Question about Canon PIXMA iP5300 InkJet Photo Printer
Print result with 3mm white line every 3cm row
Hi, my problem must be rare. Just now I tried printing a document but when the printer started to roll, my headphone cable went in the printer and got rolled into the printer. My headphone was on top of my printer.
Now I realized that thereafter if I print black and white, I see white lines of 3mm thick every 3cm row (3mm of content that supposed to be get printed is gone every 3 cm). But if I print color it looked fine.
What can I do now to solve it? Please help...
Thank you in advance.
bowz.
    Sniper:
  • 60 Answers
Unfortunate, the cable catched in the printer affected the printhead part where black ink is coming out. Maybe some plastic got on the nozzles (from the cable), if you have some technical skills you can dismount the printhead (where the cartridges are put in) and check the downside of it, where the nozzles are, clean them with warm water and a soft tissue. Not with paper tissue.
If that doesn't help, it means that soft plastic-parts are clogging the nozzles, it could be fixed with steam blowed under pressure trough the nozzles, but it requires special equipment you probabily dont have. A printer service in your area could have such equipment, try and clean the printhead with their help.
This is valable if the nozzles arent damaged (scratched), if this is the case then Canon gotcha, because a printhead is very expensive, kind of the price of a whole new printer.
Let me know if it helped you on mail arad@mediatec.ro. Rate the answer please.
And sorry if my english is not the best.
Posted on Feb 12, 2008
Alignment off
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, please try this approach:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 2600 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Align to fix blurry edges. Your printer will then print a page and aligning your print cartridges. Try to print a document again to verify that the problem is fixed.
Dec 11, 2011 | Lexmark X7170 All-In-One InkJet Printer
Lower case r flashing
Hi, your thermal transfer film in the larger internal trap door on the printer- slide on RHS of printer will open it- is either loose or out of its holder. Open the door, remove the rolls- tighten then refit. Close the door and retry. Make sure you remove and refit the paper each time you start your machine as the paper tends to roll up as it has been fed into the printer about 3cm after it last printed and this curls the papers end. I normally turn the paper around. Inset a minimum of at least 2 to 3mm thickness of paper. Let me know if this works- Ross
Jun 20, 2011 | Panasonic Panaboard UB-5315
BROTHER MFC-210 PRINTING IN BLACK INK POOR QUALITY BUT COLOURED INK FINE. USING INK MANAGEMENT TO CLEAN PRINTER NOT HELPING. HAVE TAKEN OUT AND REINSTALLED BLACK CARTRIDGE WITHOUT IMPROVEMENT. WHEN...
Try cleaning the black printer heads several times in a row, at least 5 times then print a black document with best quality setting.
Press the ink button, then down to select select cleaning and then press menu/set and menu/set again to select black.
Dec 19, 2009 | Brother MFC 210C All-In-One InkJet Printer
Printed pages have white lines
Adjust the properties of your print mode the default is normal change it to best. the printing speed will change but the print quality will be good.
Apr 27, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
White lines in print
Does the printer have replaceable printing heads, or are they integral to the ink cartridge. If so they may need replacing or calibration. Another issue may be electronic contacts, check inside the printer and on the cartridges for any dirt or debris on the (usually copper colour) contacts on either end.
Also, if possible try the printer on an alternate computer to ensure it is not a problem with your software.
Kind regards, ACD
Jun 10, 2008 | Office Equipment & Supplies
Printer duplicate rows from the document
I dont even get working...
When I turn on the printer and put on-line this happens:
1. "hardware connected" alert sound ("tiru")
2. printer gets initialized.
3. "hardware disconnected" alert sound ("turi").
4. go to 1.
This stops when I turn off the printer.
Oct 19, 2007 | BafoTech BAFO BF-1284 Parallel Adapter
Canon PIXMA iP5300 InkJet Photo Printer Logo
old marine
old marine
