Question about Cooktops
JENN-AIR MODEL D156B Electric oven
Printed circuit board and Relay board replaced. After pushing oven or broil indicator display appears and when temperature knob is turned and the temperature setting is made,display shows 140 pre heat, after few seconds the display disappears
Code f 0 means what?
Posted on Aug 25, 2008
How to change the temperature display from Celcius to Farenheit
Hello Friend, that's a great question!
Please follow the steps below to change the temperature to Celsius to Fahrenheit on your Frigidaire range, FEF366CCA.
    ·Press BROIL. "-" appears in the display.
    ·Press and hold the UP arrow until "HI" appears in the display
    ·Press and hold BROIL until F or C appears in the display.
    ·Press the UP arrow or DOWN arrow to change F to C or C to F.
    ·Press any control pad to return to normal operating mode.
    Hope this helps! - Z
Sep 03, 2014 | Frigidaire Gas & Electric Stove/Oven/Range...
After cleaning f1 appears on display
This means the oven lock is activated. The cook top touch panel is likely causing some problem.
Try to press the child lock button and see if F1 goes off. Otherwise the control panel will need to be replaced.
Oct 18, 2011 | Jenn-Air JED8430 Electric Cooktop
I get an F9 in the window on the oven what does this mean
Below are the details of error code F9...
JENN AIR
'Newer Style' Range/Stove/Oven Fault Codes
Fault : F9
Condition: Door lock safety circuit on power relay board sensed
Replace power relay board
JENN AIR
Fault:F9
Condition: Door latch supervisory
Check door lock circuit or replace clock assembly or ERC
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Jan 01, 2011 | Jenn-Air Expressions AR141 Electric...
Stove not on - but fan comes on automatically -
it sounds as if the thermostat is broke. it could be the two wires off the thermostat are after melting together. ( burning smell). the thermostat stops power going to fan when it sences below a certain degrees. but your one has been cut out of the circuit due to the two cables melting together. this means fan will constantly stay on. you need to find and replace thermostat and make sure no cables melted together. if they are then seperate and use insulating tape to re insulate.make sure circuit breaker is off while doind this
Jan 16, 2009 | Jenn-Air JED8230 Electric Cooktop
JENN AIR WALL OVEN ELECTRIC
Are you sure the breaker didn't trip on one side? If one leg of the 220 is out, the lights and controls will appear to work, but the elements will not heat up. Make sure you have 220 to the appliance. It's also possible that you pulled a wire off somehow when changing the broil element.
Dec 12, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Hi Sadirrd
Your problem (flashing F3) is most likely a defective temperature sensor.It may also be due to a open in the wiring harness connected to the sensor - unlikely but could be.
Post a rating for this solution
Regards
Nov 07, 2008 | Cooktops
Jenn-Air electric stove top - burners/fan won't come on
you may have lost a leg of your 240V service. make sure you have 240 to the appliance and then start chasing down where you lost it. there is no onboard trip or reset on this unit
Apr 20, 2008 | Jenn-Air JED8230 Electric Cooktop
On light flashes
i would replace the custom control kit. elemnt usually fine that contorol kit is a new circuit board that only controls that one burner
Mar 09, 2008 | Jenn-Air 35 in. JEC9536 Electric Cooktop
Sve47100 oven doesn't heat
Test the swtich w/ multi tester /connect tester as a jumper to the switch dettach one line on and off switch /if does not reponse / replace the switch.
Jan 03, 2008 | Jenn-Air JED8430 Electric Cooktop
Cooktops Logo
434 people viewed this question
Top Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
