Question about Dell Dimension 4600 PC Desktop
CD Distortion After Bruning
I have a problem with my cd's after burning songs to them..I take my cd out of my PC and play it on a CD Player. The first 3 to 4 songs are usually clear and sound good..But..all songs after the 3rd or 4th one are distorted, pops and snaps and sounds scratchy..I thought it was my speed I originally had my burning speed at 24X went down to 16X, but still the same thing..Can you please tell me what I can do, If anything, on my own to repair or fix this problem without having to buy a new burner. Thank You for any help you can provide for me.........Joy
    Novelist:
  • 109 Answers
There are various things that can be done here. You'll need to make sure somethings first before we conclude there might be a defective with your burner:
- Music quality: if you burn audio you should always looks for high quality files, In case of MP3: search files with at least 192 kbp/s of bitrate. If there are files with higher bitrate, they are better. Here is a overview of speeds and there quality:
96 kbp/s: FM Quality
128 kbp/s: Low CD Quality
160 kbp/s: Higher CD Quality
192 kbp/s: High CD Quality
220 kbp/s: Better Quality
320 Kbp/s: Studio Quality.
Note that files with a higher bitrate use up more space on your harddisk. For example: 320 kbp/s is usually between 8 and 12 MB's. (Depending on song length).
- Overburn: Do not overburn CD's. If it says it's almost full. Don't force a overburn.
- Disc Media: Make sure your disc are of decent quality. The less known formats/cheap ones are usually not that good.
- Your PC: While burning, don't do too much with the PC. It's best to let it burn and do nothing.
- Speeds: always use only speeds the discs are capable of and preferably less then indicated, For example: disc says 52x, use something link 32x
I hope this helps out. Let me know if these hints worked.
You can always update your burner's firmware but you'll need to tell me something more about it. Like: what model is it, what brand etc.
Have you also checked whether the lens on your CD player is OK?
Greetings,
DarkNeogen
Posted on Feb 11, 2008
Sony CD Walkman D-EJO11
Laser pickup unit fault. Contact any service technician. Gopakumar Gopalan Google
Mar 07, 2014 | Sony Televison & Video
Downoaded i tunes now i cant burn cds
you might have to set the process up again
Burning CDs in iTunes is easy and requires no setup. But if you are an advanced user, you may want to tweak the settings a bit. Here's how you can set CD burning preferences in iTunes:
Open up iTunes on your computer. Click Edit and then select Preferences. Click the Advanced tab. Click the Burning tab within the Advanced tab. Set your preferred speed. From the drop-down menu, choose a burn speed for your CD burner. Choose a format. Audio CDs are for playing in your stereo or CD player. MP3 CDs can hold more songs, but need a special type of CD player to be read. Data CDs are for backing up songs, and can only be read by computers. Choose a gap between songs. By default, iTunes puts a gap of silence between each song. You can change this option from the drop-down menu. Use the Sound Check feature. This option will automatically adjust the volume on your songs so they will be the same volume on the CD. Include the CD text option. This will give the CD the title of the playlist to be displayed by a stereo or CD player that supports CD text. Click OK to save your preferences.
Feb 18, 2013 | Dell Inspiron Zino HD Desktop Computer...
I have burnt a bunch of CD's for my Sony CD player. It holds approximately 400 CD's. It seems that last few songs on the burnt CD's are played with a lot of distortion. They have become progressiveley and...
I've had the same thing happen to me.
Minute variations from one machine (or disc) to the next would explain the different results. As the CD standard allows for error detection, correction and concealment as required, one machine may be exhausting its capabilites while the next is either correcting or concealing the problem inaudibly.
Try this: If your source material is not available for a new burn, COPY one 'bad' CD to a fresh disc CD-R (data disc) on your PC. The data copy process is not in real-time like music burning or listening is, so the PC may be able to retry and correct data errors in the source and write perfect data on the copy. If the PC can't read the data it will fail right away, but it will retry it a few times before giving up..
However, if the brand of media you're using is the problem you might just be making another copy that will degrade with time. No maker is immune to bad media. Sometimes one batch will have a problem while others won't.
Feb 04, 2011 | Audio Players & Recorders
I am trying to burn a cd on my Acer Aspire 5536-5255 using WMP and it isn't working?
In Windows Media Player, click Library and then, in the List pane, click <List Name> List, and then click Burn List, as shown in the following screen shot.
  1. If you need to clear the list before beginning, click Burn List, and then click Clear List.
  2. Drag a folder from the Contents pane or songs from the Details pane to the List pane to create a list of songs to burn.
  3. In the burn list, drag songs up or down to arrange them in the order you want them to appear on the CD.
  4. Insert a blank CD-R or CD-RW disc in the CD drive.
  5. In the List pane, verify that the songs you have selected to burn will all fit on the disc. If necessary, remove songs from the list by right-clicking a song and then clicking Remove from List, as shown in the following screen shot.
It is possible that a song will not fit even if the total time exactly matches the CD length, because the Player inserts two seconds between songs when burning. Click the Start Burn arrow and verify that Audio CD is selected, as shown in the following screen shot.
lick Start Burn.As the CD is burned, you can check its progress in the burn list. Burning a CD will take some time.Notes It is recommended that you do not try to perform any other actions while burning a CD. For example, playback may be affected if you try to play a music CD while burning a CD.
You cannot burn additional files to a CD after burning is completed. If you are using a CD-RW, you can erase the entire CD before using the Player to burn files to the CD again.
Nov 19, 2009 | Acer Aspire 5500 5570-2609 Laptop
CD Player wont play burned CDs
you need to make sure you burn your cd,s in the right format, mp3 i think
Feb 07, 2009 | 2000 Cadillac DeVille
Cd burner wont burn whole cd. It burns 6 out of 18 songs and wont work in cd players. hp pavillion laptop dv2000
Some Cds (or individual songs) are Copyrighted, so they will not burn to new CD.
Make sure you're using CD. W. and not CD. R.W. as the latter will only play in your computer CD player. Where as the former will play in your car or home player.
Apr 26, 2008 | Computers & Internet
A PC generated CD
This vintage player won't play many burned discs because of its original design. Not a problem with its design, just the nature of this beast....accordianman
Dec 14, 2007 | Sony CDP-CX300 CD Player
Playing CD-RW audio CDs on Kenwood DP-J2070
try to play a song from original cds.
maybe you brunt it in mp3 file, or its a different format. try to burn your song to cd-r.
if still, try to use nero to burner..
if it wont play your original cds and burnt cds,then the optical lens or the board is broken.
hope I helped you.
Dec 06, 2007 | Kenwood DP-J2070 CD Player
Burned CDs don't play properly
if it won't play right when you put it in the cd player....it may be that the burning system that you're using is off and needs to be updated or trashed for a new one...got that?
Oct 22, 2006 | Ricoh (RW7083A) CD-RW Burner
Dell Dimension 4600 PC Desktop Logo
75 people viewed this question
Alun Cox
