Question about Canon PIXMA MP160 All-In-One InkJet Printer
Mp 160 my canon wont wont print it takes the paper abput an inch but then it stops and the rolls keep runing but the paper stays in the same place
  • nauya8485 Feb 21, 2008
    while printing, paper go in but more than one paper. it make the printing result bad. sometimes it cannot print because it cannot shuck in paper then it make my printer jam. how to fix it?
    is it has to go to see professional fixer?
  • Anonymous Feb 23, 2008
    The paper goes in maybe an inch and then the ORANGE alarm button flashes and a E and a 3 flashes. Once the paper stops the machine keeps printing without taking the paper.
  • 25 Answers
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
550
Posted on Feb 27, 2009
    Scholar:
  • 29 Answers
Don't know why the the last posting had me as guest!!
Don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Someone replied to my problem, i tried it and it fixed 1st time. Also seems to of worked for others
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through! and hey presto it worked for me, everything printing fine now
Posted on Mar 05, 2008
Saya punya masalah print cannon pixma MP 287 kertas gak bisa masuk pada saat diprint, kalau bisa kertasnya tergulung
I have a problem cannon Pixma MP 287 print paper can not enter when printed , if the paper can be rolled up
Dec 20, 2012 | Canon LASER SHOT LBP-2900 Printer
How do I print color photos on glossy paper with Canon Pixma MP 6
printer supports it. just you have to goto printing preferences or printer properties and set rear tray to accept glossy paper. it will accept size of paper ur using. so give the actual size.
Apr 23, 2009 | Office Equipment & Supplies
Kyocera 2020d WONT PRINT Load Mp Tray
load a4 paper in bypass or the mp tray as it is also called
Jun 08, 2017 | Kyocera FS-2020D ECOSYS Monochrome Laser -...
Trey 1 is giving a message out of paper when they is paper inside
The message "No Paper" will appear on the LCD display if the Brother machine does not detect paper in the paper tray(Tray#1 or Tray#2) or MP(Multi-purpose) Tray.
Resetting the Brother machine may resolve this issue. To reset the machine, unplug the power cord from the AC power outlet for approximately 10 seconds and then plug it back in.
Note
For MFC users :
The Brother machine can be powered OFF for up to 4 days without losing faxes in memory.
If the message "No Paper" continues to appear on the display follow the instructions listed below:
When printing from Tray#1 or Tray#2 :
Pull the paper tray completely out of the machine. Go to STEP2.
When printing from MP Tray :
Go to STEP4.
Note Tray #2 is the optional LT-5300 paper tray.The MP Tray is just above the main paper tray and can be accessed by opening the MP Tray door. To open, pull on either the left or right side of the front door by the circular cut out.
2. While pressing the blue paper-guide release lever, slide the paper guides to fit the paper size. If the back of the paper tray doesn't move, the tray lock button may be in the lock position; slide the lock button to the unlock position and pull out the back of the paper tray again. With the paper removed, you will see the LTR (letter) marking on the plastic plate on the bottom of the paper tray to indicate where the moveable rear guide (with protruding arrow) should be moved to for letter size paper. There is also a marking for legal size paper. Make sure the guides are set at the correct mark. Reload the paper in the paper tray. Make sure the moveable rear guide does NOT push tightly against the paper. It should be adjusted to the LTR (letter) or LGL (legal) position, depending on your paper size. If the moveable rear guide is pushed too tightly against the rear edge of the paper, the paper will get stuck in the tray and a loud plastic snapping noise may be heard when feeding paper.
3. Move the tray lock button to the lock position (slide the button towards the paper).
4. If there is no paper in the tray, reload the paper.
The tray can hold up to 250 sheets of 20lb paper. Do not overfill the tray. There is a maximum paper mark located on the top of the right and left paper guide. It looks like a V cut out in the plastic.
Note
If you are using special paper and the machine has problems feeding it from the paper tray, try the paper again using the manual feed tray. Make sure you insert the paper far enough --about 1 inch- under the gray plastic bar in the MP Tray until it stops or it will not be fed and the machine will display the message "No Paper".
