Question about Amana AOCS3040 Electric Single Oven
Amana Convection Wall Oven Model AOCS3040 Does Not Heat in any Mode
Everything on the electronic control panel seems to be working. No error messages. I find it hard to believe that all of the heating elements would stop working at the same time. No setting heats (bake, broil or convection). Does anyone know if the control panel and the heating elements are powered by different electrical sources? Is it possible for the control panel to get power and not the heating elements?
  • Anonymous Mar 21, 2014
    Elements and control panel have been replaced. Still does not work. Electric connections are fine
    President:
  • Amana Master
  • 2,651 Answers
Sure its possible, sounds like you've blown an over limit thermostat behind stove, gets too hot and for safety reasons cuts off unit untill replaced
Posted on Feb 23, 2008
Amana Convection Oven - Not heating in normal bake mode, but works otherwise
I will say that is the control board that is not working properly. Have you try to unplugged for phew minutes?, this will reset the current settings. If not, I will star replacing the control board. Good Luck!.
Jan 13, 2014 | Amana Ovens
We just purchased a home that was built in 2003. It has a stainless steel double oven. The doors don't close tight. Is there a way to adjust them so they do? Thanks
I have the same problem on my AOCS3040 oven....door will not shut tightly so it loses heat and is about 25 degrees off plus the escaped heat makes the control panel get very hot during cooking.
Oct 21, 2010 | Amana AOCS3040 Electric Single Oven
On a Amana EvenAir convection Plus oven the convection blower comes on during the regular bake cycle.
There is a blower on the top of the oven, which turns on when the oven is hot enough. If the warm/hot air is coming out from top vent corners - this is the blower working. Even if you turn the oven off at that moment, the blower will still work until the oven cools down. This is normal.
Oct 12, 2009 | Amana AOCS3040 Electric Single Oven
When burners are turned on Code F1 shows up and starts beeping
Hello, an F1 error code for an Amana refers to a failed watchdog circuit or ERC (Electronic range control) and need to be replaced. This can be located inside the control panel and is normally accessed from the back of the range. If you have any other questions please feel free to comment again. Mike
Oct 01, 2009 | Amana AOCS3040 Electric Single Oven
Amana Electric Oven Issue
My oven never reaches the proper temperature sitting for baking. Controls for the oven only is push buttons. How can I adjust this. This has been going on since I have bought the Amana
Oct 27, 2008 | Amana AOCS3040 Electric Single Oven
F1 fault code
EOC is a Electronic Oven Control
tech sheet under the control panel has a schematics in it..
Jun 04, 2008 | Amana AOCS3040 Electric Single Oven
F1 error on SS Amana Convection wall oven
F1=Electronic range control failure
It is telling you may have a fauilty control...need to replace control or EOC
Jun 03, 2008 | Amana AOCS3040 Electric Single Oven
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Up/Down buttons don't work
This would usually need a keypad replacement. It may come as a whole console or as part of range control board. From what I see in pictures, it appears to be an insert panel that goes into console assembly. Looks to run about 200 dollars. You will need complete model and serial numbers off oven to order correct part. These parts are usually not returnable.
Nov 22, 2007 | Amana AOCS3040 Electric Single Oven
Amana AOCS3040 Convection Oven
If I were you I would contact Amana and speak to their service dept. and tell them your problem as maybe theres a service bulliten out or a common repair and if that they would recommend someone who can fix this model.. I tryed to look up this model and I couldnt find it. If that dosent help Go to http://repairclinic.com and ask the repair guru there for assistance.. Good luck
Apr 16, 2006 | Amana AOCS3040 Electric Single Oven
Amana AOCS3040 Electric Single Oven Logo
437 people viewed this question
Top Amana Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
john mabry
Are you an Amana Oven Expert? Answer questions, earn points and help others
