Question about Nokia 1100
Charging system not charging
  • leobert29 Mar 10, 2008
    not charging
    Novelist:
  • 123 Answers
If your phone won't charge via your computer using a USB cable or via your pickup via a car charger, will it charger via the regular travel charger (i.e., plugged into the wall)? If it won't charge that way either, then the issue is with the connection or with the battery. If you replace the battery and it still doesn't charge, then the problem is with the connection. If this is the issue, then I would suggest replacing your phone, especially if it is 2 years or older. If it is a new phone and under 12 months old, then I would suggest getting a warranty replacement from your provider. If it is older, and you don't want to replace it, then try gettin a new battery, however, if it still doesn't charge, then like I said previously, it is the connection and it would be less expensive to replace the phone then to repair the connection. Hope this helps and let me know if you need any additional information.
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Posted on Feb 11, 2008
  • PRIYABRAT  PATTANAIK
    PRIYABRAT PATTANAIK Feb 11, 2008
    otherwise check your adaptor or your battery or buy a new battery
    Good Luck
    it will help you.
What to do if all s not working but the phone had a prob.
Posted on Aug 27, 2008
MY battery went dead due to me leaving the lights on. I charged and it seems to be running fine, but the charging system failure message is coming on also battery pic in red?
The battery is not fully charged or you do indeed have a charging system problem. You need to have the charging system tested to insure proper operation
Dec 21, 2015 | 2007 Buick LaCrosse CXS
My can wont charge my battery and it wont rev about 2500 rpm in any gear. i have replaced cam sensor and crack sensor and put new timing belt and tensioner on?
My car won't charge my battery ? Check the alternator (charging system) . You put new cam & crank sensor an timing belt on for a charging system problem ? Or after you did this stuff ,now the charging system isn't charging the battery ?
Nov 10, 2015 | Cars & Trucks
2004 gmc envoy xuv , battery light stays on , replaced battery and checked alternator charging fine
You checked the charging voltage at the battery with a ? volt meter ? What was the voltage with the vehicle running ? 13.1 to 14.1 volts ?
BATTERY NOT CHARGING The IPC illuminates the battery not charging indicator in the driver information center when the following occurs:
The PCM detects that the generator output is less than 11 volts or greater than 16 volts. The IPC receives a class 2 message from the PCM requesting illumination.
The IPC determines that the system voltage is less than 11 volts or greater than 16 volts. The IPC receives a class 2 message from the body control module (BCM) indicating the system voltage
Charge Indicator Always On
Step
Action
Yes
No
Did you perform the Diagnostic System Check for Starting and Charging? yes or no
Go to Step 2 yes
Go to Diagnostic System Check - Engine Electrical no
  1. Turn ON the ignition, with the engine OFF.
  2. Observe the Charge indicator on the instrument cluster (IPC)
Does the charge indicator illuminate?
Go to Step 3
Go to Symptoms - Engine Electrical
  1. Turn OFF the ignition.
  2. Disconnect the generator connector.
  3. Turn ON the ignition, with the engine OFF.
Go to Step 4
Go to Charging System Test
Test the charge indicator control circuit for a short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 6
Go to Step 5
5
Replace the PCM. Refer to Powertrain Control Module Replacement in Engine Controls 4.2L.
Did you compete the replacement?
Go to Step 6
6
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 3
Aug 25, 2015 | GMC Cars & Trucks
My car didn't take the R-134a
If your car ac is not taking in refrigerant, it could be caused by several things.
If you have recently done work on the system and you are going to fill the system the first time, you will need to pull a very deep vacuum before trying to charge in refrigerant. If you have already properly evacuated the system and having problems getting the correct charge adjusted, you may be having problem with pressure equilizing between the refrigerant source and your ac system. To get the refrigerant going again, you need to connect the charging hose on the low pressure side of the ac system and turn the fan and ac on cool. The pressure in the ac system on the low pressure side will get lower than the pressure in the refrigerant container and flow will start. When charging initially, charge liquid on the high pressure side and with the ac system running, charge gas on the low pressure side. To charge liquid, invert most container so spout is down, to charge gas, keep container right side up. Charging by gas help you to not over charge your system. Beware on most vehicle ac systems the suction and discharge connections are two different sizes and require the proper adapter. If you still having problems creating a pressure difference to move refrigerant, you can try immersing the refrigerant container in warm water or applying warm air to the exterior of the container.
Hope this helps.
Jan 02, 2015 | Cars & Trucks
My battery light went on, on. My 2003 GMC ENVOY, the message board said "battery not charging" .....I took it to autozone and they said I had a bad alternator which is why it would say battery not...
The charging system on your vehicle is Computer controlled . called ( smart charging system )
• The PCM detects that the generator output is less than 11 volts or greater than 16 volts. The IPC receives a class 2 message from the PCM requesting illumination.
• The IPC determines that the system voltage is less than 11 volts or greater than 16 volts. The IPC receives a class 2 message from the body control module (BCM) indicating the system voltage.
Do you know what DTC'S - diagnostic trouble codes are ?
DTC B1327
DTC B1328
DTC P0562
DTC P0563
DTC P0621
DTC P0622
DTC P1633
DTC P1634
DTC P1637
DTC P1638
These codes are all associated to charging system problems .
Battery light lit on the instrument cluster ?
Are You Smarter Than Smart Charging System MOTOR
Oct 27, 2017 | Cars & Trucks
Batteries won't fully charge
mcdevito75 here, Sounds like the chargeing system has gone bad. Contact Pride online or phone.
Jun 27, 2010 | Pride Line Rally Scooter 3 Wheel Viper
1998 jeep cherokee sport- i get a code p1682.
P1682 - Charging system voltage to low.
Nov 23, 2009 | 1998 Jeep Cherokee
How can I know that the Battery Maintenance System is charging.Does the battery voltage displays on the screen??
Hai dud,
A battery maintenance system for charging, analyzing, discharging and conditioning of a NiCad battery. The system displays voltage and capacity to determine whether or not a NiCad battery has enough capacity to power equipment for an optimal time period. The system charges the battery using a negative delta voltage method of detecting full charge, while also displaying instantaneous battery voltage. The system also analyzes the battery in a charge, discharge and recharge mode of operation, and during the charge mode the instantaneous voltage is displayed. The discharge mode discharges the battery to one volt per cell while displaying voltage and accumulative capacity alternately. The system also conditions batteries by cycling a battery through three cycles of charging, discharging and a subsequent recharge cycle.
Hope it Helped You!
Aug 03, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
Power to ac clutch fuse no power at clutch on 03 leSabre
If your AC system is otherwise operational, it may just need to be charged. The compressor will not come on unless there is sufficient charge/pressure in the system. So, first thing to check is the amount of charge in the system. You can purchase a gauge , similar to a tire gauge, that will give a reading of the system's charge. The gauge hooks up to the low pressure side ,or the larger diameter hose/line, same as where you place the re-charge hose. Again, if the system is operational, as you charge it, the compressor should kick in. At first, it will cycle on and off until the system reaches sufficient pressure.
Hope this helps...
Jul 16, 2009 | 2003 Buick LeSabre
Itouch charging
Some speaker systems which are only compatible for charging the ipod nanos and classics do not work with the iPod Touch and the iPhone, the internals are slighly different from one another which will not allow that speaker system to charge your iTouch.
To play & Charge your touch, i suggest getting a speaker system that supports the iPod touch platform.
Hope this helps ?!
Oct 28, 2008 | Apple iPod touch
Nokia 1100 Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