5. Verify the correct size and type paper is being used:
If you are printing from a PC and using the paper tray, make sure that MP Tray is NOT selected in the application's print properties for Paper Source.
If you are printing from a PC make sure that the MP Tray is selected in the application's print properties for Paper Source.
Note: Please be aware that the setting in the printer driver will take priority over the setting made on the control panel.
14. If you have set the Tray Use settings for a particular tray, the machine will feed paper only from that tray. If the selected tray is out of paper, a "No Paper" message will appear on the LCD. You need to reload paper in that tray.
To set the Tray Use setting, follow the steps below:
a. Press Menu.
b. Press the up or down arrow key to select General Setup.
c. Press OK.
d. Press the up or down arrow key to select Tray Use.
e. Press OK.
f. Press the up or down arrow key to select the mode you want to use.
You can select Copy, Print or Fax(MFC users only).
g. Press OK.
h. Press the up or down arrow key to select the tray.
You can select Tray#1 Only, Tray#2 Only or MP Tray Only.
i. Press OK.
15. For MFC users :
To test, print the Help List.
. Press Menu.
a. Press the up or down arrow key to select Print Reports, and press OK.
b. Press the up or down arrow key to select Help List, and press OK.
c.Press Start.
For DCP users :
To test, print the User Settings.
d. Press Menu.
e. Press the up or down arrow key to select General Setup, and press OK.
f. Press the up or down arrow key to select User Settings, and press OK.
g. Press Start.
Note
If the problem still continues after following the above instructions,
I recommend you clean the Separation Roller, Pickup Roller and Separation pad following the instructions of the FAQ: My Brother machine mis-feeds paper.
Apr 21, 2012 | Brother MFC-8460N All-In-One Printer
How topaper load cannon mp 160 pixma
Loading Paper into your Canon MP 160 Pixma.
A) Loading Paper :
Follow this procedure:
1) Open the Paper Support, then pull out the Paper Support Extension.
2) Place a stack of paper (print side up) in the Auto Sheet Feeder, pinch the Paper Guide and adjust it to the left side of the stack.
* Set the Paper ThicknessLever to the correct position for the paper.
Note : Set the Lever to the left for most paper. When the Lever is set to the right, the confirmation message appears before the machine starts printing.
Important : Make sure the stack does not exceed the Load Limit Mark.
B) Loading Envelopes
Follow the following steps:
2) Prepare the envelopes for loading.
Important : * Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
* Remove any curling by holding the edges diagonally and bending them gently.
* If the edges of the envelopes are inflated or curled, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
* Ensure that no curl or puff exceeds 1/8 in. (3mm).
3) Place the stack of envelopes (print side up) in the Auto Sheet Feeder, pinch the Paper Guide and adjust it to the left side of the stack.
* Load the envelopes in the Auto Sheet Feeder with the short side down.
* Set the Paper Thickness Lever to the right.
Important : Make sure that the stack does not exceed the Load Limit Mark.
Hope this helps. PLease rate my response.
Thanks
Have a good day.
Dec 01, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Wont print on card stock, legal paper- keeps jamming
Menu> scroll to Paperhandling> MP Tray type>>(plain) try changing this to cardstock  <enter>
instead of MP Tray type do the same for Cassette if you desire....
Best, danakadan
Oct 11, 2008 | Kyocera FS-1030D Laser Printer
Canon MP 160
I had the same problem with my mp 160, I tried to print but the printer only took the left side of the page and the paper got jammed. I pulled it out but I think a piece was left inside the printer. Error message was blinking, but somehow I got the printer moving again. I tried to print again, but this time the printer would take 1/10 of the whole page and stop, even though rollers were moving. My solution for this was to take a piece of thin cardbore(I used a magazine cover), cut it in a shape of A4, put it in printer, printed it and when the rollers start moving I forcebly pushed the cardboard through. Now it seems to work fine.
Feb 10, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
76 people viewed this question
old marine
old marine
