Question about Brother DCP-110C All-In-One InkJet Printer
Printer unable to scan message
Hi my printer has a message saying it's unable to scan and to refer to trouble shooting manual that I have lost.... can you please help?
  • Brother Master
  • 1,113 Answers
Try this for me, turn it off and hold down the menu key, then turn it on while you hold it down for 10 secs, let it go is there a number in display? if not then we will go the tradational way...
This works...press menu black start and up 4 times quickly, does "maintenence" display. if so arrow the numbers to 8 set 2 set, error code should show. post it
Posted on Feb 11, 2008
Refer to device documentation to trouble shoot
you need to set up your scan to option.
this can be done from the hp software
open solution center click settings then scan settings
from there select scan to set up
a window will open and then click on front panel destination list
once again a window will open with a double pane on the left side is your short cut options click on them one at a time click add then once satisfied with options click update the device or ok
if it fails to update reset the printer and try those steps again, or re install just the drivers
if the same message appears then check the settings on your firewall
Mar 22, 2010 | HP Officejet 6310 All-In-One InkJet...
No scan options say refer to device documention to trouble shoot
Try ths:
This happens mainly when you try to scan from the printer ;
Always try to scan from HP solution center but still here is the resolution:
Open Hp Solution center
Click on Settings
Click on scn settings
click on Scan to Setup
Select all the option available to updrade the Front panel menu list and click on ADD
Click on Update;
Restart the computer and the printer and try to scan.
It should resolve the issue.
Regards Soumajit
Mar 02, 2009 | HP Officejet 4315 All-in-One Printer
Need to scan - unable to on my HP officejet 5610xi All-in-One
open control panel -> go to scanners and cameras -> start the hp officejet 5610xi -> then it should start enjoi :)
Jan 20, 2009 | HP Officejet 5610 All-In-One InkJet...
HP C6180 ''Unable to scan, copy or send a fax''
Check the following steps:
Connect the printer directly to the wall outlet and
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold # and 6 while plugging in the power cord
Try to check the result.
Regards,
Sagarjd
Nov 20, 2008 | HP Photosmart C6180 All-In-One InkJet...
Can't scan on the HP OfficejetJ4580
Uninstall everything that has to do with your old HP printer, drivers, photo processing, etc. Reinstall software with J4580 printer. That should open HP Digital Imaging Monitor where you can set scanning options. Plug printer into the back opf your computer. Plug power supply directly into the wall socket.
Nov 12, 2008 | HP OfficeJet J4580 All-In-One Laser...
My hp officejet 4300 and vista
Assuming the message you receive says "No Scan Options", HP has a Vista related solution on the following page:
No Scan Options
Sep 22, 2008 | HP Officejet 5610 All-In-One InkJet...
Manual
My printes is saying that it is unable to print . It is asking me to see trouble shooting and routine maintenance chapter.
Feb 11, 2008 | Office Equipment & Supplies
Scanning
go here
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00503569&cc=us&lc=en&dlc=en&product=441240&dlc=en&lang=en
Dec 17, 2007 | HP Photosmart 2575 All-In-One InkJet...
Brother DCP-110C All-In-One InkJet Printer Logo
53 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
