Question about Lowrance iFinder GPS Receiver
Map loading from SD card
Mapcreate7 data will not load, is there a way to update the iFinder
    Problem Solver:
  • 17 Answers
Yes go to the Lowrance web site and down load the fix to a sd card , put the sd card in the i finder and it will update it automaticlly. I have not done it for map create 7.0 but have for map create 6.3. On the web site look under suport or downloads and you should find it. There is also a lot of free lake maps that you can download to sd card also. Good luck
budman630
Posted on May 15, 2008
Navigation map do not show up, next turn etc. Also show message "no map info".
My problem was cured by reformatting the Mini SD card that holds the map data. I had the same problem this week with my Garmin Nuvi 265. After doing an update I received the "No Data Available" message when trying to use my GPS. After trying three days of so-called fixes I remembered that, at least in my case, the map is stored on a Mini SD card. I pulled the card from my Nuvi and popped it into the computer to see what's on there. There are 4 or 5 files associated with the map. I deleted the files and reformated the Mini SD card using the FAT32 setting. I reinistalled the card into my GPS. Prior to connecting the GPS to my PC, I uploaded the latest version of Garmin Express. Once that was loaded I reconnected the GPS and had to re-register the unit. Once that was done the software told me that there was a new update. I ran the update. Lo and behold . . . after about 25 minutes the map was successfully loaded to my Nuvi and it was working as it should.
Mar 20, 2016 | Garmin nuvi 50 Travel Assistant
Will not let me enter an address.....shows NO MAP DATA AVAILABLE?????
update failed or was corrupt or memory failed or wiped just reconnect to pc an let it update again
May 09, 2015 | Garmin nuvi 1100LM 3.5" GPS w/ Lifetime...
Can not put an address in garmin nuvi
Try running an update with Garmin Express, let it sit for 30 Min after it says it is done, then check again
otherwise you may have jsut installed a smaller region ,... again Garmin express could help.
Aug 04, 2014 | Garmin nuvi GPS
Loading Maps
MapCreate Topo does not have lake maps. There are 'some' maps on Lowrance's web site (Free Enhanced Lake Maps) but you may need to purchase lake maps on SD cards for the area you're interested in.
Jun 02, 2009 | Lowrance iFinder H2O GPS Receiver
Fine drive 400
you will need a 1gb sd card, for the data one solution is to visit C&C wireless and pay over $100 for a map update or even send them your unit for even more $. see http://www.finedrive-acc.com/shop.cart?action=ITEM&prod_id=F400-08CP
The other solution was to send it to Fine Digital but they closed their doors in the US so they no longer support us customers. Because of this I made a DVD with map data I purchased from them before they closed and I added much better instructions; this DVD updates the firmware in the unit and loads the last map data issued to the SD card. you would need a PC with a DVD drive and SD card reader to use it. you can find these DVDs on ebay for $18 which basically covers my costs only.
Dec 16, 2008 | Fine Digital FineDrive 400 GPS Receiver
I have a Finedrive 400 gps. When I turn it on it says it cannot find the card. I'm guessing the SD card lost map info, odn't know why. went to Finde Drive and their updates are $110. Do you know of sites I...
This is a common problem with these units, it happens if the unit is shut off while its writing data to the SD card.
Nov 29, 2008 | Fine Digital FineDrive 400 GPS Receiver
Can not download map data for fatal application error
One solution is to visit C&C wireless and pay over $100 for a map update or even send them your unit for even more $. see http://www.finedrive-acc.com/shop.cart?action=ITEM&prod_id=F400-08CP
Nov 04, 2008 | Fine Digital FineDrive 400 GPS Receiver
Nuvi 200w map download and sd card
Guys and or ladies... I know that you have to create a folder named "GARMIN" in the sd card so the maps can be recognize. Maybe this solves your problem. Let me know if it works.
BR from Spain,
Carla
May 11, 2008 | Garmin Nuvi 660 GPS Receiver
Putting maps on sd memory card
(Untried)
For C330 owners that want to have both Canada and US 2008 map update on their GPS this is what you have to do.
Must have:
1 - Street pilot C330
2 - 512mb SD card
3 - SD card reader of some form (some cameras will suffice)
4 - Garmin 2008 Map Update North America
What to DO:
1 - connect the GPS to the computer
2 - Insert the Map update disk
3 - Install the Lower 48 states, United States
(Reason - the C330 has around 1000mb of memory and the "US 48 states" map uses around 900mb" while Canada uses 400mb...which is why you will need that 512mb SD card later)
4 - Once the GPS is updated with the US map. Browse the Map update disk contents. This can be done with going to "My Computer" right click on your CD/DVD drive and click on "Explore"
5 - Open the folder called "img"
6 - Copy the file called "gmappromU.img" file is around 430mb. (This is the map file for Canada)
7 - Insert your SD card into your card reader and connect it to your computer. A window should pop up. If not you should see it on your "My Computer"
8 - Once you have navigated your way into the SD card directory. Create a folder on the SD card named "garmin" (no caps)
9 - Go into your newly created "garmin" folder right click and paste the "gmappromU.img" file. (This may take upto 20 to 30 mins)
10 - Once the process is complete, Rename the "gmappromU.img" file to --> "gmapsupp.img" (watch for spelling, no caps at all)
11 - Remove the SD card, Turn off your GPS, Insert SD card into GPS.
12 - Turn on GPS, let it load, and there you have it, the FULL North America Map.
When you are searching a state or province (depending where you are located) it will give you an option which map to use, Canada/Alaska or the lower 48 US states. Select your map and you are set to Go.
Feb 01, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin i2/i3
Either you have a bad micro SD card or you are loading more data than the card can hold.
You will need slightly less than 2GB of memory load load USA and Canada all together at the same time.
You can also try buying an external card reader and instead of loading to the garmin load the map data onto the micro SD card from the reader.
Dec 03, 2007 | Garmin StreetPilot c340 GPS Receiver
Lowrance iFinder GPS Receiver Logo
372 people viewed this question
Top Lowrance GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Wbix
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
