Question about Dell W4200 42 in. HD-Ready Plasma Television
DEll 42" plasma TV. The
DEll 42" plasma TV. The Problem is a thin black line appears on the screen, usually a few minutes after turning on. The line appears on all inputs.
  • 3 more comments
  • eeloftus Feb 11, 2008
    I have also disconnected & reconnected all input cables.
  • eeloftus Feb 12, 2008
    I ran the white wash feature for 2 hours w/ no success. The line appears with all inputs disconnected as well. Thanks for your reply to my problem.
    Thanks for your reply to my problem. I have moved the input leads around w/ no success. I did notice the line was still there with all inputs disconnected. The TV is is plugged in to a top of the line surge protector along w/ 3 other components. I will try plugging into a different circuit. I also was informed that crossing power chords over input cables can cause interference.
    The model # is W4200
  • eeloftus Feb 25, 2008
    Thanks for your help. TV is out of warranty & Dells only help was send the TV to San Francisco where they would perform diagnostics and then contact me w/ a repair estimate and for permission to repair the TV.
    Thanks again.
    Earl
    Thanks for your help. I tried your suggestion but i could not figure out how to unplug the cables. It looked complicated & sensitive.
    Thanks,
    Earl
    Brigadier General:
  • 3,614 Answers
Hi Sir,
Asking for some info. and testing you just have done.
Thanks
Posted on Feb 20, 2008
    Scholar:
  • 110 Answers
Hiya eeloftus!
The black line in your plasma display is a well-known defect of some panels. Your best bet here is to pass the buck to Dell and make them replace it. You can check your warranty status here
Once you've entered your tag and checked your status there, the site should lead you through the return process. If that doesn't work well for you, call Dell directly at 1-877-671-3355.
  • 372 Answers
Hi.
If this line is completly black chances are one of the ribbon cables that connect to the plasma display is tarnished.
You will need to remove the back of tv set & you will see 6 to 8 2inch wide ribbon cables going to rear of screen carefully unplug them from the PCB do not attempt to pull them from the actual plasma screen. clean them with an erazer & isopropyl alcohol plug them back in & test.
http://dysonmanuals.llc.nu/
Chris..
  • 549 Answers
Have you tried to change out the input leads and use high quality ones?
Sometimes interference can do this.
Try moving around the leads to the tv from your various components and antenna inputs.
Also, try disconnecting inputs and use one at a time.
Grounding antennas and input devices properly make a large difference.
Some tv manufacturers recommend not plugging the tv in ;the same outlet circuit as the components attached to it.
If this does not change anything, write back.
Also, is the model number of the tv in your original post accurate or is there a typo?
Posted on Feb 11, 2008
  • Hjalmer Lamminen
    Hjalmer Lamminen Feb 12, 2008
    I helped my wife's parents with a problem they had with lightning strikes. The lightning did not effect the tv, because it was on the other end of their house, but the computer got zapped.
    They had the best power strip they could find and lightning got it anyway.
    I then changed the receptacle that the computer was plugged into to a GFCI, because it is quicker to trip from a lighning strike than the power strip is(they use both power strip and GFCI).
    A power strip is rated in joules and a GFCI is rated in miliamps, and is designed to trip if someone is about to get a shock with moisture situations. A power strip has poor timing because the lighning flash is out of earth and back down to earth when it strikes and actually makes a cycle. The ground rod actually prevents the lightning from from going up and into equipment and when it is on that cycle is when the GFCI trips as opposed to the power strip which sometimes does not trip until the downcycle.
    I wish manufacturers would put a GFCI in the power strip with the other electronic components.
    I have found that when plugged into a GFCI outlet, that the phone line that is plugged into the power strip is also protected and modems also servive a strike.
    As for grounding an antenna, the best way is to ground to a copper or other metal water pipe or drive an 8 foot ground rod into the ground as close to the antenna as you can.
    Also, if you have metal water pipes, they should be grounded to the same rod as the electrical panel and as close to the point of entry into the house a practical.
    Another error is that the metal service entrance panel needs to be bonded to the same wire that goes to the ground rod.
    You are suppose to ground the pipe/mounting bracket of the antenna.
    Do not put a grounding rod within six feet of the other rod(s) on your property, as this will make a circuit through the earth from one rod to the other.
    If an antenna and the devices hooked to your tv are not grounded, there is a great possbility for static to acumulate and eventually can cause a multitude of problems for tv and components(this hint is in most if not all users manuals for tv's and components).
    I have attended electrical refresher courses in order to keep my electrical license and have found that grounding is the number one most important issue and is studied more than anything else.
    Large commercial and industrial installations have had major problems with improper or no grounding.
