Question about Panasonic Lumix DMC-FZ18K Digital Camera
Battery charger i recently purchased a FZ 18 in the UK will the battery charger work in the the USA bearing in mind the voltage difference ie 250 / 110 or do i need a different charger for the US
    Problem Solver:
There is no problem as far as i can tell after looking at the charger it is compatable to both UK and USA electricity systems
Posted on Feb 14, 2008
  • 56 Answers
If there is no option of voltage change you need to buy a new one for us. because the US use 110/60 HZ and UK use 220/50Hz. S the problem not only the different voltage it is also the problem of Freequency(50Hz & 60Hz).
Posted on Feb 11, 2008
Can all 18volt 5amp makita batteries be charged on either a 240volt or a 110volt charger. Since I charged mine on a 110volt charger the green/ red lights on the charger start flashing bear in mind the...
The charger input voltage should make no difference on the output voltage / current, if they are designed to run on that input particular voltage. A 240 volt charger will not work on 110 volt and vice versa. If in doubt check the output voltage of the charger with a voltmeter. Make sure you are getting around 20 volts dc.
Mar 09, 2018 | Makita Drills
I have bought a Braun epilator 7 , Braun type:5377 , in USA and have purchased the charger in the UK which is 100-240 v , do I still need to get a voltage converter to be able to use it in the UK ?
If the charger is 100 to 240VAC, it should work. USA use 110 volt so the charger should be OK with 240. The UK charger will probably have a UK 3 pin plug on it. If you use it in the US, you will have to change the plug again or buy an international adaptor which can be adapted to fit most outlets anywhere in the World.
Apr 19, 2015 | Braun Health & Beauty
I need a PIHSIANG Model SA60-3015 U charger for my mobility scooter
hi, no you don't , a compatible will do , what model shoprider mobility scooter is it please ? please bear in mind shopriders chargers a rebadge units , i have repairs hundreds of these...
Regards
Rob
www.gewizrepairs.co.uk
Oct 14, 2014 | Health & Beauty
No display, won't charge, dead, after cold storage
hi, you say the voltage is 3 volts each, then it never work , remember it's requires at least 18 to 20 volts to light up.
if a battery measure's below 10v it's normally impossible to charge again as a lot of chargers will not go below this level, you could try a car battery charger to bring the level up however do this with care and don't leave on charge
Regardswww.gewizrepairs.co.uk
Dec 27, 2012 | Invacare Supply Group Invacare Lynx L3...
I have recently purchased a G22 Yamaha Golf cart and it's just over 4 years old. The batteries were replaced about 4 months proir to my buying. it goes well but the charger shows after charging a yellow...
When I have this sort of problem, I always double check battery connections, all should be clean and tight and the cables should be in good condition. Then I check each battery under load and see if any voltage drops too much. If that doesn't show any problems then I think a dealer might be your answer. A dealer would have a battery discharge machine that would how good your batteries are.
Jun 15, 2017 | Golf
Hi, my drill has just stopped working i have changed the battery but it seems dead ?? the drill is about 3 years old but has only been used a hand full of times as it a personal home diy tool ?????
When you put the battery in the charger, does the light go on? The charger has lights to indicate whether the battery is fully charged or not. If it is dead when you put it in the charger and remains that way after one hour, you can be pretty sure that the battery is dead. If there are NO lights on the charger, plug it into a different outlet and recheck. Not using the drill for long periods of time is really not good for the battery. The drill is probably ok, but the charger or battery could be the problem.
Nov 15, 2009 | Dewalt 18 Volt Compact Drill Kit
Do i require an adaptor for my mobile phone charger in the usa my phone is a nokia i live in the uk
Like any other AC device you will need an adaptor as the voltages are different.
Sep 14, 2009 | ovolab Computers & Internet
I am considering purchasing a Toshiba LCD TV in the United Kingdom (London area). I will be returning to United States in ~18 months and was wanting to know if a TV purchased in UK is compatible in U.S....
Generally NO as UK uses a different line value than US (SECAM )VS (NTSC) also the power ratings are different 240V as oposed to 120V for USA
Please rate our help to keep the free service online
Aug 28, 2009 | Televison & Video
Would Samsung i900 omina from UK work in North America
Hi
as far as I am aware the bands are the same world wide if you have quad band, otherwise we from the UK would not be able to roam abroad with them. Only thing I would worry about is the mains charger, as the voltage is different in europe to USA (220volts/240volts ----- USA 110volts) Oh and the plugs themselves are different. Might be worth also checking with Samsung if warranty is worldwide! I think it is?
Apr 27, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Open Questions:
Panasonic Lumix DMC-FZ18K Digital Camera Logo
56 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
