Question about Mitsubishi WD-62525 62" Rear Projection HDTV
CODE 3 4
I diasnoticate the tv WD-62527 code 3 4
    President:
  • 4,402 Answers
Double post
Posted on Feb 11, 2008
Mitsubishi wd 62527
hello there it could be a loose connector that u may have disturbed or broken look again inside if it worked before with
sound the chances are its ok
Jan 21, 2018 | Televison & Video
Cannot figure out how to connect my new sound bar to my older TV
If your TV has audio output connectors (RCA type), you can use them as a source of input to your soundbar. This should be apparent by reviewing the installation instructions that accompanied your soundbar.
Nov 30, 2013 | Mitsubishi WD-62527 62 in. LCD Projection...
My tv a mitsubishi d 62527 the green light kees blinking
Called the blinking green light of death---set should if power lost when put back blink for 70 seconds or so---digital unit booting up.
About the only simple cause is in the main power supply are four 1000 uf caps that puff up and fail--provide boot up voltage.
follower power cord to supply and look for bad caps (they will be easy to spot) and see attached photos of what to look for.
Nov 06, 2012 | Mitsubishi WD-62527 Compatible TV Lamp
Screen Removal - Mitsubishi WD-62527
SPEAKER GRILLE Removal
Pull the SPEAKER-GRILLE away from the cabinet to remove.
SCREEN-ASSY Removal
1) Remove 10 screws (a) from the upper cabinet rear cover (3 screws on each side and 4 screws across the
top).
2) Remove screws (b) along the bottom of the SCREEN-ASSY (8 screws on 52 inch models, and 12 screws
on 62 inch models),
3) Unplug the LL connector to the front CONTROL-PANEL.
4) Lift the SCREEN-ASSY up slightly and then pull away from the cabinet.
CABINET FRONT DISASSEMBLY
Aug 01, 2009 | Mitsubishi WD-65735 Television
Television
Press menu and the device buttons on the tv both in together and hold them in for 5 seconds and see if the led will blink a two digit error code, then let me know the blinks.
Jul 06, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Tv 62527 light goes off when after a few seconds when turned on
This is generally a Power Supply problem, usually the SMPS so it's replacement or repair.
Jul 15, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
78 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
