DVD Drives
Problem for DVD Drives
Generic problem for all DVD Drives
Internal DVD Drive
By LambertL on Feb 11, 2008
I decided to buy this product because I just wanted a really good DVD player, not a burner etc., and this seemed to be the one, but now I don't know if I can install it in my Dell Dimension 4550, because it (the ASUS item) is SATA, and the instructions have no diagrams, and talk about things I don't know about, for example, there is just one slot on the back of the drive, for the ide/sata connector I guess, (and I don't know if this connector is SATA? - and then they say, "Connect one end of the 4-pin audio cable to the audio output connector of the optical drive." - but there is no place for that... - I went to the ASUS site, but I can't find anything there. Please help. Thanks, cheers, L
Best Solution
posted on Feb 24, 2008
Helpful)
Compurepair
Rank: Wiz
Rating: 84%, 786 votes
if you,ve purchased a SATA drive.
Then you should have SATA Connectors On The Motherboard.
If you look carefully you should see SATA1 And SATA2 if applicable. they,ll look like a small black/white piece of plastic connector. shaped similar to a letter *L* this is the sata connector, you may already have a hard-drive on 1 of them. ( red Cable ) The 4 pin audio cable, goes from the rear of your DVD Drive, you should have 2. 1 for analogue 1 for digital. this connects Audio from your Drive to motherboard, slim grey cable ( usually ) look towards the rear of your motherboard for this, usually towards the audio out ( if you have onboard soundcard )
connect this to Audio/sound ( you,ll probably have 3 located close together.
Hope this helps.
Mike @ Compurepair.
Was this helpful?
Yes
No
Popular Solutions for DVD Drives
Questions and Unsolved Problems for DVD Drives
Answer
having problems with dvd on my laptop keeps coming up with unable to connect drive may be corrupt or... (More)
Answer
My notebook DVD drive can't see even under my computer.I can see only harddisk. but DVD drive can... (More)
Answer
Up until just recently, all drives were working fine. Now, there is no E drive being recognized.... (More)
Answer
for some reason now after i convert the disc and it burns from the computer then try to make... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For DVD Drives:
Top DVD Drive Experts
Rank: Guru Guru
Solutions: 14935
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more DVD Drive Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
