Question about HP Pavilion dv4000 Notebook
Windows has stopped working
When i start the computer windows does not open. The window that opens all the time is the window with the following,
We apologize foe the inconcenience, but windows did not start successfully.
Then it states
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Start windows Normally
i have tried them all and nothing works it just goes back to the same thing. Can you please help
  • 1 more comment
  • suzflorida Feb 15, 2008
    I am having the same problem. I get the exact prompts and none of them work. It also keeps trying to start windows after the 30 seconds is up. It will keep doing this continuously.
  • Pascal Willemen
    Pascal Willemen May 11, 2010
    Is there an options saying:
    "Use the last settings that worked" or something similar?
    Greetings,
    DarkNeogen.
  • Anonymous Mar 30, 2014
    When working, unasked for windows open on my screen. I have to restart to get rid of these.
  • 520 Answers
It sounds like it hasnt been activated and the time is up.you can re install as a fresh copy and you"re given 30 days to activate your copy.if youve recently updated to newer sp it needs to be activated.you can try removing the battery and power;reconnect and rebooting sometimes if youre persistent ,eventually youll get something to come on.
Posted on Feb 20, 2008
    Scholar:
  • 163 Answers
If you have an XP disk you could also try running the Repair console.. fixboot and fixmbr as well as chkdsk /p will cure alot of issues..(If last known settings option does not help)..
Posted on Feb 11, 2008
Why has it stopped working?
Apparently in some cases all you need to do is start Excel/Word/Powerpoint/Outlook as Administrator in order to get permissions to do something on the computer. If you're using Windows 7, right-click the application in the Start Menu and click "Run as administrator". See if this works for you.
In Windows 8, open the Home screen, find the application you're trying to open; right-click it and select "Open as administrator" at the bottom.
. If you are still experiencing the issue I can suggest this program Excel Repair Toolbox
https://www.repairtoolbox.com/excelrepair.html
Mar 29, 2016 | Microsoft Excel 2013 1PC/1User
INCREDIMAIL STOOPED WORKING
incredimail sucks big time and have many problems try a other email program like outlook 2010/2013 or thunderbird from mozilla
Nov 22, 2013 | IncrediMail
How to identify acer veriton model number
In Windows 7 try the following,
Open a command prompt and type in the following command to get the local computer model name.
wmic csproduct get name
and this will get you the serial number
wmic bios get serialnumber
Alot of the times the computer model number and serial number are located on a sticker on the rear or bottom of the machine.
You could also possibly find this information in the system windows in Windows. Right click on computer and choose properties.
Regards,
G33k
May 11, 2011 | Computers & Internet
How do you fix error code E000590-0001
Solution 1: Clear the Windows Store cache
To start with, you should simply clear the Windows Store cache as doing so is the solution to a wide variety of different Windows Store-related issues and may just be able to get the job done in this case as well. In order to clear the Windows Store cache, you need to:
  1. Press the Windows Logo key + R to launch a Run
  2. Type WSReset.exe into the Run dialog and press Enter.
  3. Restart the computer and, once it to boots up, check to see whether or not the Windows Store is up and functioning again.
Solution 2: Re-register the Windows Store
When it comes to Windows 10 issues involving the Windows Store, it is always a good idea to re-register the Windows Store and see if that fixes the problem. Many Windows 10 users who have been affected by this specific issue have had success with getting rid of it by simply re-registering the Windows Store. In order to use this solution, you need to:
  1. Press the Windows Logo key + X to open the WinX Menu.
  2. In the WinX Menu, locate and click on Command Prompt (Admin) to launch an elevated Command Prompt with administrative privileges.
  3. Type the following into the elevated Command Prompt and press Enter:
PowerShell -ExecutionPolicy Unrestricted -Command "& {$manifest = (Get-AppxPackage Microsoft.WindowsStore).InstallLocation + '\AppxManifest.xml' ; Add-AppxPackage -DisableDevelopmentMode -Register $manifest}
  1. Once the command has been fully executed, close the elevated Command Prompt.
  2. Restart the computer and wait for it to boot up. When the computer boots up, try launching the Windows Store and see whether or not it successfully loads up.
