    º d1 = 2 Strike-Through º º º * º
    º d1 = 3 Overscore º º º * º
    º d2 = 0 Cancel Selectedº º º * º
    º Score º º º º
    º d2 = 1 Single Line º º º * º
    º Continuous º º º º
    Contd..
  • Mohammed Rizwan
    ìíííííííííííííííííííííííîííííííííííííííííííííîíííííííîíííííííí¹
    º Select Score: º ESC (- n1 n2 m d1 º º * º
    º (continued) º d2 º º º
    º d2 = 2 Double Line º º º * º
    º d2 = 5 Single Line º º º * º
    º Broken º º º º
    º d2 = 6 Double Line º º º * º
    º Broken º º º º
    º LINE SPACING º
    º n/360-inch Spacing º ESC + n º º * º
    º n/180-inch Spacing º ESC 3 n º º * º
    º n/216-inch Spacing º ESC 3 n º * º º
    º n/60-inch Spacing º ESC A n º º * º
    º n/72-inch Spacing º ESC A n º * º º
    contd............
  • Mohammed Rizwan
    çäääääääääääääääääääääääºääääääääääääääääääää×äääääää×ääääääää¶
    º Immediate n/216 Feed º ESC J n º * º º
    º Immediate n/180 Feed º ESC J n º º * º
    º Reverse Feed n/216 º ESC j n º * º º
    º Reverse Feed n/180 º ESC j n º º * º
    º PAGE FORMATTING º
    º Immediate Mode On/Off º ESC i n º * º º
    º Intercharacter Spacingº ESC SP n º * º * º
    º Page Length in Lines º ESC C n º * º * º
    º Page Length in Inches º ESC C NUL n º * º * º
    º Skip Over Perforation º ESC N n º * º * º
    º Set Left Margin º ESC l n º * º * º
    º Set Right Margin º ESC Q n º * º * º
    contd ...
  • Mohammed Rizwan
    º HORIZONTAL TAB SETTING º
    º Horizontal Tab º HT º * º * º
    º Horizontal Tab Stops º ESC D n1 n2..NUL º * º * º
    º Set Tab Increment º ESC e NUL n º * º * º
    º SET HTabs in Spaces º ESC f NUL n º * º * º
    º VERTICAL TAB SETTING º
    º Set Tab Stops º ESC B n1 n2..NUL º * º * º
    º Set VFU Tab Channel º ESC b x n1 n2..NUL º * º * º
    º Select VFU Tab Channelº ESC / x º * º * º
    º Set Tab Increment º ESC e 1 n º * º * º
    º Vertical Skip º ESC f 1 n º * º * º
    º Set VTabs in Channel º ESC b c n1 n2...NULº * º * º
    º Set VTab Channel º ESC / n º * º * º
    contd.....
  • Mohammed Rizwan
    º GRAPHICS º
    º Select Graphic Mode º ESC * m n1 n2 dataº * º * º
    º 8-Pin Graphics: º º º º
    º m = 0 60 DPI º º * º * º
    º m = 1 120 DPI º º * º * º
    º m = 2 120 DPI Hi Spd º º * º * º
    º m = 3 240 DPI º º * º * º
    º m = 4 80 DPI º º * º * º
    º m = 5 72 DPI º º * º º
    º m = 6 90 DPI º º * º * º
    º m = 7 144 DPI º º * º º
    º Select Graphics Mode º ESC * m n1 n2 data º º * º
    º 24-Pin Graphics: º º º º
    º m = 32 60 DPI º º º * º
    º m = 33 120 DPI º º º * º
    º m = 38 90 DPI º º º * º
    º m = 39 180 DPI º º º * º
    º m = 40 360 DPI º º º * º
    º Individual Graphics Commands º
    º Single-Density 60 DPI º ESC K n1 n2 data º * º º
    º Double-Density 120 DPIº ESC L n1 n2 data º * º º
    º Hi-Speed Dbl. 120 DPI º ESC Y n1 n2 data º * º º
    º Quad. Density 240 DPI º ESC Z n1 n2 data º * º º
    º 9-Pin 60 DPI º ESC ^ 0 n1 n2 data º * º º
    º 9-Pin 120 DPI º ESC ^ 1 n1 n2 data º * º º
    º Reassign Graphics Modeº ESC ? n º * º º
    contd...
