Registry i need 2 something abt the windows registry,such as wat is all abt?,how tis helps me in acessing the user details ets
    Brigadier General:
  • 3,614 Answers
Hi karthee,
Every version of Windows since Windows 95 has used a Registry, which is essentially a database containing the configuration information for the OS, its peripherals, and any installed software. The Registry is among the first things that Windows loads at startup, and it tells the OS everything from how menus and the Desktop should look and feel, to where all the vital files and programs reside, to which hardware is installed on the system.
The Registry actually includes a series of data files stored in different folders in your Windows subdirectory, all according to which OS version you’re using. For instance, in WinXP Home or Professional, the Registry has six files located in the Config folder at C:\WINDOWS\SYSTEM32\CONFIG. Win98 SE and WinMe have different files in other locations, but in all cases, it’s easier to access the Registry via the Registry Editor.
The Registry Editor, the Regedit.exe program, resides in the Windows subdirectory. But the quickest way to open the Registry Editor is to click Run from the Start menu, type regedit in the field, and press ENTER.
Now that we told you how to open the Registry Editor, we should also warn you that it’s unlike other Windows programs because it saves any changes you make on the fly rather than waiting for you to decide to save your changes. Yes, the Registry Editor will save any changes you make as you make them and apply those changes to the respective files and settings on your system. You cannot negate your edits or deletes simply by bailing out of the program without officially saving anything. This means that any user venturing into the Registry Editor must take special care to track any changes made and protect him or herself by backing up the Registry before tinkering with it.
Hope it's help's you.
Enjoy!
Hope to hear more from you soon
tnx
-micro
Posted on Feb 11, 2008
Rand mcnally 710 navi.exe has encountered error
go on lione and do the back up anbd reset to factgory setting it should be ok
Mar 05, 2013 | Rand Mcnally TND 710 GPS Receiver
Tip
How to Backup and restore the registry
In case you go and modify the registry manually and you want to back it up in case something goes wrong and you want to restore it, this is perfect for you.
Backup:
1.) Go into the start menu and click "Run".
2.) Type "cmd" and click OK
3.) type in the window "copy c:\windows\system.dat c:\windows\system.000" and press enter.
4.) Once Complete type "copy :\windows\user.dat c:\windows\user.000" and press enter.
You have now created a backup of the registry.
Restore:
1.) Go into the run menu again and type cmd.
2.) Type in the 2 commands that was shown in the backup section except in each command swap the twon directores.
(e.g.) "copy c:\windows\system.dat c:\windows\system.000" will become "copy c:\windows\system.000 c:\windows\system.dat"
Whatever was backed up when you created the backup file will be restored to the windows registry.
on Dec 26, 2009 | Computers & Internet
Wat does regedit means
regedit is an an inbuilt Microsoft Registry Editor. To start the regedit.exe go to Start>>>Run>>> type regedit and click OK. The Microsoft Registry Editor (regedit.exe) enables you to view, search for, and change settings in your system registry, which contains information about how your computer runs. Although you can use Registry Editor to inspect and modify the registry, doing so is not recommended, because making any incorrect changes can damage your operating system. Please go to http://en.wikipedia.org/wiki/Windows_Registry for more details.
Mar 22, 2012 | Acer Computers & Internet
Abt trapdoor doesn't go up
Hello
I've only the user manual for your ABT Trapdoor Electriscreen projectior by Stewart. No other service details can be available now by NET search. There is one indication given in the user manual about the malfunction of the screeni I'll copy it here to you.
SCREEN WON'T OPERATE => NO 120V POWER AVAILABE OR OUTBARD SWITCHING PROBLEM => [1] CHECK TO SEE WHETHER THE CIRCUIT BREAKER IS SWITCHED OFF. RESET IF NEEDED.[2] CHECK OUTBOARD SWITCHING APPARATUS. [3] CHECK VOLTAGE AVAILABILITY; CONTACT AN ELECTRICIAN. [4] CHECK THAT TOGGLE SWITCHES ARE IN THE CORRECT POSITION. SEE FIG 2, P.5
That is all. OK.
Oct 28, 2011 | Stewart Filmscreens ABT TRAPDOOR...
Its nothing to do with the wires it wont boot up from my hardrive and when i go into my bios settings its saying that i havent got full acess to it please help thanks
you will have to make yourself the adminstrator
click start control panel user accounts on the users tab,click the name of the computer administrator you must have full control also you can change the password there
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
Hope this helps
Apr 11, 2011 | Computers & Internet
I have hp 530 laptop .but my brother change poweron password in my laptop .he forgot the password..can i solve this problem?
You need to remove the access panel on the back of the laptop, locate the jumper labeled E49 and remove from positions 1 and 2 and put it on 2 only. Replace the cover and boot up, this should get you past the password.
Please leave feedback if you find this helpful. Thanks.
Mar 18, 2011 | HP 530 Notebook PC
MY I 4 GOT THE CODE AND NOW IT SAYS IPOD IS DISABLED CONNECT TO ITUNES AND I HAVE A NEW COMPUTER SOOO WAT DO I DO CAUSE I CANT PLUG IT IN TO THE SAME COMPUTER I DID IT WITH CAUSE I DONT HAVE IT I NEED...
1. Make sure iTunes isn't running.
2. Click Start, type regedit, then press Enter.
3. Navigate to this Registry location:HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers
4; Its better you clean/repair Windows registry with RegInOut.
4. Look in the main pane for a key that refers to iTunes. If you find one, delete it, then exit the Registry.
5. Start iTunes. The offending message should be gone!
Sep 29, 2010 | Apple iTunes
I want to only name of reliance user number 09309341710
this is possible only through the service proider after ou have provided them ith convincing information abt why you need the user details..... as matter of security user details are privy only to the service provider
regards
iversh
Sep 29, 2009 | Yahoo Computers & Internet
Abt my pc
I would suggest the following (all free):
1. Download, install, and run Lavasoft Adaware.
2. Download, install, and run Spybot.
3. Go to www.pcpitstop.com, register, and run full tests.
Jul 20, 2008 | Microsoft Windows Vista Ultimate Edition
Administrator rights are not getting executed - Windows Vista
SYSTEM restore should help u
Restart the computer and return to the OS in "safe mode"
THen you click system restore from control panel and restore the system giving admin password when asked.
Theres another way of changing the setting in registry but thats too cmplicated, and i am not sure abt it
Apr 12, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
174 people viewed this question
David Payne
David Payne
