Question about Refrigerators
Refrigerator Buzzing Ge Side by Side frig. Will not dispense ice, frozen water on my food items, and now the buzzing noise is continous I can't sleep! Can you tell me how to stop the noise?
  • Fresa Feb 12, 2008
    thanks I came home today and the noise was gone, I did shut off the icemaker last night and I did forget to call GE
  • 958 Answers
If my guess is correct, that buzzing sound could be coming from the evaporator fan touching the ice that builds up in the evaporator. if that is true, a quick remedy for the noise to disappear is to thaw the ice, unplugged it for a while but as ice builds up again, then the noise would come back. the original problem would be the defrost cycle not functioning well. will be in touch if my guess is correct. thanxs,
Posted on Feb 11, 2008
GE Side-by-Side Refrigerator GSE25GGHBCWW has a buzzing noise if any food touches the plastic shield over the fan in the freezer section.
Try taking off the fan cover and see if the blade has slid too far forward on the motor shaft. If that's the case just push it back a bit to give it more clearance( do this with the fridge unplugged)).. It could also be ice buildup which is then hit by the blade at the slightest pressure..
Jul 12, 2017 | GE Refrigerators
Water dispenser not working GE model GSH25JSX13
Do you hear a slight buzzing when you try to get water?? If yes, you may have a frozen water line inside the freezer door. GE had some problems with those models. They offer a heater kit that has to be installed in the dispenser area of the freezer door. Once installed, in about a day the water line should be defrosted enough to dispense water again. If you don't hear that buzzing sound when trying to get water, you could have a bad inlet valve which is at the lower back of the refrigerator where your house water line hook to the refrigerator.
Mar 04, 2015 | GE Refrigerators
GE GSL25IGXB LS refrigerator. No water from front dispenser.Ice making works. Filter is good. Any suggestions?
Temp set at 5(as always) but food in the refrigerator is freeezing. Ice maker and water distpenser do now work. just started happening.
Try unclogging the drain line for the freezer. What seems to be happening is your refrigerator is working too hard to keep the temperature that it reads inaccuately. Usually a light defrost will do the trick , sometimes a longer defrost or one using warmers...don't be too tempted to use anything like a hair dryer for safety reasons.
Make sure you keep your frig door closed and use the frozen food in the frig to hold temps down.
Good luck.
Mar 28, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
My water dispenser is not dispensing water, but I can hear it. Where is the water?
If that model listed above your post is correct then you may be hearing the water control valve buzzing and trying to open. If the ice maker works then the water supply is OK, but if the dispenser will not fill the glass the we need to have a look at the dual control valve on rear of refrigerator near floor and where household water enters your refrigerator. If your model is the PSS26MSRSS Profile/Artica the water control valve part number is=> WR57X10032 and unless it is frozen in the water reservoir inside fresh food compartment you mot likely hear it trying to open.It may need to be replaced. Thanks, Sea Breeze
Feb 11, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE - SIDE BY SIDE MODEL TFX25JR - Continous HUM
Probably the condenser fan motor is going out they will often make noise for a long time before anyone notices. Get it looked at soon. overheating the compressor on that old of a fridge could spell trouble.
Sep 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile is Buzzing
Checx the wire connection and the way u food is inside ur frig. Maybe something is not at the right place!
Sep 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a maytag side by side frig. Today I walked
Below is 2 links you can click to view the fountain. Thanks, Sea Breeze I believe that your board ot the water solenoid is defective.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5171257
http://servicepartstec.blogspot.com/ Enter model number on this link, they also offer free assistance. Model number MSD2735GRS
Apr 30, 2009 | Maytag MSD2736GR Side by Side Refrigerator
No water but ice is fine
turn freezer side to zero for 1 minute press water dispenser
Mar 29, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
Buzzing sound from interior light bulbs
sounds like you have an issue withthe electronic control board locates behind refrig next to the compresssor, in a white housing
Dec 30, 2008 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
522 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
