Question about Intel Motherboard
MOTHERBOARD DRIVER i have a pentium 3 computer,the problem is my monitor always flicker what would i do? is it because i did not install the motherboard driver?i hve no motherbrd drver bcoz my computer was only gave my sister from japan.
  • 749 Answers
Well it is not the computer that has a problem... It's your monitor, it needs to be checked by a technician to fix those cold solders that causes the flickering on your screen.
Have it repaired then... Fixya me okay..
Posted on Feb 11, 2008
My monitor is flickering
Flickering on the screen can be caused by defective hardware in the computer or by improperly installed software monitor may flicker and goes into rolling state due to dust, overheating after a long continuous usage,loose circuitry or due to some electromagnetic interference with other like tv , UPS, large speaker systems etc.
FIX :
1.Try Re-installing your Video driver
2 If it is possible, connect a different monitor to the computer. If the flickering disappears, it is a fair indication that the monitor is defective, otherwise go to the next step.
3. Set up the computer and the monitor on a different place in your house. If the flickering disappears now, it is most likely an interference caused by something in the original location. Check for devices which can cause interference.
4. If the flickering persists, check the setup of your system. If available in the setup, make sure that the option Monitor Type is configured as Colour Non-Interlaced.
If you don't think any above possible reasons for the rolling or flickering state of your monitor then we recommend you to get your monitor checked by the monitor company at their respective service cente
Sep 01, 2011 | LG Studioworks 700S 17" CRT Monitor
There is no sound driver in my Pentium III procecerr
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 05, 2010 | Intel Pentium 3 , 450 MHz Pentium III...
NOT SHOWS RESOLUTION 1360 by 768 IN 16" WIDE LG LCD MONITOR MY MOTHER BOARD IS GIGABYT INTEL CHIPSET 865, PLS GUIDE US
Hi!
Installing the video card driver can make use of its features of higher resolution support for your LCD monitor.
And also install the driver of your LCD monitor. This enable to use higher resolution that could provide with your computer video card as I have mentioned above.
Hope it helps..
Thank you for reaching Fixya.
Please leave comments for further assistance.
Apr 05, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Got a flickering in my video, installed brand new Video card. No change. Unplugged everything, except monitor (I meam mouse & all). Still flickers Monitor Acer AL2017
I had this problem once. Turned out to be the VGA plug connecting to the computer. Make sure this is inserted at the computer properly. Wiggle the plug and see if that effects the monitor display. If it does, then replace the VGA lead. Also check that your video card is inserted properly and go into the BIOS on your computer and make sure that the onboard Video chip is disabled (if your motherboard has one). If all this doesnt correct the fault, try uninstalling and installing the video driver again. If you are still having problems you may have a faulty video card.
Mar 17, 2010 | Acer AL2017 20" LCD Monitor
I recently purchased and installed the P191W monitor, and now my pictures are stretched. I was told I new to get a new graphics card. What card should I get? Or can I just update the driver? I am running...
Find your monitor's native resolution, in your case it's 1440x900. Go to display settings (usually right-click on desktop and choose properties), go to settings tab and move the resolution slider until it shows 1440x900. Confirm, the screen should flicker for a moment and adjust - and you should be fine.
If there is no 1440x900 resolution available, then installing a monitor .inf file that came on a disk accompanying the monitor might help.
Oct 24, 2009 | Acer AL1916W 19" LCD Monitor
I have pentium computer - D815EEA2 Motherboard P-III, 733 Mhz. CPU Now i purchase viewsonic VA1918WM Monitor and picture is flicking, and only one setting of resolution in 1024 by 768 pixels High (24 Bits)...
The reason you are getting the flickering is because the refresh rate is not set correctly. Click on Start>Control Panel>Display>Settings>Advanced>Monitor. In the middle of the window you will see the refresh rate. It should be set between 60-75. Try setting it between that range and try it a few times until the screen stops flickering.
Thanks for using FixYa. Don't forget to vote on this solution before you log out.
Jan 20, 2009 | Computers & Internet
USB 2.0 driver
Yes you can, and it ea´sy to do if u have a free psi-slot
And drivers can always be found if there isent a driver-cd following whit the item
But, in not sure that you can use the benefit and full speed of an high-speed usb since your motherboard is a litlle bit old and so is the bus-speed on it.
Good luck
Dec 07, 2008 | Intel Pentium 3 , 450 MHz Pentium III...
Lost sound on intel p4 compaq. Need to download driver
This will take you to Intel's download site for the 865GV motherboard. Do not be thrown off by the title on the site, D865GVHZ. These drivers wil work for you.
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=1704&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21
Luck!
Please vote.....
Jan 13, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Monitor Flickering and Sharpness control is disabled
it will probably be the graphics driver you need to update as XP probably loaded generic a graphic driver. The monitor should be ok with a standard driver.
Apr 18, 2007 | ViewSonic VA902B 19" LCD Monitor
Intel Motherboard Logo
217 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