Solution 3: Rename the Software Distribution folder
Located in the root folder of your computer's HDD/SSD is a folder named Software Distribution, and there is a pretty decent chance that you'll be able to fix this issue by simply renaming this folder, like many affected users before you have, and forcing Windows to automatically create a new one. In order to do so, you need to:
  3. One by one, type the following commands into the elevated Command Prompt and press Enter after typing in each one:
net stop wuauserv
net stop cryptSvc
net stop bits
net stop msiserver
  1. Type the following command into the elevated Command Prompt and press Enter:
ren X:\Windows\SoftwareDistribution SoftwareDistribution.old Note: Replace the X in this command with the letter corresponding to the partition of your computer's HDD/SSD that Windows is installed on. Usually, it is C:\
  1. One by one, type the following commands into the elevated Command Prompt and press Enter after typing in each one:
net start wuauserv
net start cryptSvc
net start bits
net start msiserver
  1. Type exit into the elevated Command Prompt and press Enter to close it.
  2. Restart the computer.
  3. Wait for the computer to boot up.
  4. When the computer boots up, check to see whether or not the problem has been resolved.
Solution 4: Enable TLS
If none of the solutions listed and described above have worked for you, you may be suffering from this issue because TLS is disabled on your computer. If that's the case, simply enabling TLS will get the job done and resolve this problem. In order to enable TLS on a Windows 10 computer, you need to:
  1. Open the Start Menu.
  2. Click on Settings.
  3. Click on Network & Internet.
  4. Click on Wi-Fi in the left pane and, in the right pane, scroll down and click on Internet Options.
  5. Navigate to the Advanced
  6. Under Settings, scroll down to the Security
  7. Make sure that there is a check mark next to the Use TLS 1.2 option, meaning that the option is enabled.
  8. Click on Apply and then on OK.
  9. Restart your computer. Once the computer boots up, try launching the Windows Store and see if it loads up successfully.
Solution 5: Disable Proxy
Having a proxy enabled can prevent you from accessing the Windows 10 Store.
  1. Press the Windows + R keys to open the command prompt, type inetcpl.cpl and then click OK. This will open the Internet Properties settings.
  2. Go to the Connections tab and click on LAN Settings.
  3. Check the box next to Automatically Detect Settings and uncheck the box under Proxy Server.
  4. Click OK and try to open the Windows 10 Store.
Alternatively, you can follow these steps.
  1. Open an elevated command prompt by pressing the Start button, typing cmd and then opening as a administrator.
  2. In the elevated command prompt type the following command:
    netsh winhttp reset proxy
This will reset the proxy settings and give you a direct internet access.
  1. Try to browse the Windows 10 store and verify if the issue will persists.
Regards.
Microsoft Live Support 24 7 Online Professional Support Chat
Mar 16, 2011 | Office Equipment & Supplies
The automatic update for windows has found several patches to install,however i cannot get them to install. how important is it to continue installing these patches.
http://www.filehippo.com/download_ccleaner/ download the latest version and run it to clean all unwanted files and junk in your computer...
And then follow the step's below:
Method 1
Download and install Windows Installer 3.1 and reboot.
Method 2
If that doesn’t work then you can try to stop the Automatic Update service and clear out the previously downloaded files and cache.
Open the Services console by clicking on Start, Run and typing in services.msc and clicking Ok. Stop the Automatic Update service by right clicking on it and choosing Stop.
Open My Computer or Windows Explorer and make sure that hidden files and folders are shown.
Navigate to WINDOWS\SoftwareDistribution\Download and delete all the files within this folder. Then navigate to WINDOWS\SoftwareDistribution\EventCache and delete all the files in there as well.
In the Services console, start the Automatic Update service by right clicking on it and choosing Start. You may also want to check its properties and make sure it is set to Automatic for startup type.
Download the latest version of the Windows Update Agent and save it to your desktop.
Close your web browser and any other open programs and double click the WindowsUpdateAgent30-x86.exe file to run it.
