Wus flashin a Font (LP0003_ChowFun.shx)... for L7 (using RSD Lite... onto V360v w/ Wolf-MP) went away from PC (as one duz during flash process :Yawn:) and wen i came back WTF!! My screen only shows the followin message
Boot Loader 08.D0. SW Version: R4513_wolf-MP. ACR Battery Low <<== (Is flashin on and off) Cannot Program <<== (Is flashin on and off)
Not sure wat all this means as i had 2 3rds of battery left b4 flashin (hav flashed L7 Font in past w/ 1 3rd battery w/out any drama) Taking out battery/ reconnecting to PC/ and variations cant get Daemon to recognize it... ie, PC wont connect to phone so I cant (dont know wat 2 do) do anything w/ it... Hav to go bak 2 ol clanger nokia I guess... any help much appreci8ed...
Update: Phone wont charge either... Outer screen flashes once every 15-20 secs when connected to charger... HELP!! :-<
The service is completely free and covers almost anything you can think of (from cars to computers, handyman, and even drones). click here to download the app (for users in the US for now) and get all the help you need. Good luck!
My friend gave me a razor to unlock last night that he just bought from a long time user on Cingular network. Since I unlocked without trouble I thought I would help someone out. Basically you need to flash one software into your phone, then you need to run another program and unlock it. Here is how I did it. Download and install EMULE, a free program. Run EMULE and select edonkey network only and forget KAD network during setup. Don't upload with emule in chunks as I believe it takes more processing power from the PC. Now run EMULE and click Connect. After it connects search for a program called P2K.EASY.TOOL. It will be around 6.2MB file. Extract all the files and look for a file called P2K_Easy_Tool_v39 and extract this also. Next, you need to get the program called RSD Lite 3.0. Again get this file by searching emule for this and downloading. Then install the program by double clicking on .msi or right click and click install. Now get the program Motorola_Unlocker_2005.zip. This can be found quicker at themotoguide.com/unlocking.php. This file may not be necessary or this step! CHARGE the phone to full charge. I forgot two more file are needed! You'll need to USB drivers for the phone. The ones I used were v3_drivers.exe (search yahoo) and always click continue anyways. Finally, you will need bl_826-828_to_07d0_ for_V3_by_Archy.V2.shx (no space between 07d0_for_) and this file can be gotten at themotoguide.com/unlocking.php. If you attempt to communicate with the phone it may want to install drivers and you may have to do the operation again. When installing drivers, just specify the folder where you extracted USB drivers. Now lets get started. Plug the phone into USB cable and turn on. Run the program called RSD Lite 3.0 and then it should say connected and show your phones IMEI #. If not, you could restart phone, but press # and * with one hand then start up. Now it should say in RSD LIte 3.0 something different. You can leave it like that or restart phone and then you should definitely see IMEI #. Now click on FILE in RSD Lite 3.0 and search for the file bl_826-828_to_07d0_for_V3_by_Archy.V2.sh… and click OK. Now lets downgrade the bootloader, click START. Wait tell it is done and finished at 100%. Don't even mess with the computer during this time or any cables. Turn phone off and hold down * and # on phone again and turn phone on into Flash mode again. It should say 07d0 now or be a blank screen, which is fine. Now run the program Motorola_Unlocker_2005, click send to phone. It will do something and your phone will reboot. If it is unlocked then you are done. If it didn't work as mine didn't with this step then turn phone off for third time. Again boot up in flash mode by holding down both * and # and turn on with other hand. It will be in flash mode with black screen. Now run the program called P2K_Easy_Tool_v39.exe and there is one other file in this folder called winscard.dll. Click on LOCKS and then select your phone model. Now select Unlock SP. Click on DO SELECTED JOBS. It should show the status above and will do some work, then reboot phone do some more work and power off, I remember. That is it turn it on and you are done. Lets sum this up on what is needed. EMULE, P2K.EASY.TOOL, RSD Lite 3.0, Motorola_Unlocker_2005.zip, bl_826-828_to_07d0_ for_V3_by_Archy.V2.shx. You could probably skip the Motorola_Unlocker_2005.zip step. If for some reason you destroy your phone! You have a 80% chance of recovering it by going to www.themotoguide.com/downloadfirmware.ph… and getting one of these three files, extracting it. Then flash it into your phone with RSD LITE 3.0. Do not do any of these steps if it is illegal in your country or you don't deserve to use your phone yet or buy talk time from a network!! http://www.themotoguide.com/unlocking.ph… Hoped it Help.....
I had the same problem with a phone that was donated -- user forgot the pin to unlock the phone. There is a way around this. You will need to reflash the phone. I used RSD Lite, which is a Motorola Utility for flashing their devices.
But first, you will need a flash file to overwrite the one on your phone that is associated with the pini code. To find an appropriate flash file, search for "ModMyMobile" which is a forum that has various Razr flash files. You will need to enroll, but its free.
Locate and download the appropriate .shx file and unzip to a directory on your computer that you can easily find.
Run RSD Lite and connect your Razr with a USB cable. The program should locate your phone and put it into bootloader mode... don't panic, it is supposed to. Now click on the "..." button up top, locate the unzipped .shx file and hit "Start".
It takes about 5 minutes to reflash and presto - you phone is working again! :-)
My v360 is doing the same thing...don't know what to do...
