Question about Refrigerators
Fridge water "overflow" ?
A plastic 'gutter / water collector' is mounted inside on the back (under the cooling element) with the water outlet drain in it's centre which apparently goes into the back of the fridge.Where does this water-outlet go to ? It seems this outlet is 'blocked' because between cooling cylces it overflows and accumalates in the bottom of the fridge.There is NO outlet outside at the back of the fridge whatsoever or anywhere else to be seen.
  • Choppermack Feb 12, 2008
    Yep that would have been my remedy untill as I mentioned previously I found that there is NO drain tube exit at the rear or anywhere on this fridge - believe it or not, we scrutinised this thing with a fine toothcomb/ inspection mirrors, torches etc the same as I do on aircraft....problem is I have no info relating to the thing's actuall construction inside and there's no way I can open up the back of the fridge without wrecking it.
    Looks like sticking to the routine of drawing out the water every few days with the old hose and syringe is the only way.....
    Many thanks Mac,
    Choppermack
  • Anonymous Mar 18, 2014
    Black plastic container at the bottom behind the fridge overflowed, how often do I have to check
  • 168 Answers
It is supposed to drain to a plastic tray under the fridge. There is usually not a lot of water that drips down there... and the water usually will evaporate before overflowing.
If the water is draining on the inside of the fridge, then the drain tube on the rear of the fridge might be clogged. You should be able to remove the tube fairly easily, and then see if you can blow air into it to see if its clogged. Sometimes it just gets clogged with dirt and dust. If the tube is clogged, and you cannot blow air through it, then see if you can get a small somewhat flexible wire and push it through the tube.
Hopefully it will make it all the way to the other side.
Hope this helps.
Good luck.
Mac =)
Posted on Feb 11, 2008
My frige keeps on runnig water from frige on floor
That suggests that the icemaker valve isn't shutting off completely, or there's a leak. It's also possible that if there's a tray under the fridge that collects condensation, then evaporates it by heating, the heating element could be bad and the condensation is overflowing the tray.
Jun 09, 2018 | Refrigerators
Refrigerator not cooling
The self defrosting mechanism is fubar. Check out the defrost timer and defrost element for proper operation. Chances are that the element is open.
Jun 25, 2016 | Samsung RF266ABRS Bottom Freezer...
How do fix water inside refrigerator under bottom drawers
It may be your drain hole at the back of the fridge has become blocked.
There will be a channel at the back (or side) of the fridge that collects condensation with a drain hole out of the back of the fridge. The drain hole becomes blocked with mould / gunge causing the excess water to overflow and puddle in the bottom of the fridge.
The hole may be gently cleared with a small diameter rod or stick.
Mar 08, 2015 | Frigidaire Refrigerators
Fridge leaking
check door gaskets are in good condition Open and close door quickly Wait for maybe 10seconds and try and open the door . If the gaskets are working there will ne a marked resistance to opening
May 13, 2013 | Bosch KSU49630 Top Freezer Refrigerator
I keep getting water at the bottom of the fridge, under salad boxes on my Hotpoint fridge
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Jul 03, 2012 | Hotpoint-Ariston HS3022VL Refrigerator
I have an ice ball forming on back right of fridge. ANy idea why or what should be done?
You most likely have a problem with the defrost cycle. could be several things. Does it gurggle after you close the freezer door? No? Do you get a strong suction on the door immediately after opening the door? Longer than 30 seconds is not right. Defrost drain may be clogged. It drains defrosted water into the pan under the unit near the coil. Unplug with a light gauge wire and drain cleaner.
Drain may be clear, but heating coils may not be be working well enough. In a marvel of technology, a self defrosting fridge activates heating elements mounted on the cooling coils. A timer heats the elements hot enough to melt frost to water inside your freezer. Very efficient! This water runs out to a pan in the bottom and is evaporated.
Your water is not draining, clogging the drain, then backing up with every defrost cycle. check the drain. If clear, it is probably the circuit board controlling it.
Spencer
Oct 07, 2010 | Sub-Zero Bottom Freezer Refrigerator
The hole at the back of fridge is not letting water go down so i have puddles of water running to front of fridge have tried cleaning out but just the same
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 14, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Water inside my Hotpoint Fridge/Freezer RFA70
There is a kit available, WR2X9393 which includes an aluminm heat probe which you attach to the heater to prevent icing of the drain
Mar 06, 2009 | Refrigerators
Hotpoint RFA 60 Refrigerator drain problem
Well the only way to check it out completely is like you said going from inside your freezer and I like to pour water down the line to make sure it drains.
Take the back panel off inside your freezer and locate the opening of the drain. You will see the collection tray just under your coils and in the middle you will see the opening. Now if it is blocked by ice just take a couple tea spoons of table salt and pour on the opening. Ice will melt very fast and then the opening will clear and then take some water and pour down it.
If the opening is clear just pour water down and observe the drain pan under the unit and see if it comes in there.
Jan 18, 2009 | Hotpoint RFA60 Bottom Freezer Refrigerator
Leaking Whirlpool refrigerator
My Whirlpool fridge had water droplets falling onto all three shelves and pooling unter the crisper drawers. I solved the problem by clearing the ice-clogged drain in the freezer.
In Whirlpool model ET21UM, the condensation drain hole is located directly behind the freezer. To access the drain hole, remove all your frozen items and place them in a large picnic cooler. Notice that the floor of the freezer is basically a large plastic tray fastened by two small bolts. Unscrew the bolts with a wrench or ratchet and remove the plastic tray. At this point you will probably see that water has seeped under the tray and created a mini ice rink on the bottom of your freezer. You can tap the ice lightly with the handle of a screwdriver to break it up. Once it's broken, toss the ice into your sink, or put it in a plastic bag and store into your cooler to keep everything cold.
Once the ice has been removed from the freezer floor, you should be able to see a metal drip trough in the back under a false wall hiding the condenser coils. It's a little tougher to remove the ice from the drip trough with the screwdriver method, so you might want to use a hair dryer. After a few minutes with the hair dryer, you should be able to remove most of the ice by hand. You can remove any water with a sponge or turkey baster. The only ice left will be a plug of ice in the drain hole in the middle of the drip trough. Heat up a cup of water in the microwave and carefully pour it into the drip trough. If the drip trough is hard to access, you might need to use a funnel. The hot water should melt most of the ice in the drain hole. If it pools in the drip trough and doesn't drain, use a sponge or turkey baster to remove the water and add hot water again. A small length of wire or a pipe cleaner might help clear any other obstruction in the drain hole. When the drain is clear you should hear water flowing through it. Dry off the floor of the freezer and return the plastic floor tray to it's spot and fasten with the two bolts. Remove any water that has pooled in your refigerator and you're done.
Dec 27, 2007 | Refrigerators
Refrigerators Logo
921 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
