Question about Disney Mix Max Digital Media Player
Not starting up
Everytime I turn on the disney mix max player it shows up saying starting up but, even after 2 days it still will not start. I also can not turn it off once I push the power button. I have already pushed the reset button it still does not work. I have also plugged it into my computer but the same window is there. What can I do so it will work again?
  • samyvale Feb 24, 2008
    It was working good, but it turn off suddenly it's gone ,push all bottons but nothing please notify me if there's any solution
    Scholar:
  • 93 Answers
Try the recovery tool from their firmware update page. Go here http://digiblue.com/customer-service/faqs/disney/mixmax/17.html and download the instruction document and try that. If that doesn't work you may need to get a replacement.
Posted on Mar 05, 2008
How do i download music on my mp3 player?
How to Put Songs on Disney Mix Max
The Disney Mix Max portable media player is capable of playing audio files in the MP3 format. It can also play videos formatted as WMV and display photos formatted as JPEG. You can convert audio files into MP3 using the Disney Mix Max software -- Mix It Plug-in. The plug-in works with Windows Media Player 10. This software CD came with the player and is not available online. To download music to the device, you can use Windows Media Player 10 or Windows.
Things You'll Need:
* USB cable
* Mix It Plug-In installation CD
Instructions
Convert Non-MP3 Files
Install Mix It Plug-In. Insert the Mix It Plug-in installation CD into the computer's optical drive. Click "Install Mix It Plug-In" when prompted. If no screen opens, double-click on the "My Computer" icon. Double-click on the installation CD icon. Then double-click on the setup or installation file; this file is often formatted as EXE. Select to have the program saved to your desktop. Then double-click on the desktop icon -- "disneymixitplugin" to open the setup wizard. Click "Next" in the setup screen. Follow any additional setup prompts.
Open Windows Media Player 10 and create a playlist. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Open Mix It Plug-In. Select "Yes" when asked to save analysis information for your music files. The software will analyze each track's compatibility with the Disney Mix Max player.
Press "Go!" to start the conversion process. Once the process is complete, an inactive "Go!" will be displayed. All music that has been converted is still listed in your Windows Media Player 10 playlist. You are now ready to download music to the player using Windows Media Player.
Open Windows Media Player 10 on your computer.
Remove the USB jack cover located on the bottom of the Disney Mix Max. Insert the compatible end of the USB cable into the USB port on the Disney Mix Max. Insert the other end of the cable into the computer's USB port.
Click "Library" and click a playlist name. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Select the "Sync List" tab and choose "Sync List" from the menu.
Verify the items to be synced to the Mix Max, or right-click on a song title and select "Delete" to remove it. Click "Start Sync" to download music to the Mix Max.
Windows
Insert the USB cable to the Disney Mix Max USB jack. Connect the player to the computer with the USB cable.
Click on the desktop "Start" menu and choose "My Computer."
Double-click on the "Removable Disk" that corresponds with your connected device.
Drag songs saved on your computer with your mouse into the Removable Disk folder.
Tips & Warnings
If you converted files using the Mix It Plug-In, you will need to use Windows Media Player 10 to sync them to the player.
Mar 11, 2011 | Disney Mix Max Digital Media Player
Disney Mix max
Yep you sure can. Depending on the version of Windows Media Player that you have it's pretty easy to rip the CD and then sync it to your Mix Max. I recommend using Windows Media Player 11 as it's the easiest so I'd recommend you install that first. Then insert your CD into your computer, open Windows Media Player and click on the "Rip" button at the top. Select the tracks on the CD that you want to add to the player and click "Start Rip." Once the tracks have completed ripping click on the "Sync" button at the top right of Windows Media Player. Then just drag the tracks from the library on the left to the sync list on the right and click "Start Sync."
Aug 30, 2008 | Disney Mix Max Digital Media Player
Mix Max
Try pressing the reset button on the bottom of the player with a tack or paper clip. If you have a SD card try removing it and then reset the player.
May 31, 2008 | Disney Mix Max Digital Media Player
Help
Try going to the following link and follow the directions to flash the firmware in your player. If that doesn't work I'd suggest you call their support line to see about setting up a warranty replacement since they have a 1 year warranty on all of their products. Keep in mind you'll need to have your receipt for verification of the original purchase date and warranty period.
http://digiblue.com/customer-service/faqs/disney/mixmax/MixMaxFirmwareUpgrade.doc
May 13, 2008 | Disney Mix Max Digital Media Player
Shuffle mix max
That's not actually how you delete songs from the player. When you connect it to your computer you will see a new removable disk called Mix Max in your My Computer icon or in Computer if you have Vista. Open up that Mix Max icon and then you can highlight and delete only the songs you don't want or all of them.
Mar 28, 2008 | Disney Mix Max Digital Media Player
Disney Mix Match
You may need to update the firmware on the player in order to be able to play the Max Clips.
http://digiblue.com/customer-service/faqs/disney/mixmax/14.html
As far as putting songs on the player goes check out the FAQ's page on the manufacturers website. The specific FAQ for adding songs is here...
http://digiblue.com/customer-service/faqs/disney/mixmax/02.html
Mar 17, 2008 | Disney Mix Max Digital Media Player
Downloading Music onto Mix Max
If the music is already on your computer, it must be in mp3 format, do the following;
1) Open Windows media Player,
2) Connect your Disney Mix Max
3)Click "sync"
4) "Drag" song to where it says "Drag items here",
5) Click "Start Sync"
Jan 10, 2008 | Disney Mix Max Digital Media Player
How can i delete space
hmmm, Try connecting to your computer,or open "My Computer"
and see if it recognizes the Disney Mix Max, if it does,
Double click the Disney Icon, and right click on something you want to delete, and click delete, or press "delete" on your keyboard. Be Careful not to delete things you want to keep though....
Jan 09, 2008 | Disney Mix Max Digital Media Player
Driving me nuts
It has to make a library file of the contents on the player. It uses that file to display the titles and artists when scrolling through the menus and what not. You'll have to format your player in order to clear it up. This will erase everything and then you can put your songs and stuff back on it. Just make sure that when you do you leave at least 4 megs of space for it to make that library file. Here's a link to the manufacturers instructions on how to format the player.
http://digiblue.com/customer-service/faqs/disney/mixmax/06.html
Dec 26, 2007 | Disney Mix Max Digital Media Player
Disney Mix Max Digital Media Player Logo
61 people viewed this question
Top Disney Audio Players & Recorders Experts
Rick
Are you a Disney Audio Player and Recorder Expert? Answer questions, earn points and help others
