Hp1300 The feed button is blinking and there is no any movement or sound from the printer. please help
    Problem Solver:
  • 10 Answers
You have a paper jam or sensor arm that is stuck in open position. I suspect you look at the rear cover by the fuser unit. You will see a small sensor lever. make sure it moves freely. Also check the paper sensor where you load paper.
Posted on Feb 11, 2008
Hi how can i reset the printer zebra lp2844 back to factory settings?
1.turn off printer
2.press and hold feed button
3.press power button
now led id blinking 3 time
4.then release both button
and single press feed button
now it will com receipt .... successfull
Let me know this helpful
Jan 06, 2011 | Zebra LP 2844 Thermal Printer
Paper feed fault
Check the printer lens and make sure the paper is probely inserted. Hope this helps...
Jan 28, 2008 | Canon BJC 3000 InkJet Printer
Tip
Use this method with your own risk!! E2-2 = No paper (ASF) E3-3 = Paper jam E4 =...
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Reset E27 Waste ink absorber full or platen waste ink absorber full for Mp140
turn off printer.
- press and hold your finger at on/off with reset/stop button together
- turn on printer power switch
- release the button on / off, but at the same time continue to press the stop / reset and then press the button on / off again and continued to hold the two buttons.
- wait a moment
- relese stop/reset button 2X.( you will see the led light blinks twice when you press the stop / reset twice)
- release on/off button.
wait until the screen on the printer control panal shows the number 0.
- after printer panel screen shows number 0.
- press stop/reset button 4x
- press on/off button 1x
- wait until you hear the movement of your printer roller
- when you hear the movement of the roller your printer, wait a while until you do not hear any sound of movement in your printer. :)
- turn off and turn on printer again and your will see your printer back to normal.
Ok world...Good luck
------>>>Download guide to fix waste ink overflow ip1000 Click Here
on Jul 21, 2010 | Computers & Internet
Using repair reset program for epson stylus color 860
Try this manual reset.
Press and hold LOAD/EJECT+CLEANING buttons,
Press POWER and hold it down until you see blinking INK OUT and PAPER OUT lights, then
Release all buttons.
After 2-3 seconds press and hold CLEANING button until all lights blink.
Restart your printer.
Jan 14, 2010 | Epson Stylus Color 860 InkJet Printer
Squeaky HP printer
Typically the squeaking comes from the toner cartridge. If you just purchased it, take it back, it's bad. If you can find an identical printer, swap cartridges and see if it makes a difference.
May 27, 2009 | HP LaserJet 1300 Printer
Zebra Z4M only feeds a small portion of the label.
You should try a factory reset. Power off the printer. Hold the "pause" and "feed" buttons down while powering up. Allthe lights will blink and when they stop blinking, release the "pause" and "feed" buttons. This will factory reset the printer.
Apr 24, 2009 | Zebra Z4M Printer
Worn out teflon coated roller
'Fuser" rollers are often teflon covered aluminum rollers, but in the case of an HP1300, it is a "fuser film" wrapped around a heating element -which enables the "instant on". You can google it , or find them on ebay.
Apr 21, 2009 | HP LaserJet 1300n Printer
Canon ip90 printer wont grab paper
The most likely culprit is that the rollers that pull the paper are dirty. Use the steps below to clean the rollers.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
1) Confirm that the printer is powered on.
2) Remove any paper from the printer.
3) Press and hold the <Resume/Cancel> button.
4) Release the <Resume/Cancel> button after the Power lamp blinks three times.
Note: The Power lamp will blink and the paper feed roller starts cleaning itself by revolving.
5) When the Power lamp lights in green, repeat Steps 3 and 4 up to two additional times. (Please wait approx. 30 seconds for paper feed roller cleaning to complete.)
6) To confirm whether cleaning has been performed properly, set a blank sheet of plain paper (8 1/2 x 11 Letter size) in the sheet feeder or cassette.
7) Press and hold the <Resume/Cancel> button and release it when the Power lamp blinks three times. (The paper set in the printer is picked up and fed.)
8) Repeat the process as necessary
May 12, 2008 | Canon PIXMA iP90 Mobile Printer
Lexmark printrio x1185 just keeps on blinking doing self test...
Hi, on my older Z series printer, as it got older I took some 3in1 oil and a Q tip and applied just a little oil to the slide rods or bars that the cartridges slid back and forth on. They get quite dry with the paper dust and time. Also here is a link to Lexmarks tech site. Hope this helps,, Mechanic
http://support.lexmark.com/static/229-1-0-435.html
Jan 14, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Zebra lp 2844 thermal printer
It sounds like it needs to be re gapped. Try this:
1. Make sure that printer power is off.
2. Press and hold the feed button.
3. Turn printer power on.
4. When the status light blinks, release
the feed button.
5. The printer advances the media to
measure and verify the length of
individual labels or tags. The printer
then prints a status summary and
remains in diagnostic dump mode.
6. To begin normal operation, tap the
feed button. The printer prints "out of
DUMP" and advances a label.
Nov 30, 2007 | Zebra LP 2844 Thermal Printer
204 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
