Question about HP OfficeJet 7110 All-In-One Thermal Printer
Feeder won't pick up paper
I keep getting out of paper error. paper is full.
  • Anonymous Feb 13, 2008
    Same exact problem on a HP 3210. Only 218 printed pages on 14 mos old machine. An estimate at shop yestrerday told me it would be cheaper to throw out....Argghhh.
    SJ
    President:
  • 2,351 Answers
When i try to print it takes shows error, what do ido?
That suggests that the problem was not with the feeder or shaft, but with a sensor.
Can you check the sensors, or cal a service agent?
May 26, 2016 | HP LaserJet P2015 Printer
Multiple pages feed when printing on hp 7410
  • If the automatic document feeder (ADF) does not pick up any pages at all, the rollers inside the automatic document feeder need to be cleaned.
  • If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
SolutionLoad one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.note.pngNOTE:If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water. If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face plate from the front of the automatic document feeder, access the pick assembly inside the automatic document feeder, clean the rollers or separator pad, and then reattach the face plate.
Please Click on this link to know more in detail.
Thanks
Apr 01, 2012 | HP OfficeJet 7410 All-In-One InkJet...
Good day, I keep getting an error message saying the Feeder Tray is full - even when empty?
You might have a dislodged flag but your error is sort of cryptic. Is it the ADF feeder, the manual tray feeder? More details might enable me to answer your question better. Check all the flags in the paper paths to ensure that they move smoothly and are not stuck in one position.
Sep 02, 2011 | HP LaserJet M4345 MultiFunction Printer
The paper keeps jamming during feed I have changed it but it still jams, I think there is a fault with the feed section at the bottom but I cant find a manual that shows technical details for repairs so I...
Did you replace paper feeder with new one? Most paper feeder problem are rubber at paper pick up roller (bottom side) and small spring at bottom paper pick up roller. Check for "something" slip at paper feeder and lubrication at paper feeder mechanic.
Feb 02, 2010 | Epson Office Equipment & Supplies
I have a canon pixma mp780 all in one printer. It keeps saying add paper but the paper tray is full.
Check the feed switch, you can put paper in the bottom tray or the top feeder and you press the feed switch to change from one to the other, when the rollers are dirty and paper doesn't pick up you also get that error.
Jan 14, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Hi I get this 250.07 paper jam check mp feeder on Lexmark t644
Please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Lexmark T644 Laser Printer
Feeder grabing the paper crooked causing jams and paper unable to go through the feeder smoothly. it stops once the feeder grabs the paper.
set the paper tray size to the size of the paper...if this is ok...clean the pick upo roller with damp cloth and soap water...if this doesnt help ...change the pick up roller..
keep me posted
May 04, 2009 | Computers & Internet
I865 flashing 3 times
That's a "paper jam" error that can be fixed by removing all paper and pressing the resume/cancel button. Then replace the paper in the feed chute.
The printer can straighten out a crooked feed to a very limited degree. The photo feeder attachment can interfere with a really full 8x11 feed. The i860 is very susceptible to overfilling the 8 1/2 x11 feeder without notice until you try to print. I usually remove the photo feeder until I need to print photos, and keep the regular paper feeder no more than 3/4 full. I pull out the regular paper when printing photos.
Feb 24, 2009 | Canon i860 InkJet Photo Printer
No Paper in Document Feeder
I just upgrated my Vista system as recomanded, and after that I am not able to scan documents, getting the messGE " NO PAPER IN THE DOCUMENT FEEDER " on my all in one laiser jet 3050
May 23, 2008 | HP LaserJet 3055 All-In-One Printer
HP OfficeJet 7110 All-In-One Thermal Printer Logo
Ben Johnson
