Question about Hunter 20531 Vista Brushed Nickel Ceiling Fan
Pull chain broken
My pull chain keeps pulling out. I took it apart and the chain sits inside this sping mounted swith. Can I buy that switch? I cant seem to get it back together proparly? Someone please help!!!!! Thank you
  • 2,130 Answers
Yes, You should be able to find a replacement switch with new pull chain at most hardware stores in the electrical section.
Good Luck!
- Jim
Posted on Feb 11, 2008
Instructions to replace pull chain for Leviton Plastic Lampholder model 8827CW2
I believe it is cheaper just to replace it then try to get the parts!
You may be able to take it apart and salvage it by using what is leftr of the old pull chain but I am not sure.
Feb 09, 2014 | Leviton Electrical Supplies
Hello, I currently have a celing lamp in my kitchen. There is a little cord you pull to turn it off. The onlything is, is that the cord is not working and i dont know how to turn my lamp off if not to...
The lamp has on-off pull-chain switch.
You can buy replacement pull-chain switch at hardware store.
Buy the pull-chain switch that has two wires.
Buy two yellow or orange wire nuts.
Switch off breaker.
Take apart light.
Remove old pull-chain. Strip back the wires if needed, twist wires together.
Connect new pull-chain switch using wire nuts.
Sep 22, 2011 | Electrical Supplies
Hi: I have an bathroom heater fan, Thermosafe model:3208,(new Zealand) one day i found out that i could not turn it on, it even not make the "clip" sound (this heater wasn't designed...
From your description, it sounds like the pull chain ON/OFF switch is broken.Admittedly, this is the first time I have ever heard of a pull chain switch being on an electric heater, But, I guess it is in the ceiling and not wired to a wall switch, it's the only way to turn it ON or OFF. I wouldn't think that replacing the pull chain switch would be that difficult or expensive to replace. Most home centers and hardware stores sell this type of switch for use in ceiling fans, The key would be removing the faulty switch and taking it with you to buy a new one. You want to be sure that the new switch matches the amperage and polarity of the old switch.
As far as the unit only being a year old and the switch failing so quickly ... it's in a warm moist environment 24 hours a day. It doesn't surprise me that the switch broke. You might want to consider replacing the pull chain switch with a hard wired wall switch. Certainly, it would cost more than replacing the pull chain switch, but you'd never have that problem again.
I hope this helped you, Mary. Please let me know.
Jul 14, 2011 | Heating & Cooling
How do you open a wu pin switch. the chain broke & went inside switch
My chain was broken about 1.5 - 2 centimeters inside the wu pin. I took a chain connector (with some chain hanging off one end) and fed it into the hole, trying to connect it to the broken chain. After a couple of tries I managed to get the end of the broken chain inside the wu pin to connect to the chain connector by gently pulling down once it was somewhat inside the chain connector. I hope this works for you. I was so glad I didn't have to resort to cutting any wire or making a trip to a home improvement store!
Jun 13, 2011 | Westinghouse Electric Westinghouse...
My daughter pulled to hard on the ceiling fan pulling out the chain. i have taken it off and apart, nothing appears to be broken but im trying to figure out how to put it together so it retracks, i...
Don't even bother to repair the pull chain switch, get a new one at KMart, HomeDepot or similar store for less than $2.
Two times I've repaired one, it comes apart when I need it the most.
Good Day! Don't forget to rate this post!!
Sep 09, 2010 | Vacuums
Pull chain broke off how do i get it back in. took it apart how do i get it back in
You can purchase a new switch at a local electrical distributor or go online to mcgill pull chain switches
Jun 06, 2010 | Hampton Bay 52 In.Carriage House II in...
The pulley chain broke on the light on my ceiling fan and there is no slack to turn the light on or off. Can you please tell me how to fix or replace pulley?
To replace chain switch with a new one (available at a hardware store), first turn off power to the fan. Unscrew the nut on the bottom of the fan which holds the coverplate in place. Find two wires going to the switch, pull them out of the enclosure, take the wire nuts off. Now you can take the old switch out by unscrewing the locking nuts that hold it in place. Put the new switch in by reversing the instructions for removal.
Good Luck.
Jan 20, 2010 | Solar 2-wire Pull Chain Light Switch For...
Pulled chain to slow down fan speed. Chain came out of the housing. Yikes. What should I do? Perfetually have the fan running or can I take it apart and fix it?
Turn the fan off at the breaker. Is there any chain still hanging out? If yes, buy new section of chain at hardware store. If no, buy new pull chain switch at hardware and replace.
Jul 27, 2009 | Dryers
Hunter 20531 Vista Brushed Nickel Ceiling Fan Logo
504 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
