Question about Logitech Webcam
Camera won't install on computer
I'm trying to load the camera onto an older PC with Windows ME. The software is loaded but when I plug the camera into the USB it either won't recognize the camera or it turns the computer off. I need to get the camera installed to work with skype. Any suggestions? Hullo, i plugged in my new camera for skype but silly me did not action instructions that popped up in the right hand corner. now it shows a light on camera but not reconizing it ...not connecting. ???? Dick smith camera worth a bout $50.00
  • melloyellofb Mar 11, 2008
    i installed the program but it wont recognize the webcam
Please tell me the solution
Posted on Sep 24, 2008
I am running winXP Pro service pk 2 and I am having the same problem.it just doesn't see the webcam.
Posted on Jul 10, 2008
  • 84 Answers
I suggest you change your operating system to windows xp. most web cameras are on winodws xp platform. Im sure you will not have any problems about it.
Posted on Feb 11, 2008
Windows 7 will not reckonize my fuji jx580
If you want to install Fujifilm software then you will need administrator privileges for your computer.
You might want to consider NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Aug 22, 2012 | Fujifilm FinePix JX580 Black 16MP Digital...
I am trying to download photos to my pc. All plugged in the the Device Connected box ins blank. Any ideas - its driving me nuts!
OK, when I use my Kodak Easy share cameras on a fresh computer that hasn't downloaded Kodak pictures before I do the following:
Load Easyshare software onto the machine, and install it.
Then, I connect the camera to the computer.
Then, I open the Easyshare software and it may ask a few questions.
Next, I watch the computer (Windows 7) as it loads the proper driver for my camera.
Finally, I click on transfer pictures and I am set with my pictures.
The pictures should show up in the Start Menu's picture under Kodak Pictures.
You should be done.
Let me know how it works out with the Easyshare software downloaded to the computer before trying to load pictures on to the computer.
Jul 10, 2010 | Kodak EasyShare C633 Digital Camera
Polaroid camera not windows nt compatible
Starting from the start plug in the device and XP will detect and look for new drivers a search for drivers is usually done in the inf directory under windows or winnt directory If a driver is not found the computer pops up a question did a Cd or software come with this device if you install the software the a reboot is usally needed if you do not do a reboot you can try once the drivers have been installed unplug the device and plug it back in again the computer will search for the new drivers that are installed and should set up the device to work If it does not work you will need to get driver for the device that will work with XP I have a scanner than need XP drivers but will work on one of the older computers but not XP
Jan 11, 2009 | ASUS P4XP-X Motherboard
I am trying to load the software from my older scanner onto my gateway computer, that now has Windows XP and the software only uses Windows 98
HI YOU NEED TO RIGHT CLICK ON THE SETUP FILE THEN PROP AND THEN COMPATABILITY THEN CLICK BOX AND CHANGE IT TO 98  THEN APPLY THEN INSTALL IT
Dec 04, 2008 | Computers & Internet
I can't load software
You don't need a driver.
Sep 22, 2008 | Pentax Optio E40 Digital Camera
I have installed the Fujifilm finepix Z10fd software onto my computer. However, when I plug the camera into the computer the pictures do not load onto the computer. How do I resolve this?
is there a import menu in software to open first to import? try to uninstall software and hook camera up generic to usb and power on camera in playback and see if you can import into my pictures first-then import them into fuji program after reinstalling
May 16, 2008 | Fuji Cameras
I need an "activation code" from Corel to complete the installation
Perhaps your camera only comes with a trial or limited edition of the software. Try proceeding without the activation code and/or read through the camera's documentation very carefully.
Feb 28, 2008 | Sanyo Xacti VCP-HD2 Camcorder
Windows Vista installation of drivers.
i jus plugged mah concord eyeQ duo 2000 digital camera into mah usb port and it downloaded the drivers for me without usin mah disc on mah vista...
Feb 08, 2008 | Concord Camera Eye-Q Duo 2000 Digital...
If it turns off the pc then the camera driver is corrupt, try re installing and using a different usb port, as WIN ME was never a good operating system when it came to drivers and .ddl files. If still no luck with install try a windows 2000 driver. Then your next obstacle is getting your cam to work with Skype.
Mar 07, 2007 | Logitech QuickCam Communicate STX Personal...
Logitech Webcam Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