  • Mohammed Rizwan
    º USER DEFINED CHARACTERS º
    º Define User Defined º ESC & NUL n1 n2 a1 º º º
    º Character º data º * º * º
    º Copy ROM to RAM º ESC : NUL NUL NUL º * º * º
    º Copy ROM to RAM º ESC : NUL n NUL º * º * º
    º n = 0 Roman º º º º
    º n = 1 San Serif º º º º
    º Select ROM CG º ESC % 0 º * º * º
    º Select Download CG º ESC % 1 º * º * º
    º JUSTIFICATION º
    º Justification: º ESC a n º * º * º
    º º º º º
    º n = 0 Flush Left º º * º * º
    º n = 1 Centering º º * º * º
    º n = 2 Flush Right º º * º * º
    º n = 3 Justified º º * º * º
    º SELECT CHARACTER TABLE º
    º Select Character Set: º ESC t n º * º * º
    º º º º º
    º n = 0 Italic set º º * º * º
    º n = 1 Graphic set º º * º * º
    º n = 2 User-Defined Setº º º * º
    º Remap to 80h-FFhº º º º
    º Printable Code Area º ESC I n º * º º
    º Expansion: º º º º
    º n = 0 Restore Codes º º º º
    º n = 1 Redefine Codes º º º º
    º Select International º ESC R n º * º * º
    º Character Set: º º º º
    º º º º º
    º n = 0 USA º º º º
    º n = 1 France º º º º
    º n = 2 Germany º º º º
    º n = 3 United Kingdom º º º º
    contdd........
  • Mohammed Rizwan
    º Characters (continued)º º º º
    º º º º º
    º n = 4 Denmark I º º * º * º
    º n = 5 Sweden º º * º * º
    º n = 6 Italy º º * º * º
    º n = 7 Spain º º * º * º
    º n = 8 Japan º º * º * º
    º n = 9 Norway º º * º * º
    º n = 10 Denmark II º º * º * º
    º n = 11 Spain II º º * º * º
    º n = 12 Latin America º º * º * º
    º n = 13 Korea º º º * º
    º n = 64 Legal º º º * º
    º OTHER CONTROL CODES º
    º Set Absolute Print º ESC $ n1 n2 º * º * º
    º Position º º º º
    º Set Relative Print º ESC \ n1 n2 º * º * º
    º Position º º º º
    º Repeat Data º ESC V n data º º * º
    º Color Selection: º ESC r n º * º * º
    º º º º º
    º n = 0 Black º º * º * º
    º n = 1 Red (Magenta) º º * º * º
    º n = 2 Blue (Cyan) º º * º * º
    º n = 3 Violet º º * º * º
    º n = 4 Yellow º º * º * º
    º n = 5 Orange º º * º * º
    º n = 6 Green º º * º * º
    Contd...
  • Mohammed Rizwan
    º CUT SHEET FEEDER CONTROL º
    º Cut Sheet Feeder º ESC EM n º º º
    º Operation: º º * º * º
    º º º º º
    º n = 0 Disable CSF º º * º * º
    º n = 1 Select Bin 1 º º * º * º
    º n = 2 Select Bin 2 º º * º * º
    º n = 4 Enable CSF º º * º * º
    º n = R Eject Sheet º º * º * º
    It is urged that a functional understanding of the printer commands be obtained.
    Reference to the User's Manual is encouraged whenever a more detailed command
    description is desired. Some of the commands listed are unique to certain printers.
