Color output problem
The print of the text that my printer is printing is not the same as what i prefer. for example, if i choose color black for my document it will print color blue. or if i choose color blue it will print color red.
  • brian c
    brian c May 11, 2010
    Can you be more specific with the make / model of the printer?
    President:
  • 4,402 Answers
My deskjet 5550 printer stopped printing in color it only print black ink i have replaced the color cartridge still only prints in blank only; i have tried calibrate printer and clean cartridge options;...
If the Cartridge and printer alignment is successfull and you are still not able to print in color, mostly the Color print is disabled in your pc
Click on START Button
Click on CONTROL PANEL
Open Printers and Faxes folder
Highlight the Printer icon for Deskjet
Right click on the printer icon and choose Printing Preferences
Under Printing preferences, you will find Printing mode - It must be on BLACK or GREY SCALE, Change to COLOR/ ALL
try printing.
Jul 03, 2010 | HP DeskJet 5550 InkJet Printer
How do i use only black ink in this printer? its asking me to put the color ones in there and i dont want to do that bc it keeps wanting to print color and im out of color ink?
you can select to print only in black from within the print driver under preferences in the print screen.. but now that the tricolor is needed to be replaced you must replace it before you can proceed once you do that you can select it to print only in blk
Mar 31, 2010 | HP Officejet Pro L7680 All-In-One Printer
I just installed a Canon mx300 on my Mac (runs 10.4.x) and all seemed to go well. I can print but the black letters don't print black (actually, the same happens if I have colored text mixed in). It's...
If the colors in your document don’t look right, you can change whether colors are managed by ColorSync or your printer.
To change color management options for printing:
Open the document you want to print.
Choose File > Print.
If the Print dialog contains only two pop-up menus and some buttons across the bottom, click the disclosure triangle beside the Printer pop-up menu.
Choose Color Matching from the print options pop-up menu.
Select one of the following options:
Select ColorSync if you want the application you’re using to control the color management of the printed output.
Select “In printer” if you want the printer you’re using to control the color management of the printed output.
If you select ColorSync and don’t believe the correct profile is selected for your printer, you may be able to change it. If you see a Profile pop-up menu, choose Other Profiles from the pop-up menu, and select a new one.
I hope this info will help to sort out your problem..Regards
Jan 08, 2010 | Canon MX300 Office All-In-One Printer
Word/Excel/Notepad docs will not print in black ink, will print in all other colors (incl those that require black ink) and everything else not Office product will print in black--new problem
Hi katethecat,
It is the Setup in your software.
First of all check this:
Go to CONTOL PANEL-> Printers-> select your printer if there are more than one listed.
Right Click on the name of the printer
Left click for the following:
Printing Preferences-.> color
Make sure the Color is selected and not the black or grayscale.
Click Ok
Exit from the menu
When you choose the color option it prints color & black
If you choose the black option, it prints everything in black.
Some software overrides it.
Please go into Word, Excel, Notepad etc and check the Printer Preferences are set to color not black.
Hope this will work for you.
Please give a rating.
Cheers
luciana44
Sep 08, 2009 | Microsoft Windows XP Home Edition
Won't print Black
I assume you have the black cartridge installed correctle and it has enough ink.
Check these : Either through Contol Panel or any other place where you can see a list of installed printers, select your printer.
Right Click on the Printer
Left cLick on Properties.
Left click on Preferences.
Click on Color tab
Choose ...Color Or Gray Scale
Some times it will show as Color OR Black
Choose black.
You have to do a test page.
Hope this will help.
luciana44
Sep 05, 2009 | Canon PIXMA iP2000 InkJet Printer
How can I get the Canon MP460 to print in black and white only?
what you'll need to do is just refill the color cartridge.
you may not need to use it, but refill it to prevent it from drying out and not being able to work. That is because for the printer to work both cartridges need to be in working order.
Mark
May 22, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Every other word either red or blue
Please follow these steps and then try to print :
For winows system :
1. Click Start, Settings, Printers (Windows XP: Control Panel, Printers and Faxes).
2. Right click on the Lexmark printer icon and select Properties.
3. Select the Printer Settings tab (Windows XP: click on the Printing Preferences button) and click on the Change button.
4. Close the I Want To menu and select Print Color images in Black and White.
5. Click OK to confirm the new settings.
For mac system
# Load plain paper into the printer. Open the Page Setup screen and select the required settings.
# Then open the Print screen and customize the image printing settings as follows:
1.
2. From the software application, select File, Print. From the Printer pop-up menu, choose your printer model and then continue.
3. From the pop-up menu in the upper left corner, choose Color Options.
4. From the Document Color pop-up menu, choose Black Only.
5. Click Print.
Mar 20, 2009 | Canon BubbleJet i560 InkJet Printer
Hp 3210 photosmart Is it possible to print from black cartridge only,
It is possible. You will have to go into the properties of the printer you're using. Assuming you're using WinXP, go to Start>Printers and Faxes and right click your color printer. Choose Printing Preferences. Using my HP Photosmart C3100 as an example, I would next choose the Color tab and under Color Options, choose the radio button that says Print In Grayscale. That will do it.
Feb 20, 2009 | HP Photosmart 3210 All-In-One InkJet...
Print in black ink only
I know you can print in Greyscale which prints in black and white only. On your Windows computer, you should just be able to click Start -> Printers and Faxes, then right-click your printer and choose Printing Preferences. Look for a tab that says Color and click it. There should be a selection, probably a check box, that lets you choose "Print in Greyscale". Afterwards, when you print, even color documents will print in black-and-white only.
Oct 07, 2008 | HP Photosmart D7160 InkJet Printer
357 people viewed this question
jasbo
jasbo
