Question about Jensen CD4610 CD Player
Car stereo Jensen car stereo volume goes down after playing a while
  • Wouter Basson Feb 13, 2008
    The volume actually goes down while driving, when you stop and return to the car later the volume almost blows you out of the car.
    No amp fitted
  • 52 Answers
If u got an amplifier, make sure u replace the fuse with a higher amp fuse, If the face for the detatchable deck got some kinda liquid, use compressed air to clean it a little bit, make sure alternator is charging and if ur car is not running then make it run to keep the battery chargin, :)
Posted on Feb 11, 2008
Start up volume way too loud! The answer here is to push in volume button to set..my volume button when pushed in sets mute and on/ off
Annoying issue but honestly, I have no idea how to operate your "Jensen VX7020 6 2 Inch MultiMedia Bluetooth" but logic says you should read instructions. Read these instructions
http://www.jensenmobile.com/docs/common/VX7020/VX7020_IM.pdf
Watch these videoos, maybe get some hint
Jensen VX7020 6 2 Inch TFT Car Stereo 2 0 DIN MultiMedia Receiver with...
Jensen VX7020 6 2 Inch TFT Car Stereo 2 0 DIN MultiMedia Receiver Review
also some info at this website. Check it:
vx7020 manual
Feb 19, 2015 | Jensen VX7020 6 2 Inch MultiMedia...
I have a JENSEN CD311X car stereo!
IF THIS PROBLEM HAPPENS TO ALL CDS PLAYED, COULD BE THE OPTICALS LENS IS DIRTY, TRY TO CLEAN IT, OR IF ORGINAL CD CAN BE PLAYED THEN THE OPTICAL LENS ARE NOT PROGRAMMED TO READ THE COPIED ONES
Oct 13, 2009 | Car Audio & Video
Jensen vm9413 no audio ouput
i thought my banswer went through but i guess not so i'll do so again.Often a defective speaker can cause this problem.So before you decide to replace the unit or repair it,when this happens again disconnect one speaker at a time and see if it doesn't come back on after connecting a specific speaker and goes off if you reconnect it.If it does you've found your problem.But sometimes a speaker doesn't melfunction until put under a strain.So you can also check by seeing if it shuts down at higher volumes and plays longer at low volumes which will tell you also that it is an external not internal propblem.Let me know what happens after the speaker test
Oct 11, 2009 | Jensen Car Audio & Video
FM Reception with Jensen MSR3007
I have the exact same problem with the exact same stereo. I started by removing the in-line AM/FM/VHF Separator and connecting the antenna directly to the stereo. The static/popping/fade-out continued. Today I swapped to a new antenna, but it did not help. I swapped back to the original antenna and for a brief while, I had good reception. The I went to coil the excess antenna cable and the static/popping/fade-out resumed. I have narrowed it down to either the antenna connector coming out of the back of the stereo or an internal circuit. Either way, it does not look like a do-it-yourself fix.
May 31, 2009 | Jensen CD400M CD Player
Jensen vm9412 and ipod classic
The newer generation iPods don't always work with the iPod connection kits in a lot of the car stereos. Some of the problem is due to the fact that the new generation iPods have been changed and the stereos were manufactured before the players were released so they are not compatible.
I bought my girlfriend a Pioneer car stereo with an iPod control cable, and it works fine with her Nano (not the new generation Nano) and it works with my iPod Photo 60 GB but it does not work with my iPhone 2G and I read that it is not compatible with the new Nanos or the Classics. Check with Jensen to see if the model you have is compatible with the Classic and see if there is a solution to the issue. It may not be compatible with the new video portion of the Classic firmware.
Cheers
Aug 20, 2008 | Jensen VM9510 Car DVD Player
Jensen volume
turn the volume level to what you want, when you still see the yellow level on the screen, press and hold the volume button till you hear two fast beeps, this will be the level you deck will start of at every time you turn it on
Jul 24, 2008 | Jensen VM9510 Car DVD Player
Jensen 9412
how can I restar a stereo car jensen vm9412
May 29, 2008 | Jensen VM9510 Car DVD Player
Volume resets to 26 every time unit powers on
Jensen Units donot remember your previous setting, its just one of the many reasons not to get one
Mar 27, 2007 | Jensen VM9020TS Car DVD Player
Jensen CD4610 CD Player Logo
75 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
