Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
Posted on Jan 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I downloaded windows 7 and I cannot print on my canon s900 printer and I,m unable to find a driver for same.
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 103 Answers
  • Posted on Jan 17, 2010
Anonymous
Expert
Level 2:
Mentor:
Answers
103
Questions
0
Helped
25618
Points
302
Hi try to use the vista drivers for the printer istall it from the device manager
right click on my computer > manage > device manager
I have a rather elderly but fully functioning Canon CP-330 which I used with my PC running Windows XP and my iMac running OS X
Get Windows 7 Driver from webpage
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/selphy_compact_photo_series/cp_330#DriversAndSoftware
Press on Drivers & Software
Select Windows 7 32 or 64 bits, depending the one you have
Download it and install it
Can't help you with OSX; your printer should work, no idea why it doesn't but then, I don't know much about OSX.
3helpful
My printer not working in windows 7 please tell me
I have luckily managed to figure out how to get my Canon MF3110 printing with Windows 7 64 bit even though there is no driver for Windows 7 64bit for the Canon MF3110 Multifunction Printer. The solution is to download the Windows 7 64 bit printer drivers for the Canon MF5750 and then install the drivers as your LPT1: Printer. Note this same work around should work in theory with the Canon MF3111 model as well.
You know you have the right file because if you go to Canon's website link here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=335&modelid=11148
Select Windows 7 (x64) in the drop down
And download these drivers:
MF5730_5750_MFDrivers_Win_x64_us_EN_7.exe
The printer has flashing light, it rotates between yellow and green but never turns to solid green light, It does not accept any print job. Please advise
Issue: Power light (or Alarm and Power lights) alternate(s) between orange and green
Solution: The S900 may require repair
Unfortunately, the issue you describe seems to indicate that your product requires repair service.
Source:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/s_series/s900#ServiceAndSupport
You could try updating the driver, also available at the link above but the manufacturer's website seems definite that repair is in order.
Sorry for this news.
1helpful
Yellow light blinks 7 times
? Seven flashes: Defective printhead
Remove and reinstall the printhead.
Also, ensure that the protective cap has been removed. If reinstalling the printhead does
not resolve the problem, replace it with a new one.
I would like to get my Canon S900 Photo Printer to print from my laptop which has Windows Vista. The driver Disc that I got with the printer can only be used for Windows XP. Is there a way that I can use...
Here are drivers for Canon S900. Please, select driver for downloading.
Additionally, you can choose Operating System to see the drivers that will be compatible with your OS.
Cannon S900 not printing
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
6answers
Need installation software
Kevin download drivers and software to suit HERE - please rate
In case I stuffed the other link link
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
