Question about Kenmore 22422 Top Load Washer
Washer machine kennmore washer. the hot water is leaking back into the washer after it is cut off and is finishing washing. water is coming from the normal location for the wter to fill the machine
  • catfishgirl Feb 12, 2008
    i have no problem with the cold water. just the hot water drips back into the tub after it is cut off. also water is leaking under the washer into the floor.
  • 589 Answers
Sounds like the hot water solenoid is stuck.
Posted on Feb 11, 2008
  • brian c
    brian c Feb 11, 2008
    Sorry I accidentally posted that without finishing my answer.
    Try this. Shut off the hot water supply to the washer. Unplug the washer and listen for a "click" noise. Plug it back in again. If you hear the "click" again, it could be either the water level sensor, or the timer.
    If you don't hear the "click", then the solenoid is probably hanging / stuck.
    Does it also do it if you choose "cold / cold" on the temperature selector?
Won't finish cycle and is washing cold
You need Washing Machine Engineer , try Yellow pages,
Mar 16, 2015 | Washing Machines
While using washing machine water leaks out
sounds like the lower pipe or pump pipe is leaking or come away. you need to pull the washer out and place it on its side (left as you look at front) and check the pipes on the bottom, they have pincer clamps on the pipes, if the pipes are cracked or damaged replace them but usually its just they have come loose from drum movement. and just need fitting back on. also the drain pipe needs to be at least 3 inches from the top level with the water in pipes height of the washer so the water does not just come out.
Jan 13, 2018 | Washing Machines
Water underneath unit
Check your water hoses may be leaking behind the machine or at the tap.If the hose is leaking turn all taps off. the alloy crimp needs to be cut off & put a hose clamp on the hose.turn all taps off when machine has finished the wash.
Feb 01, 2013 | Fisher and Paykel GWL11 Top Load Washer
Water underneath unit?
Whirlpool washer water leaking back into washer
bad water valve or vacuum lock in drain line causing water to come back into washer when cycle is finished
Dec 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washing machine is a Roper top load washer. The problem I am having is that the pump from the cold water drain from under the washing machine. Do I need another pump? The hot water will work. I use the...
This model is a direct drive with only one pump, the drain pump. If the drain pump leaks, which is a common problem on these models, it will leak no matter what temperature wash is selected! If you a have a leak on cold, it will probably also leak on warm wash. Your problem is your solenoid operated fill valve on the cold side. Only one fill hose comes off of this combination fill valve to your fill plenum at the top back of your tub. So if it leaks on the cold, but not hot, check for a crack in the plastic housing of the valve on the cold half. The valve is located on the inside back of the machine on top right when looking at the front of the machine. They are fairly inexpensive and easy to replace.
Hope this helps
kcomp1863
Jan 18, 2011 | Roper RAS6233KQ Top Load Washer
When you open the door there is an odor that come from inside the wash tub
this is due to the build up of scum in the washer pipes the best thing to clean it out with is bleach ,,,do a cold/hot water wash with nothing in the washer only a strong mix of bleach, when the wash has finished do another cold/hot wash again this time with only water in the washer to flush out any bleach left in the washer then leave the door open a little when you have finished your washing from then on,this should kill of any more nasty smells
Nov 16, 2009 | Frigidaire ATF6000ES Front Load Washer
Water leaking from hot water connection
Try sliding the panel backwards it should slide off.. Hopefully this should do the trick
Apr 26, 2009 | LG WM-2277HW Front Load Washer
Washer is leaking while it is just setting still.
The first thing that I would check, is the hot & cold water hoses, that connect in the back of the washer, to see if they are tight. If they are tight and still leaking from there, then the rubber washer, inside the brass fitting part needs replaced. If that doesn't help, then disconnect the power, and water hoses, then turn the washer over and check the water hose underneath, to see if its leaking. One of these hoses has to be the problem.
Jan 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Leak into washer
The solenoid for the water intake is faulty. It may just have some crud stuck in it. You have two, one for hot and one for cold connected directly to the hoses on the back. You can shut off the cold water supply and see if it still leaks - if it does the hot water solenoid is faulty - if the leak stops then the cold water solenoid is bad.
Nov 22, 2008 | GE WBSR3140DW Top Load Washer
Kenmore 22422 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
