Question about Kenmore Elite HE4 Electric Dryer
Sensor not working correctly
Sometimes the dryer buzzes, indicating that the load is dry, and it isn't...and other times it does that and the load is in fact dry.
I have used some household all-purpose cleaner and cleaned a very little bit of soil off the sensor strips -- what else can I do so that I don't get a "it's all dry" signal before it's all dry?
  • puzzledpeter Feb 24, 2008
    I'll try that and report back.
    I was daunted by the prospect of taking the dryer apart to replace the sensors...that would require turning the thing upside down, at least, and crawling into its guts to a degree not feasible for a man of advancing years and declining patience :-)
    Thanks very much.
    puzzledpeter
  • Gary Davd
    Gary Davd May 11, 2010
    replace the bad sensor
    President:
  • Kenmore Master
  • 2,651 Answers
Using a scotchbrite padon the sensor will do better than cleaner, its dirty from build up of dryer sheets
Posted on Feb 24, 2008
Dry will only get hot for a short time or with small load?
Are you in sensor dry? Try putting it on timed dry and see what happens. Small loads sometimes won't make good contact with the sensor bars on the inside of the dryer, so you might just need to try drying larger loads. If that doesn't work, then you might have a problem with your sensor bars or your main controller board.
Also, is it gas or electric?
Oct 13, 2014 | Dryers
Buzzing sound
USUALLY WHEN MOISTER SENSOR DETECTS CLOTHES ARE DRIED THE BUZZER GOES OFF TO LET U KNOW SO MAY HABE BAD MOISTER SENSOR, UNLESS THE CLOTHES ARE DRYED WHEN IT GOES OFF
Apr 12, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Why does my dryer end its cycle early?
depending on what type of model. there is a moisture sensor inside the dryer. when you use any cycle other than time dry. if it is a small load ( 2 -3 shirts) it may not touch that cycle. making the machine think that things inside are dry and cut the time short. you can try time dryer and see if that helps. to check if moisture sensor on you dryer is working some models will have a test mode to make sure its sensing. try pressing more time button, then less time button back and fourth. all lights should come on. then you can open door. and when put your hand across the moisture sensor usually near the lint trap. you should hear a beep. to indicate that its reading moisture, meaning good..
Sep 19, 2017 | LG DLG5988 Gas Dryer
Not drying all the time. Sometimes it works sometimes it doesn't. Seems to work for about 15-20 minutes than the heat goes off
Remove the connecting vent on the rear of the dryer and dry a load. If it dries correctly find and repair the vent blockage.
Jan 01, 2010 | Kenmore Dryers
Kenmore Ultra Care Fabric Series 80 dryer works sometimes
This sounds like the motor is bad. Hope you didn't pay too much for it. ;-)
Apr 01, 2009 | Kenmore 659 Electric Dryer
DRYER RACK DOES NOT DRY CLOTHES
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
Feb 17, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
Matag NeptuneDryer MD5500AWW - intermittent heat - not drying
this is joyce
It is as you guessed your sensor. it is usually located in door but some models are in back of machine on inside, go online download document papers go to maytag.com put in model# and then download your model # and it will show you where your sensor is located, it should be simple to replace. I had the same problem with my dryer.
I am glad you said you checked the dryer lines because if these get clogged up they will cause the dryer not to dry the clothes correctley. very smart....if you need me to help let me know.
thanks,
joyce
Feb 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Error code on dryer display
Check your breakers. Mine was doing the same thing, all of the 120v parts of the machine were working. (blower/drum motor/ lights) However the element wasn't coming on. Went to the breaker and found that one side of the 2 pole breaker was tripped. Turned both off and back on. Heater started working again.
When you set the dryer on settings such as normal or permanent press, it engages the various sensors that help the dryer to make the most efficient use of energy. Moisture sensor, heat sensor etc. (THAT IS WHAT TURNS ON YOUR AD SETTING) Normally it selects a time based on factory settings that it believes your load should be dried by. Say 50 minutes at Normal (high heat, normal) Every so often during the cycle, the machine will check the humidity sensor and the other sensors and try to see if the dryer is still on schedule. Sometimes it will determine that more time is needed, occasionally less time. While it calculates, it displays the Ad meaning that the machine is on auto dry. TO TURN OFF AUTO DRY, set it to a time setting instead of a DESCRIPTION setting.
Oct 26, 2007 | Frigidaire GLEQ2152ES Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
