Question about Olympus Camedia C-700 Ultra Zoom Digital Camera
Won't power on. Batteries are fully charged (I verified voltage using a voltmeter). No response to the power on button.
The plastic cover of the batteries got somewhat deformed causing lack of connection. When pressed down the power went on. I shall try to replace (if possible) the plastic cover. In the meantime I have fastened the cover down with plastic tape.
Posted on Feb 11, 2008
I have a pride cirrus Wheelchair a voltmeter shows that the batteries are fully charged up. But when I drive I don’t get very far before the VSI shows of the batteries are dead. I check again at the...
faulty voltmeter and /or bad batteries
have the batteries load tested to eliminate them then replace the voltmeter
in reality it should be showing a reduction in volts available as the batteries run down form use
as an example
fully charged batteries 12 or 13 volts
go for a trip around the block and as you go the meter should start reading a lesser voltage as you are going or a reduced voltage at each stop
Nov 13, 2017 | Pride Health & Beauty
S600 schwinn electricscooter.I just purchased three new batteries.I hooked them all up then plugged charger in it reads charge ok.But soon as I un plug the charger and turn to poweron it doesnothing.
Use a voltmeter to verify your batteries are indeed fully charged. Double check all connections for solid contact and signs of corrosion. Keep all contact points shiny clean.
If the batteries are all good, we could be talking control circuit.
Mar 02, 2016 | Health & Beauty
Tips for charging new batteries in Jazzy Select Traveller
Check the charger output to verify whether or not you have a bad charger using a voltmeter. These smaller batteries are notorious for having a short shelf life and poor quality control from the manufacturer. Load test the batteries after you verify you have a working charger that will bring the batteries up to the proper voltage first.
Feb 24, 2014 | Electric Mobility Pronto M41 Power Chair...
When i press power on/off button of my D3000 nikon camera, there's nothing power exist. What is the solution for this problem?
Before you do anything, verify that your battery is fully charged. Be aware that rechargeable batteries do fail after a time and your battery charger could also fail. Buy a second battery if you do not already have one and try that. Also, replace your battery charger. Or, if you have a voltmeter, simply measure the battery voltage to eliminate both the battery and charger as a cause.
The other thing I would do, is make sure the battery contacts in the camera and on the battery are clean. If that does not solve your problem, I would contact the nearest Nikon USA repair depot for repair information. You will find there locations in your D3000 manual.
Sep 11, 2013 | Nikon D3000 Digital Camera
Philips cd445 not charge battery
Small knowledge of electricity and Voltmeter. Check voltage on contact for charging. Voltage depend of used batteries and simple definition is that voltage must be something higher.
Jan 22, 2018 | Philips CD4452S/05 Digital Telephone and...
The battery won't stay charged
Hi it is possible that you Alternator is faulty,if you have access to a VoltMeter ,check the battery voltage in the morning before you try to start it you should have around 12.7 volts for a charged battery if not fully charge your battery again and check the voltage with your car running you should have around 14 volts with the engine reving at 1500 revs.ifyou get around 12 volts then your lights are taking more power from the battery than the Alternator can replace.You could also get your local garage to Drop Test your battery to see if any of the Cells are faulty
Jan 11, 2013 | 1987 Volvo 740
WILL NOT CHARGE I HAVE TRIED TO CHAGE IT BUT IT WILL NOT CHAGRE
well if it won't charge then it could be the batteries are too low for the charger to pick up or the charger is not working. If you have a voltmeter set it on 200 vdcand plug it into the 2 outter holes of the charger port located under the front of the joystick. Without the charger plugged in you will read the battery voltage and it should read 25-27 volts fully charged Now plug in the charger and the meter will be reading the charge voltage and it shoud be 27-30 volts. If you are reading 27-30 volts with the charger plugged in then the charger is working Hope this helps you
Apr 22, 2011 | Jet 3 Ultra Power Chair
It not charging fully
Stan Issue is probably batteries. If you are charging overnite and never get a full charge then I would suspect batteries. If you have a voltmeter set it to 200 vdc and plug the leads into the two outer holes of the charger port located under the front of the joystick. When fully charged you should read 25-27 volts. If you are reading a lower voltage then I would check the charger. you will have to read the voltage at the battery posts with the charger plugged into the charger port You should read 27-30 volts. If you are not getting that reading replace the charger. Try borrowing a charger from someone that also has a chair If it charges the batteries then you need a new charger if it doesn't then you need new batteries Hope this helps
Feb 07, 2011 | Ctm HS-2800 Power Wheelchair
My batteries are struggling to charge do i need new ones
Harold Do you mean that they won't fully charge or won't charge at all. If you have the small 12/12 batteries then they do not last as long as the U1 batteries (bigger) If you have the U1 batteries check the voltage of the batteries with a volt meter Fully charged should read over 12 volts and up to 13.5 volts. Also check your charger to make sure that it is charging with a voltmeter you can measure the voltage aith the charger plugged in and you should be reading over 13 volts on each battery. Hope this helps you
Sep 07, 2010 | Pride Health & Beauty
I've been charhing the battery for 48 hours and no charge! any answers?
Kw How old are the batteries and have they been sitting up for a long time? If this is the case the charger cannot pick up really low batteries and charging them for 48 hours won't help. Unfortunately you have to get 2 new batteries. Your chair requires 2 U1 batteries. Now if the batteries are fairly new and when you plug the charger into the joystick you should be getting a red light and a yellow light on the charger. When fully charged the yellow light turns green. If you have both lights and it never turns green bad batteries if no lights or just the power light bad charger, If you have a digital voltmeter you can set it on 200 volts dc and place the leads in the two outter charger plug holes on the joystick. It should read the battery voltage fully charged 25-27 volts HOPE THIS HELPS
Sep 06, 2010 | NRS Hoveround MPV 5 - Used Power...
Olympus Camedia C-700 Ultra Zoom Digital Camera Logo
49 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
