Vcr doesnt want to turn casettes
Panasonic vcr doesnt play, record, ff etc.
Something might be tight inside???
  • Wouter Basson Feb 13, 2008
    It does this with all tapes, thanks i will have a look at the idler
  • 48 Answers
It does sound like a bad idler indeed. You did not inculde the model number so I can't tell you if this VCR uses a tire idler or a gear. If you're handy you can probably change it yourself. I have tons of VCR parts left over and if you have the model number I can tell you if I have the idler.
Posted on Feb 12, 2008
  • 579 Answers
Most likely, the idler wheel is slipping too much. That is the device right under the middle of the cassette that flops back and forth depending on which direction the winding is to go. If it is the type with a little rubber belt on it then that needs to be replaced or if it is a clutch type, either replace the clutch or many times I put a drop of something viscous in the clutch to tighten it up.
This is the most common type of VCR problem and usually happens after about 5 years.
Could also be a broken capstan belt. Take the mech out an look underneath.
Hope Ya Fix It.
  • 537 Answers
Is it all tapes or a particular tape? The tape might have kinks in it or have too much tension.
Look at the following link for more information:
http://books.google.com/books?id=YiDraJn7wwQC&pg=PA19&lpg=PA19&dq=vcr+tension+too+much&source=web&ots=PrmTGvSu2D&sig=9YQYnKf3a75Pm7Nv5kxkuRCkZP0
Mike
F03 DISPLAY ON MY NV-SD300 PANASONIC
go to panasonic.com/vcr and give them the model/serial # and ask what the F03 error code means and they can give you a solution for the problem.
Jerry
Aug 27, 2012 | Panasonic Televison & Video
No response when i press play
hi
reset your camin its default condition.
change your battery.
scan your memory card and cam memory with antivirus.
connect it to pc.
Mar 23, 2008 | Panasonic Palmcorder PV-DV103 Mini DV...
GE VG4270 vcr power turns off quickly when recording or playing a tape
Have someone look inside---if tape is not loading all the way against the video heads or tape does not move in play-rewind-FF then there is a problem with the transport mechanism which is what performs these functions.
May 13, 2012 | GE VG4270 VHS VCR
Put in tape and vcr fast forwards
something maybe broken on the inside for it to say play but fast forward. the botton could be stuck as well. maybe open the vcr and clean it all up in side. that might help
May 11, 2012 | Panasonic Pv-9661 Omnivision 4-head Hi-fi...
My vhs c adaptor wont play my casette. It plays for two seconds then the power to the vcr turns off. Yes I have tried several vcrs
This is because something is jamming either in the adaptor mechanism (nightmare devices at best!) or in the tape cassette.
If you can afford to, escape from this dinosaur technology and enjoy a digital camcorder with a hard drive and/or recording on cards.
No moving parts! No tape tangles, jams or breaks! HD quality!
Well worth considering.
Sep 21, 2011 | Panasonic PV-P1 VHS-C CASSETTE ADAPTOR
How to takeout the stuckup video casette form sony vcr and repairing the auto casette take-in take-out system
remove the vcr´s cover and manually turn the motor´s pulley that charge the cassette, if you do not know which is the motor, put atention which motor is turning while you plug the vcr at outlet. Do not forget give points.
Apr 17, 2010 | Sony RDR-VX525 DVD Recorder/VCR
Can't record from camcorder to VHS tape on LG Model VCR
ok,uve gone OUT of cam and IN to VCR player?,then press play on cam and record on VCR,u should see whats recording as long as your on your normal video channel
Aug 17, 2009 | LG V181 DVD Player/VCR
DVD Recorder VCR combo, VCR will stop after 23 sec of play or rec
necesito saber que tecla presiono para desactivar el modo progresivo scan
Feb 14, 2009 | Philips Magnavox DVD/VCR Dual Player
Re: Model PV-4523S
You can try cleaning it with a VCR tape cleaner to see if the pinch roller have build up on there. It could be that the motor isnt feeding the tape up against the recording heads properly and may need an adjustment. If you can take the top cover off, you should be to see what the problem is by the way the tape is being inserted into the machine.
Jul 29, 2008 | Panasonic PV-V4021 S-VHS VCR
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