If you get a message saying that the Update Agent is already installed, then click on Start, Run and then click the Browse button and navigate to where WindowsUpdateAgent30-x86.exe was saved on your desktop and click on it one time. Click on the Open button and in the Open line, click once on WindowsUpdateAgent30-x86.exe file so its highlighted. Click after the last quotation mark in the line and enter /wuforce after the last quotation mark so it looks something like "C:\Documents and Settings\username\Desktop\WindowsUpdateAgent30-x86.exe" /wuforce. Click Ok to install the Windows Update Agent
Close all open programs and install the update.
Restart your computer and try downloading and installing Windows updates again. If your computer already has some updates that were downloaded during the time you were performing the above steps, cancel them and download them again from scratch.
Jul 13, 2010 | Microsoft Windows XP Professional
UNABLE TO CLEAR DATA IN PRINTER. COLD START DIDINT FIX
for windows xp.
click on start then click on run in open box type cmd and hit ok. it will open command prompt. type following commands:
net stop spooler then hit enter
net start spooler then hit enter
repeat same step for 3 4 times. then restart computer.
Dec 16, 2009 | HP LaserJet 4350 Printer
WHEN I TURN MY COMPUTER ON I GET AN ERROR MESSAGE - HOW CAN I STO
Please click on Start, Click on Run and type the following in the open box and click OK
msconfig
Vista: In the Start Search field, type msconfig , and press Enter . The System Configuration window opens.
Or
Press and hold Windows logo key on keyboard and press R. It will open Run Window. Type the following in the open box and click OK
MSconfig
Please click on Startup tab
Remove the check mark from entries related to Mywebsearch OR M3PLUGIN.DLL
Then click on Apply, Close and Please click on Exit without restart.
When the system restarts, you will see a message about System Configuration Utility. Click in the box for “Do not Show this message” and then click on OK.
It may work!
REGARDS
RAHUL
Feb 22, 2009 | Microsoft Windows Vista Ultimate Edition
Window Update Problem
Follow the steps below to solve this annoying problem when the Windows XP updates will download but won't install.
Make sure Windows installer 3.1 is installed correctly
Click on the following link to visit the Microsoft Download Center and download Windows installer 3.1
Download Windows Installer 3.1
Reboot the computer and try to download Windows Updates, if they still fail to install, continue with the next step.
Stop the Automatic Update Service
Click on Start, Run
Type the following command and press Enter
services.msc
Right-click on the Automatic Updates option in the Name column and click Stop
Close the Services window
Show Hidden Files and Folders
Open My Computer
Click on Tools, Folder Options
Click on the View tab
Under the Hidden Files and Folders section, select "Show Hidden Files and Folders"
Click Ok
Delete the Previously Downloaded Windows Updates
Open My Computer
Double-click on Drive C (or whatever drive Windows is installed on)
Double-click on the Windows folder
Double-click on the SoftwareDistribution folder
Double-click on the Download folder
Click on Edit on the menu bar
Click on Select All
Click on File on the menu bar
Click on Delete and delete everything in the download folder
Return to the SoftwareDistribution folder by clicking on the green up arrow on the toolbar
Double-click on the EventCache folder
Click on Select All
Click on Delect and delete everything in the eventcache folder
Restart the Automatic Updates Service
Click on Start, Run
services.msc
Double-click on the Automatic Updates option in the Name column
Click on the Start button under Service Status to restart the service
Select Automatic under Startup Type to start the service each time Windows starts
Click Ok
Close the Services Window
Download the Latest Version of Windows Update Agent
Click on the following link to download the latest version of the Windows Update Agent and save it to your desktop.
Oct 18, 2008 | Televison & Video
Slow system
Follow the following Steps and you can get rid of the Slow System Problem:
1) Left Click on Start, then click on Run and type "temp" in the open box and click on ok .
2) Delete all the files from the "temp" folder and close the window.
3) Left Click on Start, then click on Run and type "%temp%" in the open box and click on ok .
4) Delete all the files from the "%temp%" folder and close the window.
5) Left Click on Start, then click on Run and type "Prefetch" in the open box and click on ok .
6) Delete all the files from the "Prefetch" folder and close the window.
7) Restart the computer.
Aug 11, 2008 | Acer Aspire 5500 5570-2609 Laptop
HP Pavilion dv4000 Notebook Logo
130 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