    For a detailed listing of the commands supported by a specific printer, please refer to
    the Command Summary in the printer's User's Manual or the Control Code Matrix
    chapter in the Epson Programmers Reference Manual. The Programmers Reference
    Manual can be ordered from Epson Accessories Sales under Part No. : PTM-0.
    Note: If a particular command is not listed in the printer's Users
    Manual, the command is not supported.
    End.................
    Thank you
    Riz
Same problem
Posted on Nov 15, 2008
The ESC sequence command for reverse line feed for DMP is as follows
chr(27)+chr(106)+chr(n)
ie. ESC j n where n is n/216 of an inch.
It worked well in my Panasonic KXP-1694, given as a text input
found this on http://www.lprng.com/DISTRIB/RESOURCES/PPD/epson.htm
Posted on Oct 11, 2011
j$j$j$j$j$j$j$j$j$j$j$j$
copy and paste it in a notepad and print from dos prompt
eg: c:\>print file1.txt
----------------------by Bijesh.B----------------------
---------------------bijesh_kovalam@rediffmail.com---------
Posted on Apr 11, 2008
Epson LX-300+ II
just change the page length setting in printer .just press pause button and switch on the printer and change the setting accordig to the page size it is bettreif you take online help from epson service call center they will guide you how to set the page length.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 22, 2010 | Epson LX-300 Matrix Printer
Can not print with Epson LX-300
The USB to parallel converter does not always work.
You should buy a Parallel port for your computer if you have can extra slot inside the machine. The cost for the parallel port is usually under $20.
thanks adi
Oct 03, 2009 | Epson LX-300+ II Matrix Printer
Dotmatricx printing
Each machine has it own printing language (HPCL, HPGL, PostScript, etc.) You must first find out what command language it responds to.
Hope it helps.
Aug 28, 2009 | Epson LX-300 Matrix Printer
Setting custom size (tear off) paper
I have some problem, but now have solved
1. replace your original epson lx-300+II driver by IBM ProPrinter II from windows installation driver.
2. in control panel-->printer and fax-->choose IBM Proprinter II ---> click File-->server properties--> click form tab--> chek create new and fill new paper size and don't forget give a name (ex. 8.5x6)--> save form
3.In printer and faxs right click IBM Proprinter II-->choose properties--> click device setting tab --> change tractor feed, manual paper feed and upper paper tray feed to new name (8.5x6)
4. Good luck
Jun 18, 2009 | Epson LX-300+ II Matrix Printer
Can print correcly
plz check all the settings, language setting must be check , after that if the problem not solved then uninstall the driver and again reinstall the printer driver
May 27, 2009 | Epson LX-300+II Matrix Printer
Unable to do a reverse line feed
Describe your Epson LQ-2180 Dot Matrix Printer Problem
Apr 12, 2009 | Epson LQ-2180 Dot Matrix Printer
Epson LX-300+II not printing in draft 10 cpi using visual studio .net
use courier font. it works just as draft font. no problem in VB-6 i hope it will also work with .Net as well.
tell if dont work.
asad khan
justasad@hotmail.com
Oct 27, 2008 | Epson LX-300 Matrix Printer
Epson LX-300+II, the font problem
yes you can change the font tray to print the printer internal setting tray that press and hold any key by tarn the printer off then on after you tarn the printer on release the key
Sep 06, 2008 | Epson LX-300+ II Matrix Printer
have you check the white cable? (from the printer head to the
mainboard) .If the white cable is ok and you confirm that the
printer head is fine, then the problem is at the mainboard.
most problems like this that i had encountered is at the transistor
at the mainboard. Try to check it out using a multitester.
Epson lx300+ii with serial port to fujitsu pc
use the com1, and use a baud rate like 9600, with 8 and 1 bit stop. dont. be sure that is in ESC/P or IBM as you requiered. if your software use directly the serial port, be sure that the bios set up is properly. i think that the lx300+ have less buffer than lx300+2
and if you use high speed, could loose info.
Jan 28, 2008 | Epson LX-300+ II Matrix Printer
5,438 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
