Question about Gaggia Titanium Espresso Machine
Coffe groungs drawer full of water
I bought a Gaggia titanium coffee maker via EBay, generally I’m happy with the machine but lately and it is getting worse I noticed how the drip tray and especially the Coffee grounds drawer are full of water to the point that they are about to overflow! At the beginning the Coffee grounds drawer had nice pallets of ground coffee in it but now it is just slush. If someone would know a solution it would be greatly appreciated!!!!
Thanks in advance………Jonas
  • Jonas 16 Feb 12, 2008
    Thanks for helping,
    I’m using
    the same amount of coffee (medium amount) as always the brewing unit is cleaned
    regularly including the strainer and
    everything is defiantly put back correctly.
  • shazriders Jun 10, 2008
    I think it is same problem - gaggia titanium about 5 yrs old. There is water in dregs container on the left and ground coffee in drip tray on the right. coffee is weak. Same with beans and preground coffee.
  • 2,039 Answers
When you make ourself a expresso do you have the same amounth of coffee or it mush lower if recently you clean the machine inside check if you screw or put back everything at there right place let me know thanks for using fixya pierre
Posted on Feb 11, 2008
I have the same problem with my Gaggia Titanium. The coffee dispenser tray is filling with water, making it "Coffee slush".
I am thinking it might be the O-rings in the brewunit that needs to be changed ? Any thoughts ?
Posted on Jul 28, 2008
Espresso (small coffee) doesn't work anymore
you have to change the amount of the water on the small coffe button. Press and hold it while is making coffee .When you want to stop -just take off your finger from button.
Aug 22, 2014 | Gaggia Titanium Espresso Machine
Gaggia titanium machine, display says dregdrawer missing, even when I've clicked drawer back in place after cleaning it...
Hi
Either your tab is broken on the back of your dredge drawer or your microswitch has been moved from its correct position. There should be a tab on the back of the dredge drawer. If not you need a new dredge drawer.
Sep 13, 2010 | Gaggia Titanium Espresso Machine
Gaggia Titanium. . coffee not hot even though
Remove the filter holder and brew some water into a small plastic cup and check temp, it could be the thermostat for the coffee temp is damaged.
Apr 29, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
My gaggia titanium keeps coming up with ventilate in the display have cleaned the whole machine out made no difference
You need to push the hot water button on the machine panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
Apr 19, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
The brew unit is not tamping the ground coffe properly.
Give the brew unit a good wash,then lube all the moving parts with food grade grease.
If you are able dismantle the brew unit and wash in warm soapy water,this removes coffee and any old lubricant.
Feb 21, 2010 | Gaggia Titanium Espresso Machine
Will grind the coffee beans but no water passing
Either the grind is too fine or the brew unit is blocked at the screen.
Feb 05, 2010 | Gaggia Titanium Espresso Machine
Gaggia Titanium dumps ground coffe inside unit
Hi
You have 2 knobs in the bean hopper. The small one is set to the most positive. Turn it back 1 click from the plus and that should take care of your problem. When you have a clean brew unit it will make the first coffee but a little coffee is left in the brew unit and when it tries to make the second coffee a full charge and the little that was left cause an over charge, and dumps the coffee without making anything.
Jun 17, 2009 | Gaggia Titanium Espresso Machine
Replacement Part
Check one of the followinfg sellers :
Home Page Seaco,Gaggia,Spidem,UNIC,LaPavoni Espresso machines, parts
Gaggia Espresso Machine Parts
or see here GAGGIA Replacement Parts
You usually need to call the seller to get the price and order the part.
Nov 15, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
298 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
