Question about Canon PowerShot SD950 IS Digital Camera
My camera doesnot remain on
I have SD950 powershot camera, the problem is, it can't stay on, when I press the ON botton the light just turns on for a 1 or 2 second, it ejects the lens and it goes off. I have checked the battery and everything. Is there any solution ?
  • aracelyhdz72 Jan 15, 2009
    hi, I have the same problem with my camera turns on and with in 1 or 2 seconds turn off, and it ejects the lens and it goes off...Please anyone cand help me...
None of thos things work
Posted on Oct 11, 2008
  • Canon Master
  • 4,738 Answers
Are you using alkaline batteries? If so, alkaline batteries just don't have the power for more than a few pics in a digital camera. Some may even have problems just powering startup of the camera. Digital cameras for the most part should only be used with rechargeable NiMH batteries. Walmart sells these for around $7 for a package of four (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Posted on Feb 16, 2008
  • CameraR
    CameraR Feb 17, 2008
    Ooops, just noticed your camera is a SD950 that uses a Lithium Ion NB5L battery. Forget what I said above, it doesn't apply, sorry.
    You may instead be experiencing a lens error.
    Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
    Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try, especially if the camera is no longer under warranty:
    http://camerarepair.blogspot.com/2007/12...
I can't turn on the camera, even with a fully charged battery.
The battery contacts are like little springs, as the camera gets jostled these can stop making good contact. Open the battery case and try force holding the battery against the contacts (You may need to hold a piece of metal across the bottom of the battery as you push) Then see if the camera comes on.
If it does, you may have to stuff, pull, or rig the battery to fit more securely.
Mar 17, 2010 | Canon PowerShot SD950 IS Digital Camera
My canon sd950 is will not start when i press the on button. the lens tries to open, but then shuts
Hi there, please relace the battery with new fully charged battery. After that is the same problem happens then clean the power button & clean the lens guide pin internaly. After that your problem will be solve. Thanks.
Mar 15, 2010 | Canon PowerShot SD950 IS Digital Camera
Camera will not turn on
clean the bazttery comparment,contact points,if u fail to get on the camera,then it is problem of power section,so contact canon service station
Mar 05, 2010 | Canon PowerShot SD950 IS Digital Camera
Canon sd950is won't turn on
Dear Sir,
Welcome to Fixya
Might want to take a look at this:
http://canoncanada.custhelp.com/app/answers/detail/a_id/11506/session/L3Nuby8xL3NpZC9FVFAyZDdCag
A screw inside some Canon PowerShot SD950 IS cameras may loosen and fall out due to vibration that is generated while carrying or using the camera. Apparently a screw might have come out that prevents the camera from turning on.
The repair is free-of-charge, even fro out-of-warranty period.
I think it helps.
If you have any problem regarding this issue leave a feedback we were Happy to assist you.
Have a Nice Day
Oct 14, 2009 | Canon PowerShot SD950 IS Digital Camera
My Canon PowerShot SD950 IS won't turn on
http://canoncanada.custhelp.com/app/answers/detail/a_id/11506/session/L3Nuby8xL3NpZC9FVFAyZDdCag==
My SD950 just refused to power on during a trip out west. Apparently a screw might have come out that prevents the camera from turning on. The repair is free-of-charge, even fro out-of-warranty period.
It is a beautiful camera: pictures are not too shabby, but the design is fantastic for a portable ...
Jun 23, 2009 | Canon PowerShot SD950 IS Digital Camera
Canon SD950 IS malfunctioning - please advise
I have vertical bars apperaing on my Olympus SP-560,
In my case I know it has been caused by damp on the light sensor behind the lens, which once dried was better. But ideally I need to remove the lens to clean the sensor. Which I've still yet to work how it is done.
Oct 04, 2008 | Canon PowerShot SD950 IS Digital Camera
Canon PowerShot SD950 IS. I can't find the usb outlet on the camera???
Hi - You can download the manual by clicking the link underlined in blue below:
SD950 IS
See page 26:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 05, 2008 | Cameras
I'M PLANNING TO BUY A CANON SD950 DO YOU THING BY BUYING A MEMORY EXTREME 111 4 GB IS GOOD?.
I have owned several Cannon brand cameras (not this particular model) and have always been very happy with them. I would support the purchase of any Cannon product.
cnet gives this camera a good review.
http://reviews.cnet.com/digital-cameras/canon-powershot-sd950-is/4505-6501_7-32591168.html
May 01, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon PowerShot SD950 IS Digital Camera Logo
116 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
