Question about Clarion DXZ655MP CD Player
Its allgood how do u set the time where can i get a manual from
  • fordzgt05 Feb 11, 2008
    sorry man ts a clarion dxz758mc
  • 82 Answers
Http://clarion.com/us/en/MungoBlobs/779/346/DXZ665MP-ENG.pdf
here is the manual to your radio please leave rating
Posted on Feb 11, 2008
2005 chevy uplander. The brake lights, turn signals, psd(both), pwr seats will not work. The psd alarm stays on while driving, heated seat lights turns on/off every 30_40 secs, built in compressor runs...
TURN KEY ON , REMOVE FUSES ONE AT A TIME ,TILL PROBLEM STOPS ,CHECK COMPODENTS , DIS CONNECT WIRES ONE AT TIME TIL PROBLEM STOPS,REPLACE DEFECTIVE PART OR RELAY
Jan 22, 2015 | Seat Cars & Trucks
Fuse controls dashboard lights
Not to sound obvious, but did you check the brightness adjustment dial? If working on other things, might have spun it all the way "off".
Dec 04, 2013 | Nissan Cars & Trucks
Electric window will go down but not up
Try starting the car and after it is running, try turning the key back to the accessory position very slightly (be careful not to shut off engine) if your power is restored to the windows and audio, then your ignition switch is bad or weak. If you have a lot of keys on your key ring this will cause this problem.
Nov 15, 2013 | Mercury Mountaineer Cars & Trucks
01 a6, cyl 1 2 3 show misfire on obd2 scan above idle,plugs wires coil injectors fuelfilter o2sensors allgood
What is the code you are getting? Have you checked the engines compression and all cylinders are in good shape? Do that test and get back to me.
Jun 16, 2012 | 2001 Audi A6
Port getting flaps
sounds like some sort of keep-alive problem.
Try using
switch(config)# debug snmp packets
this will show you what is causing the line protocol to drop. you need to be connected to the console to see the output for this and turn it off when your done.
un debug all
good luck.
Jun 06, 2012 | Cisco Catalyst 4948
I have an ACURITE 00590A1-RX. My time is off by 10 minutes. i don't have my manual and would like to know how to reset it. If possible, tell me how to download a manual.
From the manual, such as it is:
Set the Time Manually:
If you want to set your alarm clock a little ahead or if the unit ever loses time for any reason, the time can be set manually by following these steps.
1) Press and hold the "CH./SET" button for seven seconds to begin the manual time set mode. (2 BEEPS) The hour will flash on and off.
2) Adjust each setting by pressing the "+" or "-" buttons. Confirm and move on to the next setting by pressing the "CH./SET" button.
MANUAL TIME ADJUST SEQUENCE: hour, minute, year, month, date
This works for me. You have to be sure to keep pressing the CH/SET button for the full seven seconds -- the first beep the the clock gives you will only allow you to set the time zone and DST function.
Aug 25, 2011 | Acu-Rite AcuRite 00592A2 Wireless Humidity...
HOW DO i SET THE WOODS 59203 TIMER LOST DIRECTIONS
Woods timers and manuals:
http://waterheatertimer.org/Woods-timers-and-manuals.html
The picture shown at fixya for 59203 is not correct.
Picture shows 49112 which is also TD1000:
Manual for 49112-TD1000:
http://waterheatertimer.org/pdf/Noma-TD1000.pdf
Manual for 59203:
http://waterheatertimer.org/pdf/Woods-59203.pdf
Manual shows 15 steps.
Plug timer in to charge battery. If battery will not charge, then timer is bad.
Set current time.
Set program1 ON time.
Set program1 OFF time
Set program2 ON time
Set program2 OFF time up to 20 pairs of ON-OFF times.
When programming is complete, press ON/OFF/Auto until Auto shows in display.
Add a comment of you need help with specific programming.
Nov 28, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
Tail lights dont have power 99 cougar
did you check the relay? it would be in something that looks like another fusebox under the hood, in the engine compartment. if its not a bulb, fuse or relay, then it is a wiring problem.
Dec 27, 2008 | 1999 Mercury Cougar
Garmin 205 running watch/ need to set actual time
It was only now that i saw your original post
One option is to touch the time settings in the top right. You can then change the time. Another option is below.
To update the time.
Go to Tools> Settings>Time
Time Format select either 12 or 24 hour time format
Current Time - you can manually set it or automatic to have the nuvi set the time based on your location.
The link to the manual is below as well.
http://www8.garmin.com/manuals/nuvi205_OwnersManual.pdf
http://www8.garmin.com/manuals/2459_QuickStartManual.pdf
Oct 13, 2008 | GPS
Clarion DXZ655MP CD Player Logo
110 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
