Question about Xerox Phaser 7400/DXF Laser Printer
Phaser 7400 hi,my name is maha, i live in cairo, i have a xerox phaser 7400, it is a beautiful machine, but recently i am having two problems' the first is when i switch it on, it gives the error message (Error U60), which after like 10 times of restarting then the machines would start operating the second problem is that when i print on art paper 250 gsm, sometimes i get clouds at the background. i appreciate the help, please could you email me on : mahazabdu@aol.com thanks
  • apierson Feb 06, 2009
    There are greay streaks/clouds in the background when I use any paper thicker than copy paper.
I have a phaser 7400 printer when i turn on the printer it say cyan led error turn off printer and turn it back on. It keep on giving me this message what should i do. Another thing is that a gear on the waste cartridge is broken is there a way i could fix it without getting a tech to come look at it. It alway say waste toner is full, ( replace it) which i already did. What should i do?
Posted on Mar 14, 2008
    President:
  • 2,072 Answers
The closest I can find to your description is a U6-0 and the suggestion is to replace the transfer belt assembly,
Posted on Feb 13, 2008
Why is my Phaser 7400 printing a solid pink page? The Transfer unit is half pink. Is this why?
This may be a high voltage problem.
Am not familiar with this machine but is a generic fault.
Ensure contacts to drum/cartridge are clean.
Next
If possible, unplug machine, open up and ensure all high voltage connections are good.
Good luck.
Jul 24, 2015 | Xerox Phaser 7400/DXF Laser Printer
I have a phaser 7400dx and the color alignment is off, I've heared people talk about that it is set in the main board and can be fixed. I was wondering how it is fixed?
Below is the link to 7400 documentation, the user guide on this page provides good info on color and image misregistration problems and some potential fixes ...
http://www.support.xerox.com/support/phaser-7400/documentation/enus.html
Alos, if it is a problem wioth your main PWB you may want to contact your Xerox service technician for assistance ......
I hope this helps.
Mar 09, 2015 | Xerox Phaser 7400/DX Laser Printer
Xerox Phaser 7400 U28 error message
The Service manual says:
The Drum Phase Sensor for the named Imaging Unit indicates that the drum is out of position.
Initial Actions:
Reseat the indicated Imaging Unit.
Cycle the printer's power.
after these steps it gets a lot more detailed and you would need to be an experienced tech to understand everything and follow the steps within a timely manner, if reseating the cyan imaging unit doesn't fix the problem, then you will have to call for service.
Hope that helps
Christopher
May 20, 2012 | Xerox Phaser 7400/N Printer
On power up the xerox phaser 7400 displayed.
HI there check the fuse on the xerox machine and let me know its ok or not.
Jan 24, 2011 | Xerox Phaser 7400/N Printer
I have Xerox Phaser 7400 with an error 928 we changed the fuser 2 weeks ago now the error has come back
Error 928 refers to the fuser motor failing. Problem could be with fuser motor, motor drive board or engine board.
One other possible cause would be if you are sending too thick a card stock through the machine, this can cause drag on the fuser which the machine interprets as a motor failure.
Hope this helps.
Jan 05, 2011 | Xerox Phaser 7400/DXF Laser Printer
We have a Phaser 7400. It continues to give us
If you've already changed out the toner cartridge and the problem persists, then it could be several other parts that are either defective, dirty or blocked.
You may want to contact a certified Xerox technician and have them look at the Imaging Unit Agitator Bar and the Low Toner Sensors for Cyan/Magenta. There could also be a faulty toner supply motor.
Sep 10, 2009 | Xerox Phaser 7400/DT Laser Printer
Xerox Phaser 7400 printing
Reinstall the latest print drivers. This issue has been resolved previously
Apr 22, 2008 | Xerox Phaser 7400/DXF Laser Printer
Xerox phaser 7400
Remove the tray, first look for a piece of paper that has come out of the tray inside the tray area.
Make sure the rolllers are snapped into place. The easiest way to verify that is to remove another tray and compare them.
Look to see if all the switches and actuators are in place.
Make sure you hear the tray up motor running when you close the tray.
Also inspect the paper tray itself for broken items. Compare it to another tray.
Feb 03, 2008 | Xerox Phaser 7400/DXF Laser Printer
Xerox Phaser 7400/DXF Laser Printer Logo
1,426 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
