Question about ViewSonic VA1912wb Monitor
A line of Dead Pixels.
Hi i purchased a ViewSonic Va1912wb last year. it was working fine until today morning. i was working on my pc when suddenly a green vertical line appeard on screen. it looks like a line of dead pixel. it has been there ever since it appeard. i tried connecting the monitor to another pc, the line still appears. is there a way to fix this? please help.
I see I am not the only one who is having some difficulty with the monitor, however if the monitors do have a 3 Year Warranty on it, and it would be best to get it sent in, and properly repaired. It looks great (use mine for games as well as standard usage), but remember if they put the warranty on it, then send it in and let the guys who made it fix what they didn't do right the first time.
Posted on Dec 27, 2008
    Scholar:
  • 84 Answers
You are right it is a stuck or dead pixel, usually if it is a colred line but not grey it is a stuck pixel at the beginning of the line you can try a utility designed to flash bright colors repetedly over time to see if this will "unstick" it. Also you could have a dry joint on your TCP which would require opening it up to diagnose.
Posted on Feb 11, 2008
My viewsonic Va1912wb flashes horizontal lines when you turn it on and i know it is not in pal and it is not the refresh trate help me please
Hi There and Welcome to Fixya.
Horizontal or vertical lines flashing/running across the screen poses serious display issues with any LCD/CRT monitors. It only boils down to 2 possible causes :
  • Corrupted video driver
  • Hardware issue
To help you determine which of the above, here's what you need to do.
  • Ensure that the computer is turned OFF
  • Disconnect ALL USB devices except the keyboard
  • Turn the computer on and immediately hit "DEL" (in some systems, it's the "F2") key repeatedly until you reach a different screen. (not the usual Windows screen)
  • Welcome to the BIOS screen
  • From here, spend 30min to 1 hour observing if the lines are present in this mode
If you still see the horizontal lines, then there's a need for the monitor to be serviced by a certified/trained technician. The link below will direct you to their support page for repair/replacement options, depending on your warranty status :
ViewSonic Support
Otherwise, the problem can be resolved by re-installing the operating system.
I hope this helps, Thanks for using Fixya.
Apr 09, 2011 | ViewSonic VA1912wb 19" LCD Monitor
My viewsonic va1912wb just flat-out died. Won't turn on, no lights, no response. Is there a likely cause, and is there anything user-repairable?
You have monitor with a very common problem, a dead power supply. After 2-3 years many LCD monitor power supplies will fail just like you have described. The problem is caused by parts called capacitors overheating in the tight space of the monitor case. If you can solder then you should be able to do the repair yourself. We will have a repair guide posted 12/29 after about 5:00 central time that should get you back going again. The repair guide will be on our web site at: www.ccl-la.com If you have any questions please let me know at the address below.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Dec 29, 2009 | ViewSonic VA1912wb Monitor
No display on Viewsonic VA1912wb
Your monitor sounds like it has gone bad. Cost for a repair is not worth it, a new one would be cheaper. Prices have gone down a lot in three years
Sep 11, 2009 | ViewSonic VA1912wb 19" LCD Monitor
ViewSonic VA1912wb 19" LCD need sound driver
operation174 -
Here is the driver download page for your monitor:
http://www.viewsonic.com/support/downloads/drivers/?prod_name=VA1912wb
Choose the correct download for your operating system.
Thanks,
videoman7
Aug 07, 2009 | ViewSonic VA1912wb 19" LCD Monitor
White static flickering on Viewsonic VA1912wb
Please check the line voltage 220V AC and check the earthing voltage 3V AC..
Jul 09, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Viewsonic VA1912WB error says analog signal
I had a Gateway 19" TFT that did the same thing.
Does the power light stay on? If so, you more than likely have "dry" solder joints at the inverters. Take it apart & shoot a little solder on the inverter solder joints. Good as new now. The solder joints dry out because of the high heat generated. This is a very common problem.
Apr 22, 2008 | ViewSonic VA1912wb Monitor
ViewSonic VA1912wb Monitor Logo
315 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
