Question about Philips GoGear SA178 MP3 Player
Cant get more than 50 songs on it
I cant get more than 50 songs on it i bought it used and im using windows vista windows media player.i erased everything that was on it but cant figure out how to get a bigger playlist downloaded on it.i got 44 songs and a buch of empty folders with the artisis names on them and when i tryed to download the songs again windows tells you there already on there
  • 8,596 Answers
First, check the Philips website re: the warning about using this device with vista and WMP-11.
Then,
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Posted on Feb 11, 2008
Sansa e250r works but will not format
The issue you have described with your portable device in most cases can be resolved by formatting your device. Please follow these steps even if you have already attempted them once before.
Please note that this will remove all music from your device.
Formatting the device in Windows Media Player
1. Open Windows Media Player with your MP3 player connected to the computer
2. At the top of windows Media Player select the Sync tab at the top
3. The MP3 player should be recognized on the right hand side and say "Your Player Name"
4. Above the player name is a button that says "Format Storage Media" click this button to erase all the data from the player
Nov 02, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa m230 MP3 Player
Use Windows Media Player to do the deletions.
Jul 03, 2008 | SanDisk Sansa m230 MP3 Player
I can't load no more than 60 songs
You have auto-sync enabled - disable it
Disable auto-sync in Windows Media Player - Microsoft's website explains it far better than I can
Open Windows Media Player WITH the mp3 player connected
Highlight Sync, click on the arrow to bring down drop-dow menu
Select Set Up Sync
Uncheck box that says "automatically sync files to device"
Jun 20, 2008 | SanDisk Sansa E280 MP3 Player
SANSA not turned on....???
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Apr 30, 2008 | SanDisk Sansa E280 MP3 Player
Sandisk keeps skipping/freezing songs!
or
-Tha Mp3 Doctor
Apr 13, 2008 | SanDisk Sansa E280 MP3 Player
Songs dnt show on my device.
Go ahead and do this, in case the DB is corrupted:
Mar 08, 2008 | SanDisk Sansa e250 MP3 Player
Mp3
1) Disconnect from computer, turn it off, hold in volume + button and reconnect it to your computer - continue holding volume + until the Found Hardware Wizard comes up.
2)
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your iLo player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "ILO 2GB" (wording may vary slightly), and then select "Format." - this should erase everything, and give you a fresh start.
Feb 17, 2008 | iLO (2 GB) MP3 Player
Cant load songs to my ilo player!!!!!!!!!!!!!!!
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Use Windows Media Player instead
Oct 20, 2007 | iLO (2 GB) MP3 Player
Uploading songs
This player is not compatible with iTunes
Ripped from CD - acquire license by going into songs' Properties and clicking on license or digital rights tab; or try and re-sync
There could be something else wrong with player for which the above methods fail. In this casE:
or
-Tha Mp3 Doctor
Aug 19, 2007 | SanDisk Sansa e260 MP3 Player
Wont play music
or
-Tha Mp3 Doctor
Aug 16, 2007 | SanDisk Sansa e260 MP3 Player
Philips GoGear SA178 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
