Question about Apple MacBook PC Notebook
Macbook Shutting Down
When I turn on my Macbook, after few minutes (5-7mins) working on it, it Shuts Down automatically
    Problem Solver:
  • 18 Answers
I think this is a battery problem. Even if you charge it etc. if your battery id faulty this could happen. I've had this problem several times (yes, several) and if your computers less than a year old they wont make you pay for the battery. Don't send it, take it into the store. Hope that helps.
Posted on Apr 13, 2009
  • 44 Answers
You don't say if you have the computer plugged in or not, but if this happens with the battery, then it's possible the battery is bad. Apple had a batch of bad MBP batteries that it replaced last year. If you had one of these batteries, the charge would be lucky to last 10 minutes and when it died it really died, it didn't go to sleep like a MBP is supposed to do when the battery runs low.
Posted on Oct 06, 2008
    Scholar:
  • 163 Answers
You Need to get the Trash Thermal Factory Paste off the Heatsink/CPU/GPU and clean all components 100% Spotless. (De-natured alcohol And a Clean lint free cotton cloth)..Then apply a small ammount of AS thermal paste to the pads on the Components only. Do not get it on anything else as it has conductive characteristics. (Or at Least Semi-conductive)..
(Arctic silver = AS)
Well Known Issue on these models..
Posted on Mar 10, 2008
  • 4 Answers
Like Ekse said, this is more than likely an overheating issue. If your internal fans aren't working properly, you can always go out and buy a laptop pad with a built in fan that might keep it cooler longer and keep it from shutting down so quickly.
Here's an example of what I'm talking about:
http://store.apple.com/AppleStore/WebObjects/EducationIndividualCustom.woa/9454004/wa/PSLID?mco=FC7688FE&fnode=home/shop_mac/mac_accessories/extras&nplm=TN932LL/A&wosid=Wa6fhSWR1L9Y3NTOKPa1nfKd022
Hope this helps!
Posted on Feb 13, 2008
  • Apple Master
  • 13,433 Answers
Possibly a overheating issue. Make sure the fans in the laptop are working and feel does the laptop get unusually hot?
If it is a overheating issue if you have the technical skills you could open the laptop and clean or replace the fans. Althought this probably will void your warranty. But then again i took my acer apart 3 times and still got it thrue warranty. If you choose to do it its your responsibility.
Posted on Feb 11, 2008
Why does my macbook air keep shutting randomly?
Sounds like a sticky key that thinks it has been pressed
Nov 14, 2014 | Apple MacBook Air
Tv timer shuts off
If the TV gets very hot it maybe shutting down on its own accord however there should be a way to navigate to the sleep menu through the buttons on the front of the set.
Feb 19, 2013 | Samsung Televison & Video
What does f61 mean?
F61 is an error code.
It will automatically shuts down your unit.
This is very common on your unit.
Try to checked if the fan is working or not.
I have repaired some unit before, this is the caused why f61 appeared.
The symptom is shutting down the unit after a few minute.
If the fan is not working it will shuts off automatically to avoid further damaged to your output I.C.
If confirmed that the fan is working then I've suspect that your output I.C. is shorted.
This is quit technical and need to send to repair shop to isolate the faulty parts.
The output IC of your unit is RSN series and quite expensive.
Pls rate my help.
Thaks for using fixya...
Jan 16, 2011 | Panasonic SC-AK18 CD Shelf System
The heater keeps shutting off, i unplug and wait a few minutes, then try again it works for a few more minutes then shuts off again.
Defective thermostat is shutting it down before it reaches the correct temperature. Essentially the thermostat is acting too sensitive.
Finding parts could be tricky probably worth replacing for the potential repair cost.
Jan 02, 2010 | Sunbeam LowProfile Space Heater
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Samsung shuts off automatically
Check air vents around cabinet. Suggests over heating and shutting down due to thermal switch. Clean vents and fan inlet
Jun 27, 2009 | Samsung Televison & Video
Philips/Magnavox TV, model MS3250C321 shuts off randomly.
TV shutting off automatically means its a problem with the Lamp. Contact Pioneer or any local tech shop or Best buy and get the same replaced.
Turning off after specific time : Go to the timer option and disable the Automatically Switch off option. This will resolve the issue. Please let me know if it worked. If you need the user manual or instruction manula please click on the link below
http://www.generalmanual.com/Televisions/Sanyo-DP19647-Wide-Screen-Integrated-Digital-LCD-HDTV.htm. Hope this will be of help to you.
Thanks
Oct 17, 2008 | Televison & Video
Ps3 shutting off on its own
Did you check a fan maybe not working and ps3 is overheating and automatically shut down
Jun 19, 2008 | Sony Playstation 3 (PS3) Console
KP-51HW40 - Auto shut down problem
I had the same problem. i was told by one of these so-called experts @ fixya that my flyback transformer needed to be replaced (the 8 blinks on the standby was the indicator). but i recently replaced it and im having the same problem. sorry. no advice. good luck.
Jun 18, 2008 | Sony KP-51HW40 51" Rear Projection...
Apple MacBook PC Notebook Logo
167 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
