Question about Lexmark X1270 All-In-One InkJet Printer
Printer the power button blinks no print no scan no copy
  • 4 Answers
It will not print when power button blinks, you must clear jam or reset until power button is on steady.
Posted on Feb 21, 2008
Print function
The printer prints alignment page; after enter button.
Place the printed page in scanned glass properly.
Press the scan button and wait untill the ON light stops blinking.
Now alignment is completed.
Regards,
Riztech
Mar 02, 2010 | HP PSC 950 All-In-One InkJet Printer
Replaced ink cartlidge and now wont print
After replacing the ink cartridge you should print the alignment page to work product perfectly.
Follow the below instructions to print alignment page:
  1. Turn on the HP PSC 1200 or 1300 series product.
  2. Disconnect the USB cable from the all-in-one.
  3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
    1. Press and hold Cancel .
    2. While holding Cancel , press On .
    3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
    4. Press Cancel again.
    5. Press Copies .
    6. Press Paper Type .
    7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
  4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
  5. Reconnect the USB cable.
If the issue still persists, perform semifull reset by following the below instructions
  1. Unplug the power cord from the wall outlet.
  2. Unplug the power cord from the back of the all-in-one.
  3. Wait 30 seconds and plug the power cord back into the wall outlet.
  4. Plug the power cord to the back of the all-in-one.
  5. When the lights begin to flash, press and hold the On/Resume and Number of Copies Buttons.
  6. When only the On/Resume light is flashing, release the buttons.
  7. When the On/Resume light is steady, the reset is complete.
Oct 12, 2009 | HP PSC 1350 All-In-One Thermal Printer
Scanner
Check the power and the data (USB) cables in the printer...check both ends...
Check :-
# The printer powers on properly
# There also can be problems with the printer driver
# and also internal printers....
Try reinstalling the printer driver...
<PLEASE RATE ME AS FIXYA>for my help......................
Jul 30, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP psc 750 printer
my computer said that it did not have it on the computer I've used the CD .
May 21, 2008 | HP PSC 750 All-In-One InkJet Printer
HP 1210 all in one printer does not have a maintenance button to allow me to align cartridges. Prints landscape pages out of alignment; I have tried taking the cartridge out and putting it back but it...
On the printer hold down the CANCEL button then press and hold the ON/RESUME button until the CHECK PAPER and CHECK PRINT CARTRIDGE LIGHT both blink simultaneously.
When both lights are blinking press CANCEL, COPIES, PAPER TYPE, and COLOR START COPY one after the other. All this must be done in under 10 seconds for it to work. Once this sequence of buttons is completed correctly in under ten seconds an alignment page will print.
Apr 09, 2008 | HP Office Equipment & Supplies
Hp psc 1350v WILL NOT COPY OR SCAN
sounds like the scanner/copier engine(same device, by the way) has gone way UnHappy. time for a service call or a recycling effort on that machine..it's a major component..and buried deep inside machine.
Feb 19, 2008 | HP PSC 1350v All-In-One InkJet Printer
Hp 1350 all-in-one
When power is applied to the all-in-one for the first time, the power light is solid and the check paper, check print cartridge, black copy, and color copy lights flash, the display will be blank, and the all-in-one will not respond. One or more of the following symptoms will also be observed: The all-in-one keeps turning off Cannot print, scan, or copy The print carriage will not move Windows plug and play (device detection) does not occur The all-in-one does not respond when buttons are pressed, including the power button. SOLUTION: This problem occurs for two reasons: the front panel cover was not installed or the ink cartridge access door was not closed before plugging in the all-in-one. The front panel overlay must be correctly installed before the power cord is plugged in. Follow the steps below to correct the problem: Disconnect the power cord. Lift the scanner lid and carefully line up and install the front panel overlay. Plug the power cord in. The print cartridge access door must be closed before the all-in-one is plugged in for the first time. The all-in-one cannot complete its first initialization until the door is closed. Follow the steps below to correct the problem: Disconnect the power cord. Locate and close the print cartridge access door. CAUSE: The all-in-one initializes when it is plugged in for the first time. While initializing, the all-in-one scans a bar code on the under side of the front panel cover requiring that the front panel cover be in place and that the scanner be operable. The scanner cannot operate when the cartridge access door is open On light (green) - On Check Paper light (amber) - Blink Simultaneously Check Print Cartridge light (amber) - Blink Simultaneously Black copy area backlight (green)- Blink Simultaneously Color copy area backlight (green) - Blink Simultaneously Issue Front panel overlay is not attached at all or not attached properly Solution Turn Off the all-in-one. Attach front panel overlay as instructed on Setup Poster. Turn On the all-in-one.
Sep 06, 2007 | HP PSC 1350 All-In-One Thermal Printer
Lexmark X1270 All-In-One InkJet Printer Logo
116 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
