Question about Epson Stylus CX5000 InkJet Photo Printer
CX5000 can't connect to printer
Can print from copier. No lights flashing.  I go to File select Print get drop down shows Print as inactive.
My son came by and fixed the problem. Thanks, Terry Eden.
Posted on Feb 13, 2008
Trying to add cannon mp450 printer to my mac and error 9672 shows up it will not print
Click OK on the message prompt to close the message.
Uninstall the Epson Printer software that came with your printer using the uninstaller. Follow the on-screen prompts to uninstall the product.
From the hard drive, click Applications, then click Utilities and select the Printer Setup utility.
Click Add.
If your printer shows up in the printer list, select Printer. If the printer does not show up in the list, choose either Bonjour or Rendezvous as the connection type and then select the printer from the list.
Under the Print Using list, select epson stylus CX5000.
In the list of available drivers, select the epson stylus CX5000 - Gimp-Print driver.
Click Add
Using the Gimp-print driver might provide basic print-only functionality. This driver is a built-in driver in the Macintosh Operating System and will not provide all of the features that are provided using a direct USB connection.
Jan 03, 2013 | Canon Pixma MP450 All-In-One InkJet...
How to resit the cartrage of cx500
ill be happy to assist you on that.
sorry but there's no cx 500, maybe cx5000.
anyway,
1. Make sure the CX5000 Series all-in-one is turned on. 2. Make sure that the document cover is closed, then open the scanner. 3. Press and release the maint.5.10.2.jpg ink button. The On and maint.5.10.3.jpg ink lights flash. Note:
Do not hold down the maint.5.10.4.jpg ink button for more than 3 seconds or the printer will start to clean the print head. If one of the cartridges is low or expended, the CX5000 Series moves that cartridge to the maint.5.10.5.jpg expended ink mark. Go to step 4. If no cartridges are low or expended, the ink cartridge holder moves to the ink replacement position. Go to step 5. Caution:
Do not move the print head by hand; this may damage the CX5000 Series. Always press the maint.5.10.7.jpg ink button to move it.
Feb 16, 2010 | Epson Office Equipment & Supplies
INK DOES NOT FLOW. HOW TO CLEAN INK AREA.
Here is a few steps to clean the print head of your printer.
1. Make sure the CX5000 Series all-in-one is turned on but not printing, and the ink cartridges are not low or expended.
2. Right-click the printer icon on your taskbar (in the lower right corner of your screen). Select Head Cleaning.
3. Click Start or Next.
Cleaning takes several seconds. The CX5000 Series runs a head cleaning cycle and the On light flashes.
Caution:
Never turn off the CX5000 Series while head cleaning is in progress. You may damage it.
4. When the On light stops flashing, make sure paper is loaded in the CX5000 Series, then do the following:
Windows:
Click Print Nozzle Check Pattern. Then click Print.
5. If there are no gaps or lines, click Finish.
If there are still gaps or lines, or the test patterns are faint, click Clean to clean the print head again.
If you don’t see any improvement after cleaning three times, refer to Problems and Solutions. You can also turn the printer off and wait overnight. This lets any dried ink soften. Then try cleaning the print head again.
Tip:
If you do not use your CX5000 Series often, it is a good idea to print a few pages at least once a month to maintain good print quality.
Cleaning the Print Head
Hope this initial / info idea helps.
Dec 10, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Where could i get an installation cd for EPSON Stylus cx5000?
Here is a link to the Epson Support for your printer.
Epson CX5000 Support
Once there click on the "Drivers and Downloads" link. Then on the next page select your operating system from the drop down menu. You will get a list of available downloads. Make sure you verify what OS you have before downloading.
If you need additional help, just comment back.
Dec 14, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Epson styus cx5000
Go into Printers, Properties, Printing Preferences, then Black Ink Only. If you make that the default, it will automatically print black ink with you click on the printer in the toolbar. If you want to print one document in color, click on File, Print, Properties, and set it for color for that one job only. The default of Black Ink should stay the same.
Aug 28, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Have Ultra Hi-Definition RX595 Photo all-in-one print,copy,scan,photo. After setting everthing up and when I print from word or anyting the print comes out in color. I thought I could have color or b/w...
1) Make sure the printer is turned on but not printing. Ensure there are no error lights or messages appearing in the LCD.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2) Load letter size paper.
3) Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. RIGHT-CLICK your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then RIGHT-CLICK the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4) Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5) Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6) When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7) If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8) If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
Aug 21, 2008 | Epson Office Equipment & Supplies
Software
Go to www.epson.com, select your machine type, model and OS from the drop downs and then confirm.
You should then get the option to download the available software like PIF tool and easy print module.
Jun 08, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Setting HP OfficeJet 4315 print preferences on a MAC OS X
Whenever you send a file to print from a program a small window shows up. If it shows only
Printer: Drop down menu ARROW Presets: Drop down menu Some buttons at the bottom
then click on the ARROW pointing down for more options. That will show more info, including a drop down menu that will allow you to change page settings, printing settings, etc. For example, if you want to change the printing quality, select "Paper Type/Quality" from that drop down menu and new options will show up allowing you to change the settings of the printer.
Jan 10, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Dark red prints with lines throught the picture
1. Make sure the printer is turned on but not printing.
2. Load letter size paper.
3. Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. Right click your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then right click the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL, HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. Right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the print head. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
Dec 23, 2007 | Epson Stylus Photo R320 InkJet Printer
Printer doesn´t print using the mangenta ink cartridge
try this :
3. Click on START.
For Windows Vista: Click CONTROL PANEL,HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
5. Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
Dec 20, 2007 | Epson Stylus C63 InkJet Printer
Epson Stylus  CX5000 InkJet Photo Printer Logo
209 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
