Question about Video Cameras
Dropped my camcorder
Today my brother's camcorder hit the floor!  I actually tripped over the cord while it was plugged in.  Didn't seem to hit hard.  Was blurry and then went to nothing.  Can't get into menu, can't take tape out?  Any ideas??  Thanks!  My brother is getting married this weekend! We were going to tape the wedding!!
I have a GRD63EK and I did the same thing to it yesterday. I believe mine worked until picking it up twisted the firewire, bending it down.
I am not sure of this as it all happened at once
  • flaxipani Sep 04, 2008
    hi my flash isn't working.. maybe I changed the wrong setting.. I am not sure.. what should I try doing first? My flash is set on normal though on the viewfinder shows the flash icon with strike through it showing me my flash is switched off.. ?? I dont know where I need to go to turn it back on.. nothing happens anyway (the flash wont pop up) when I try to take stills in still camera mode.. please help. Thanks
    President:
  • 4,402 Answers
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Posted on Feb 11, 2008
Toshiba SAT A505-S6005 Power cord was plugged when laptop fell to the floor and hit where the cord attaches to the receptical (on computer) which jammed (pushed) the thin connector prong further into
When this happens it means that the whole recepticle has been broken off of the motherboard and the whole laptop will have to be disassembled. This is not an easy job for someone who hasn't done one before. After it's disassembled it has to be determined if the recepticle can be resoldered or not. Sometimes the damage is not repairable. Good luck!
Nov 22, 2012 | Toshiba Computers & Internet
I dropped my 42 in dynex 1080 p but it didn't hit
It usually means the screen unit or panel is damaged--they are very fragile and even a slight blow can destroy them---Panel alone if bad costs much more than another set--seen one where a two year old just slapped the screen (not very hard either) and destroyed it Panel.
I will attach a few photos---no two look alike except if a starburst or odd pattern does not move---Panel.
Apr 13, 2012 | Televison & Video
I dropped my hard drive and now it wont unlock.
Bdfreo you do anything, try the device on anopther pc. see if it works then youhave nothing much to worry. if it does not, then i guess you have to go for data recovery
May 05, 2010 | Western Digital My Book Essential Edition...
Hi, my Frigidaire AC (FAA068P7A) unit was working fine last year. Put it back in the window today and now it won't power on. I checked the power cord, but cord is fine (I actually opened up the machine...
Sounds like a breaker has tripped (caused by the unit) or is it might just be 'off' for some reason. I would check the outlet (where the AC plugs in at).
If the AC is a 110V unit you can check the outlet by plugging in something else, i.e. a hairdryer. If the hairdryer doesn't work either - then you know your breaker is tripped. On the other hand if the hairdryer 'works' then you know the problem is in the unit, where I'm afraid you'd be better off to have a technician to trouble-shoot it, although you could try sending additional information at this point for more help.
Remember if it is a breaker tripped - it was probably tripped by a malfunctioning Air Conditioner so if it 'trips' again in the immediate future you will need someone to check it out.
good luck!
May 03, 2010 | Frigidaire FAA068P7A Air Conditioner
My iomega portable hard drive fell off the table onto the floor and now it does not work it makes a funny high pitched beeping noise and does not sound like the drive disks are moving. What should i do?and...
I don't know this hard drive to well but I know that when a hard drive is dropped/fallen onto the floor, it probably won't work seeing as they are fragile. You'll have to phone the company that created/imported this drive because they'll have the spare parts to fix it.
Dec 07, 2009 | Computers & Internet
No power getting to my Lakewood fan...
Maybe you tripped over it so hard you de soldered the wires form the inside. Have you openned it? Try it out if you didn't. Check the power cord and follow it all the way into the motor (with the motor openned). Check if one or both cables on the inside are desoldered.
May 09, 2009 | Lakewood HV 18-c Floor / Box Fan
Brother tripped over speaker cord
open up tthe speaker case and resoulder the leads/unless the wires pulled loose from the speaker face on the back of the speakers that should fix the problem,if the wires are pulled loose from the speaker face then reattach them with a drop of craze glue and a small drop of silicone sealer which should do the trick!
Jun 02, 2008 | Logitech Z-2300 2.1 Computer Speaker...
Hotpoint aquarius1100 electrical prob.
you say tripped the switch?... are you talking about a circuit breaker???.. I was thinking maybe you have a bad breaker... If you had no problem before... maybe try in a differt plug in reciptical... if the washer has a short.. hard to find sometimes..like looking for needle in hay stack..
Sep 02, 2007 | Washing Machines
HELP needed.
This seems to be a common problem without a solution. I took mine into a Sony Centre and they said that the cost of repair would be more than the units worth!
Jul 04, 2007 | Sony NW-A1000 MP3 Player
Video Cameras Logo
265 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