    Nicoli Tesla studied direct current and experimented with lightning and how to harness it, and he was a pioneer in direct current systems.
    There are many websites about him on the net.
  • Hjalmer Lamminen
    Hjalmer Lamminen Feb 26, 2008
    The best way to ground anything is to go to the closest grounding source.
    If you live in an apartment, the lanlord may not appreciate someone driving a ground rod on his property.
    At the hardware store, you can get an eight foot by 1/2" diameter copper ground rod.
    Another way that ham radio operators do it is to burry a wire mesh a few inches under the surface of the ground and about 6 to 12 feet square.
    The way to do it inside of a house/apartment would be to run a wire about a number 14 or possible flat braided wire under a carpet or inside some molding or whatever way it will not be seen, over to a known grounded sink water or drain pipe that goes to the pipe where your water meter is or to your water well, if you live in the country. Dish installer grounding information is in most new tv owners manuals etc.
    You can go as far as grounding the chassis of all your components(at the back of them on a cover screw) that are at your entertainment center.
    Scholar:
  • 119 Answers
If you remember well and know about the trinitron tubes,they have a orizontal or vertical line,thin,crossing on the screen.It is a distinctive line.Dell may be the same.
    Master:
    Sergeant:
  • 440 Answers
Do u have any wash out fetures in tv menu all white light this will stop that lite glitch i have samsung had same isse in my menus we have wash out feture that throw brite white light on screen that helps get glitch out ok cheak menus for screen burn in protection ok adjust it thx nick
  • 2 more comments
  • nick helpap
    nick helpap Feb 11, 2008
    no this not normal and not good so look for wahs out fetures if none gotta take this in get it tweaked back if its under wanrety if not update the main firmware on a thumb drive if its usb ready if not programer man will do it for u ok
  • nick helpap
    hey ace thats not a sotion ok
  • nick helpap
    hey yalmer how to u ground the antenna ? we have indoor one too that glitch came up white wash stoped it bbut ya antenna notgrounded how do u do so on indoor antenna
  • nick helpap
    i also use static cores around cables that come with tv on main power and use monster power strips with clean power them def help
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Hi, I've purchased a 2nd hand LG 42" Plasma TV set
Usually black lines in a flat panel indicate an error or problem in the video board. A service professional can hook up to the tv and better diagnose the issue.
Mar 23, 2011 | LG Televison & Video
About 2 weeks ago my dell 42" plasma started
change your tv main board, your tv board was broken
Jan 16, 2011 | Dell W4200 42 in. HD-Ready Plasma...
Sony ke42m1 plasma 1-1/2 black line down the middle vertically of the screen pic is otherwise clear started as a thin green line down the middle which would go away after a minute or so than the black...
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Jul 31, 2010 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
A horizontal thin black line has appeared across screen.
Jan 27, 2010 | JVC PD-42V475 42 in. HD-Ready Plasma...
Colored wavy lines on screen
This is a Logic board problem, not so easy to replace in Hitachi but well worth the repair if I had your zip code I could recommend a person or three. But the problem is a problem in the logic board and will beed replacement, Thanks for using Fixya.com
May 14, 2009 | Hitachi P42H401 42 in. Plasma HDTV
Black vertical lines is there a fix My problem is with a hoizontal thin black line on my Dell 42" Plasma TV. Any suggestions for a fix? I had tried turning off and disconnecting from cable for awhile,...
I have the same problem. My repair shop says I need a new plasma screen. Dell says replacement screens are unavailable. I now have a 42" paperweight.
Jul 22, 2008 | Dell W4201C 42 in. Plasma HDTV
Help
the problem can be traced from the power bd. you will need a digital volt meter. There are settings located on a sticker located on the upper right corner Va,Vset,Ve, Vset etc..... each one has a DC voltage. compare the voltages to trace the source. My suggestion from experience is the Y Main upper or lower buffer which ever has a brn mark located on the metal of the panel. Google a local dell dealorship or a repair company in ur local area, and get serviced.
Jul 12, 2008 | Dell W4201C 42 in. Plasma HDTV
Dell w4201c hdtv plasma tv BLACK SCREEN, LOGO FADES OUT, SOUND REMIANS, HELPPPPPPP
the problem was the y-sus board, i had a local tv repair shop diagnos that much for me. although, he couldn't fix it i did some research and found a company in california, itritek.com, who could. you send him the y-sus board and the two buffer boards and he not only repairs them but he upgrades them. apparently the y-sus board gets too much heat and eventually goes out, sometimes the buffer boards are affected too. itritek.com replaces the components on the y-sus board with better parts which are more heat resistent. i believe this will help you with your problem. let me know...good luck.
Dell W4200 42 in. HD-Ready Plasma Television Logo
202 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
