Question about Samsung ML-2150 Laser Printer
My printer cannot print.. it say 'invalid toner'.
  • 5 more comments
  • Anonymous Feb 19, 2008
    i do not have the driver,on screen write invalid toner
  • johnsonjose Mar 17, 2008
    printer showing invalid toner
  • sargy Apr 11, 2008
    "invalid toner" is displaying in the display panel and print can no be done . please give the solution.
  • simonchieng Mar 02, 2009
    invalid toner????
  • simonchieng Mar 03, 2009
    Invalid toner.....
    The toner changed is ori. Assumed the chip inside the printer has corrupted and must be repair, then the cost of repairing $$$? could it be the software problems?
  • ketuketeh Mar 07, 2009
    I have three ml 2150 in hand now. 1 unit okay,, the other two error with "invalid toner" message.. I swap the toner to the working printer, the "invalid toner" message not appear.. to i believe this is the printer error?
    Any help?
  • russ40 Mar 11, 2009
    Invalid Toner message. I'm interested in ketuketeh's fix but have no idea what the toner sensor board or unit is. Can anyone help with diagram or detailed description.
  • 21 Answers
Ok guy.. and Cikgu..
I have solved the problem.. it seem like the toner sensor board did not connect correctly to the toner. What i do is, i deassamble the unit, clean the contact point with contact cleaner, remove any dust and corrosive.. and then re-assemble the unit.. it works...!!!
Cikgu can leave me a message if u need futher help..
sorry for my language...
Posted on Mar 07, 2009
Ketuketeh Could you please explain a little better what it is exactly you are talking about cleaning? I have had this problem for so long without finding a solution.
Thanks
Posted on Aug 04, 2009
Check printer 5100
Posted on Jan 07, 2011
I agree with ketuketeh..it works just remove the dirt from the board and the spring..that's all !!
Posted on Oct 09, 2009
PROBLY toner that u use is not ori. the chip inside the printer maybe corrupted n must be repair. that's why the printer cannot identify that toner
Posted on Feb 18, 2008
Printer shows Invalid Cartridge but it is not?
I ran into the same problem with the same printer. At first I was able to take it out and turn of the printer. Put the toner cartridge back in and it would work fine. But recently, so such luck, ended up buying a new toner cartridge and works great. Slightly disappointed as the old toner is 3/4 full but its also very old and has been in the computer since purchase date. I notices when I took the old toner out I could smell the ink like it was almost burnt. If changing cartridge doesn't work I recommend a HP. I only use this printer for bulk prints but my HP for everything else. HP is the way to go....
Mar 12, 2012 | Dell 2335dn Multifunction Laser Printer
Samsung CLP 315 invalid toner message
the best thing to do is buy the original toner. how ever if u really can't then try changing the blue colored one
Jul 29, 2017 | Samsung CLP-315 Laser Printer
I have a samsung clx-3160fn printer I replacEd blk toner and it keeps sayn invalid toner .... I even refilled old toner and same error... Invalid toner
I have the same problem in a CLP-300. I have tested 3 diferent aftermarket chips from different manufacturers and always the same message: "invalid black toner" and the black toner light keeps red
Sep 21, 2010 | Samsung CLX 3160fn All-In-One Printer
Printer is a Samsung CLX 3175FN. It says the
To run a quick check on your black toner, insert your old black toner back to the printer.
press on the menu button -> system -> report-> supplier info-> print. and same for your new toner, if it show u both the old n new black toner are under the same serial number. the new toner might be faulty. Invalid toner detected.
get the new toner with the box packing back to the shop for replacement.
Oct 02, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Invalid Black Toner Xerox Phaser 6110 MFP
reload the driver again and if it persists, change the toner
Jun 23, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
Invalid black toner replacement cartridges
Hi, Please make sure what version printer you got? USA version? or Asian version or euro version?
After confirm what version printer you got buy corect version CHIP or toner it will works.
Use any of other area toner will result toner invalded.
Regards
May 20, 2009 | Samsung CLP 300 Laser Printer
Error message "change cartridge invalid refill" the printer wont print anymore
Trying cleaning the contacts on the cartridge and clean the contacts on the printer use a dry tint paper towel to clean the contacts. Then try to reinstall the cartridge using the software. Try to print the self test. If failed try another cartridge if you dont get any error then the cartridge might be defective
Apr 27, 2009 | Office Equipment & Supplies
Flashing amber warning light
The problem is that the MICR Toner Wire was placed into the wrong jumper position on the TROY Font Card. By moving it to the other jumper, this should clear your 'Invalid Toner Sense State' Error. If you need further assistance, please feel free to contact me at 800-633-2266 x 218 or vial email to bmcmillen@troygroup.com.
Regards,
Brian
Mar 20, 2009 | Troy MICR 2200T Secure Laser Printer
"invalid toner cartridge" message remains
Try this
Turn the printer off hold down the menu button turn the printer back on while continuing to hold down the the menu, when you get a green light your ready to print
Feb 18, 2009 | Samsung CLP-510 Laser Printer
Error message: invalid toner yellow
If the toner is empty it will display this message and the only way I know of getting rid of it is to replace the cartridge. They do make refill kits with extra chips so you can cut the old one out and sticky tape another on. As for a clearing code I am unaware of one for this unit as the information is store in the toner cartridge.
Sorry
Jan 06, 2009 | Samsung CLP-600N Laser Printer
Samsung ML-2150 Laser Printer Logo
1,275 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
