Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Cde 3 4
I push the Menu and Device diagnostic code 3 4
    President:
  • 4,402 Answers
34 = Lamp abnormality
Try here for Osram lamps as cheap as I have found them:
http://www.intl-lighttech.com/store/item_GTL-OS-69490
Posted on Feb 11, 2008
How to reset code error c6100
Please Follow step by step..
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
Read more help..error code 0xc18a0106 on c5180 Photosmart and HP Printer Support
Thanks,
Sep 10, 2014 | Office Equipment & Supplies
How can you check crank position sensor?
1 - Turn the key in the ignition to the "Off" position. Turn the "Run/Stop" switch to "Run." Push and hold the odometer "Reset" button. Hold the "Reset" button and do not release it yet.
2 - Turn the key to "Ignition," but don't start the engine. Release the odometer "Reset" button. Wait for the odometer to indicate the bike is in diagnostic mode by displaying "Diag." Push the odometer reset button and then release it when you see the "P" in the menu selection flashing.
3 - Wait for the bike to complete the diagnostic of the electronic control module and the ignition control module. Write down the codes that are displayed after the diagnostic is complete. Code PO374 indicates a failed or faulty crank position sensor due to a synchronization error.
Jul 25, 2014 | 2011 Harley Davidson FLHTCU Ultra Classic...
AFTER REPLACING SWITCH AND COMPUTER ON A 1999 TOYOTA TACOMA P1780 CDE STILL COME BACK
The codes need to reset with a diagnostic plug in device that may only be located at a dealers service center.
Mar 17, 2014 | 1999 Toyota Tacoma PreRunner
How do you set minutes on clock?
Settin Time
1 In the Clock priority mode, press and hold
TITLE for at least 2 seconds while the time is
displayed.
The time indication will blink.
2 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press 4 and 3 (CDE-9841 only) to adjust
the hours while the time indication is blinking.
3 When the hour has been adjusted, press the
Rotary encoder (CDE-9845/CDE-9843 only) or
press MODE (CDE-9841 only).
4 Turn the Rotary encoder (CDE-9845/CDE-9843
the minutes while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by
pressing the Rotary encoder (CDE-9845/CDE-9843 only)
or press MODE (CDE-9841 only).
6. To synchronize the clock to another clock/watch or radio time
announcement, press and hold the Rotary encoder (CDE-9845/
CDE-9843 only) or press and hold MODE (CDE-9841 only) for at
least 2 seconds after setting the "hour." Minutes will reset to 00. If
the display shows over "30" minutes when you do this, the time
will advance one hour.
Or you can ge tthe manual on the link below.
Mar 11, 2012 | Alpine CDE-9841 CD Player
How do i set the time on my alpine cde 9841?
Setting Time
displayed.
• To synchronize the clock to another clock/watch or radio time
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/500/500CDE9843.PDF
Jun 17, 2011 | Alpine CDE-9841 CD Player
I can set the hour but I can't figure out the minute settings on the clock.
Setting Time
TITLE/ for at least 2 seconds while the time is
displayed.
2 Turn the Rotary encoder (CDE-9846 only) or
press 4 and 3 (CDE-9842 only) to adjust the
Rotary encoder (CDE-9846 only) or press MODE
(CDE-9842 only).
4 Turn the Rotary encoder (CDE-9846 only) or
pressing the Rotary encoder (CDE-9846 only) or press
MODE (CDE-9842 only).
announcement, press and hold the Rotary encoder (CDE-9846
only) or press and hold MODE (CDE-9842 only) for at least 2
seconds after setting the "hour." Minutes will reset to 00. If the
display shows over "30" minutes when you do this, the time will
advance one hour.
Apr 12, 2011 | Alpine CDE-9846 CD/MP3 Car Stereo
Mitsubishi Model WS 55511 was made in March of 2003. I turn it on and it goes right back off again. On the front of this TV I only have an Enter button, a menu button. an A/V Reset Button and a Device...
Device is the same as input--try the self check, when power light goes off press and hold it and menu at same time for five seconds and release.
Device means input.
Let me know error code and I will help you more than anyone else.
SD TECH
Sep 18, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Powers on for three seconds then goes off
The first thing to do is to try to determine why the set is not turning on. It is equipped with a self diagnostic feature. On the front of the set push the MENU and DEVICE button at the same time and hold until the LED starts flashing a two sequence code. That will narrow things down for us.
Apr 28, 2009 | Mitsubishi WS-55511 55" Rear Projection...
I have a hyundai sonata classic 2000 model disconnected the battery lead to clean them, now the radio will not work I have a security code but not sure how I put it in to radio
Once you turn on the unit, "1 CDE" will appear on the LCD. Then using preset button 1~4 enter the 4 digit security number supplied on security card. After confirming the number, press preset button 5. This should unlock the player. If the incorrect code is entered "2 CDE" will appear on LCD and if incorrect code is entered again, "3 CDE" will appear on LCD. If, after the third attempt, the code is incorrect, the set will turn off. Wait 1 hour before re entering a security code.
Aug 26, 2008 | 2000 Hyundai Sonata
Alpine CDE-9843
Page 16 of the manual:
http://vault.alpine-usa.com/products/documents/CDE-9841,%2043,%2045%20OM.PDF
Setting Time
displayed.
only) or press
only) or press
least 2 seconds after setting the “hour.” Minutes will reset to 00. If
the display shows over “30” minutes when you do this, the time
Apr 26, 2008 | Alpine CDE-9843 CD Player
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
71 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
