Question about Canon PIXMA iP4200 InkJet Photo Printer
Canon Pixma Ip4200 Ink Smudges
Hey, Just recently whenever I print there is a black ink mark being left on the edge of the paper/card. I have cleaned print heads and rollers by following instructions through my printer but this dose not seem to make any differance. Some one told me that Canon have a tendency to need their print heads changed, but the printing side of it is great its only right on the edge after printing its leaving a mark. Is there anyway of solving this? Lisa
  • 1 more comment
  • Didget Feb 14, 2008
    Hey, Thanks for getting back to me. I use compatable cartridges for canon, would they leak the same? You say to clean the printheads, how do I do this? Ive done all the maintainace cleaning for the printer in the printer properties and the alignment is set to auto, so how would I now clean the printheads? Thanks Lisa
    Hey! Ive cleaned all the print head and the sponges and it seems to have solved the puzzle..... You're a star and probly saved me a lot of money :-)) Thanks again! Oh by the way your English is gr8! :-))
  • Anonymous Mar 19, 2014
    When sheet prints out, the left edge is wrinkled and has black edge from ink.
    Sniper:
  • 60 Answers
1. Do you use refilled or genuine Canon cartridges?
2. Anyway, try to clean the printheads, because they seam to leak.
3. Verify if the cartridges are correct alignet (in maintenance software you have soewhere an "align cartridges" function
Posted on Feb 12, 2008
  • Iuliu Ciupe-Vaida
    Iuliu Ciupe-Vaida Feb 14, 2008
    The printhead is the part where the cartridges are putted into; cleanig it means to get it out, it usually comes out after releasing a stopper there, and gently wipe it with a clean soft tissue moistured with warm water.
    If iy still leak somewhere and make that black on the right edge, it may be because the waste ink tank (a sponge located right under the place the cartridges "park" on the right side) is full of ink. In fact, that is the ink that is absobed in the cleaning process or when you start the printer. So if that one is full, then the printhead will be made dirty with this waste ink every time it reaches the right end, and it put the ink drop at the edge of the paper.
    To clean the sponge you need a bit of tehnical skills, as i said it is located right under the place the cartridges "park" on the right side, if you can reach there somhow you get the sponge out and clean it with warm water and a drop of liquid soap, then rinse, let it dry an put it back in the printer.
    It should solve the problem.
    Let me know and rate the solution.
    Sorry if my english is not the best! :))
The pixma ip4200 will print any color but black. I have run through two black ink tanks trying to deep clean it. Will the cost of repair approximate the cost of a new printer?
I think the black ink is still clog up and need advance cleaning. You just need small repair and cost will not expensive. It is about 10% of new printer.
May 01, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
I'm trying to print wedding invitations on my Canon MP460. I'm using a cardstock thickness of paper and have set the ink levels for "Other Photo Paper" on my Mac. The paper has been going through...
Sounds like the ink isn't having time to dry and is rubbing along paper.
Paper may be too thick. If it prints OK on normal paper (test first) but not on thick card, then it doesn't support thick paper settings.
Jan 31, 2011 | Canon PIXMA MP460 All-In-One InkJet...
Blue (CYAN) not printing despite changing ink tank
enough ink b ut not printing at all - blank paper on every time despite noise as if printing
Aug 17, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Pixma ip4200 willl not print Cyan
I think the problm lies between the ink tank and the printhead. When this passage runs dry, sometimes it takes time for the ink to fill this passage again. Try printing again after a day or two.
Jul 17, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Won't print black when set for plain paper
Try removing all ink bins except black then you won't have any problems. You should also be able to go into your printer settings and select "Black and White" or "No Color" and it will print ok. Removing the ink trays is the easiest way though.
May 28, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
The black ink will not print on my canon pixma ip4200
printer head problem remove ink put about ten drops of alcohol in where the ink goes in run clean cycle ten times
Mar 29, 2009 | Canon Office Equipment & Supplies
Canon PIXMA MX700 printhead immediately coated with ink, smudges
It's likely that the foam pads that the print head rests on when the printer is not in use are saturated with ink. They're to the right as you look into the printer: a rectangular one for black ink and a square one for the colored ink. If you power the printer off and back on, with the cover open, you'll see where the printhead goes to rest.
The pads aren't easy to get at, but you can blot them with a paper towel. Gummy, half-dried ink dissolves in rubbing alcohol, and you can soak a paper towel or a cotton ball with alcohol and wipe down the area. I've had good luck soaking the pads with alcohol, then blotting them dry with a rag.
Feb 18, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Black ink line on back of paper
Hi , look some used injection cyrene to suck up the used ink , take cover suck up all ink by reversing injection put in clean jar .after all ink finished cover it try to print from first time some print some black mark after tthree or four times maybe no more.
Jan 08, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Black Smudges of the First Copy. Canon pixma ip 3000.
try cleaning all the runners that the paper uses on the printer. Clean the dabbing pads inside the printer too.
Dec 23, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Printing to card
The solution in this case is to either use Canon card paper to print on or set the media type in your printer driver to the correct paper.
The paper you are using is not absorbing the ink correctly, so when the paper exits the machine the rollers are contacting the ink and causing the smudging.
Either you have to alter how much ink is being used by changing the media type in the printer driver, or you have to buy the correct Canon paper
I've seen this happen on Canon's Photo printers when a generic glossy paper was used. Switching to canon paper solved the problem.
Sep 28, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA iP4200 InkJet Photo Printer Logo
416 people viewed this question
old marine
old marine
