Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Fan in back of freezer making clicking sounds
The ice and water dispenser are not working. the fan in the back of the freezer is making a clicking sound. this morning, the freezer and refrigerator is not working. is this a simple solution?
  • laurentmp Feb 20, 2009
    THe clicking is not constant. When water or ice dispenser lever is pushed indicator lights dim and then clicking will start again. So far no problem with freezer or fridge temperatures?
  • francis rivero May 11, 2010
    please elaborate on the clicking sound of the fan. tnx.
What is the part number for the control board? I have the same problem... thanks!
Posted on Mar 10, 2008
From what your telling us sounds like the control board is failing. Any questions hit me up.
Posted on Feb 13, 2008
Where is the evaporator fan motor? My Freezer and fridge would quit cooling/freezing. I took the back panel off in the freezer a week ago and the evaporator coils were completely frozen over with ice. I...
I do not believe the problem is the fan. sounds like the frig. is low on Freon this is what will cause the ice build up. you need to find the leak, you can do this by spraying soapy water on coil tubes & watch for bubbles. repair leak & recharge.
May 25, 2015 | Samsung RS261MDBP Side by Side...
Fan turns off in refrigerator section.
Its issue with defrost timer causing the fan to turn OFF.
Get the timer checked.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Clicking sound from back of fridge
Its faulty capacitor or compressor relay or the timer.Its in the lower end back.
These will help.
Thanks,.
Dec 22, 2012 | Hotpoint HSS25GFP Side by Side...
Freezer fan not running
It can be faulty fan motor or blown compressor capacitor.
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
I have a maytag dual cool side by side fridge, recently the ice maker has reduced ice production and the ice cubes are not fully formed ( Almost hollow). When you use the water despenser it makes a...
It sounds like you have a water flow problem. I would inspect the unit for ice building up in or around the freezer fan motor. If the ice is forming in side the freezer, the trouble could the a restriction in the fill tube. But this does not affect the water dispenser. The noise you hear could be the water line moving when water flows through the line, or your water valve itself could be the problem, like the valve shutters when in use.
The valve is easy to check, its located behind the unit in the back left corner. Remove the screw holding the valve in place, while dispensing water hold the valve and see if the issue is only the valve. If the valve is the issue this could cause both problems you have. Part number 67005154
Water Valve
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 21, 2011 | Maytag Refrigerators
The ice dispenser and water dispenser on the door will not work
"Prepare for the worst" This is a problem i'm currently dealing with at the moment, ice maker thaw'd and refroze the ice as a block, binding the crusher turbine till it quit working. then water dispenser started spitting till it quit working, but anyway i disconnected the ice maker and water dispenser power hookup, because when i tried to use it it was drawing off the power of the fridge. now i'm to the point where fridge clicks like the relay is going out. in the back of the freezer below the ice maker tray i removed the clip or screw to where when it clicks i can hand spin the cooling fan on the click, and fridge starts up and runs, but don't remove this panel because having it on helps the air push into fridge compartment and keeps cooling elements from turning to a block of ice, " so long story short " its either your cooling fan or relay on chip board that starts cooling fan, i'm no expert but this is where i'm at hope it helps.
Jan 02, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
HI I hope I have reached Sea Breeze because I see someone had the same or similar problem as we are having from our GE GSS25... side by side refrigerator. this person wrote: "Water now comes out but only...
You have a bad main control board . Located behind the refrig , behind an 8 X 10 " panel . Easily replaceable . Sorry , not Seabreeze . You can reach him at seabreeze appliance parts . com , I think .
Sep 08, 2010 | Refrigerators
Freezer light, ice maker, and ice/water dispenser stopped working
did you replace the light . or just tighten it . and is ice cream soft . it sounds like the tempt is above 15 deg . and needs to be colder . this may be a control problem . but ck the little things first . clean the coils / make sure inside fan and under neath fan are going . re ck control settings . .. if problem does't go away . then look at control ..
Jul 29, 2010 | Frigidaire Refrigerators
Loud noise from freezer of GE model GSF25TGTB (Side by side)
Problems not related.  The first is most likely the fan, or possibly water dripping on to the fan and freezing, but usually the noise comes from the fan struggling to run.  The cube problem could be as simple as the ice dispenser being put back in wrong.  There is a metal lever under the ice tray that switches between crushed and cubed.  Make sure it is seated properly.
Dec 04, 2009 | GE GSF25XGR Side by Side Refrigerator
Hotpoint side by side Model HSS25GFPJWW
Your problems are the power board for sure. I have the same refrigerator and have read dozens of forums and advise pages looking for answers. If you let the problem countinue your fridge will completely stop cooling and all your food will be trash as has happened to me.
Symptoms: Fan in the back starts to make click or flopping sound as it tries to start up. Ice despenser doesent despense ice. water works sometimes. Eventually you notice your food defrosting partially and then refreezing as the defrost timer stops working which is controlled by the power board. Light dims and pulses when you hold the Ice despencer in. If you remove the light for the dispencer your water will work fine as long as the fan isnt making the clicking noise. Fan will eventually start up and run.
FYI GE customer Care is useless
Jan 03, 2008 | Refrigerators
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
75 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Joe Lamb
Joe Lamb
