1 I take it that you are using the right connecting cables which are compatible with PS3 system. 2 Check the cables are securely inserted. Try disconnecting the cable from PS3 system and TV and reconnecting them. 3 If the video output settings on the system do not match with those of the cable or TV there is no picture. In this case turn off the system. With only the system and TV connected touch the system's power button for more than 5 secs to turn the system on. The video output settings will automatically be reset to the standard resolutions. 4 If the resolution of the video is not supported by the TV the screen will be blank. Then go to system's output settings on the screen, select "Custom" and then select all the resolutions supported by the TV
