Question about Trekstor Datastation maxi t.u SATA 500 GB SATA Hard Drive
Computer does not recognise Hard Drive
When we connect this harddrive to computer, system recognise this as removal disk media and asking to insert disk?
We have backed up all our laptop data on this and reformatted laptop now I am not able to raed my data from this hard drive
  • 5 more comments
  • newcity Feb 14, 2008
    Same problem with a brand new HD
    it's probably a bad driver but i can't find one on the trekstor website
  • riojanita Mar 18, 2008
    My computer recognises that a USB Mass Storage Device has been attached to the computer but it is not recognised as an external hard drive. What can I do to get access to the external hard drive? I don't want to lose the data.
    Thanks a million.
    Diana
  • kriwsa Apr 09, 2008
    i can acces my data anymore, it stopped working one day and now it wont recognize my harddrive.
  • davelikeguy Apr 13, 2008
    new trekstor 1gb. Vista will find it when i reboot, but will not install it, It did work at one point but now it is like it is not there.
  • manners2020 Jul 21, 2008
    my hard drive is no longer recognised and the blue light now fashes instead of being solid
  • Anonymous Dec 05, 2008
    The pc doesn`t reconise my box anymore...
  • Anonymous May 24, 2009
    Sunplus USB2SATA USB Device
    TrekStore USB HARD DISC 500 GB
    TrekStore ( ModelnO.: DSMMU-S-SU-a )
    Since two days says the PC System that the extern hard disc is a removable hard drive and if I am clicking on the icon to open the data , it ask me , that I should insert a disc into the removable hard drive .
    Can you help me ??
    Your Oliver Frank
  • 3 Answers
Hey guys. I have an answer on how to fix the Trekstor Datastation "Removable Disk" problem.
I also own a Trekstor Datastation 500GB and had the same problem even though it worked for several months then all of a sudden when I tried to hook it up to another computer, it stopped working. It would recognize the USB connection but you could not read the drive as it would say "Removable Disk".
In "Device Manager" it recognizes the drive as Sundata USB2SATA. But what it really should be is "WDC WD50 00AAVS-32ZTB0 USB Device" or something similar to that. For those that are wondering, yes, the hard drive is a Western Digital Hard Drive. Western Digital Caviar to be exact.
Solution: You need to open the cover to the hard drive and reconnect the hard drive to the connector on the board. It's that simple!
It is very loose and this model is not well designed so it can easily come off if you accidentally knock over your hard drive or move it to another location. The hard drive is held in place by screws on a holder where there is room for the screws to slide if the screws are not tight enough.
You'll need a T10 screwdriver bit to remove the cover and a Phillips screwdriver to adjust the hard drive.
NOTE: Doing this will probably voids your warranty but trust me, it works and it's really easy and quick to do. Took me 15 minutes.
Posted on Jul 01, 2008
I have the same problem it tells me that i have to insert disc???? anyone find a solution.
Posted on Jun 03, 2008
Saame Problem. It comes up as a removable storage device, with 0 gigs memory... and when i click on it it says that i need to insert something into that drive... i have noo idea what to do, but i odn't want to lose my stuff :'[
Posted on Feb 29, 2008
Hard Disk Problem plese help....
Media test failure usuallymeans the hard disk has failed or the hard disk needs re-seating or the diskcontroller is faulty. First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty. Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an USB mass storage device and you cannot open the various folders and fileson this drive, then this confirms the hard drive is faulty. Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Sep 05, 2011 | Computers & Internet
My hp nx9030 keep rebooting itself with the message, PXE E61 media test failure check cable, PXE -MOF EXITING PXE ROM.what can i do
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty. Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an USB mass storage device and you cannot open the various folders and fileson this drive, then this confirms the hard drive is faulty. Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Aug 26, 2011 | HP Compaq nx9030 Notebook
Hi im getting the pxe-e61 media test failure check cable for a toshiba a350 i have gone into the bios and disabled the lan and put my hdd is slot 1 followed my my cdrom i bought a new harddrive but...
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty. Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty.Thenthe hard drive needs to be replaced in the computer/laptop, Windows installedand the computer or laptop's device drivers plus your programs etc. to get afunctioning computer/laptop again.
Aug 03, 2011 | Toshiba Satellite A35-S159 Notebook
How do I delete all the info backed up on my irocks external hard drive?
Usually hard drive disks are erasable so long as was an an empty space. However, the type of setting chosen during data encription causes the situation of erasability. For example, using an external harddrive disk as back up media storage media has specific requirements. The computer provides an integral means of least being compromised where data permanent encription may have been the options available during backup copying. The compoter provides the procedures of recording data into any connected external devices. Once the external device is reconnected to the computer, the options of requesting the user to either erase what has already been copied becomes one of the several displayable promps. Also, backup disks usually on connection to the computer assumes a necessity to restore to functioning mode. However, a least malfunctioning computer would simply display prompts asking the computer user to perform the most recent backup, or disregard because of least disfunction recognised from the system. Attempting is erase what has already been recorded becomes appropiate whenever the computer recognises any curroption of the files. A prompt is display asking to fix errors soon after connection. The computer user simple chooses to restore to default functionality the external hardrive. Amongs the options usually provided of the program prompt are format, delete, restore, or backup computer files once connection is recognised. keep in mind that, an external hard disk may be default rrecordable proving no options of erasing. Refer to the hard disk drive user guide as reference to achieve the process. Also, the user guide would have specified if the device is capable of alternations or not.
Jan 14, 2011 | i-rocks External Hard Drive Enclosure -...
Harddrive does not start up...computer recognises
Try Control Panel, Administrative Tools, Computer Management, Storage, Disk Management.
Check there to see if the drive is listed, "online" and has a "Healthy" Partition.
Nov 17, 2009 | Western Digital Passport WDXML800UE...
Verbatim 250GB portable harddrive is not working on my computer
look at what pops up in your my computer window when you connect it to your computer
May 12, 2009 | Computers & Internet
I cannot see my free agent external drive
u can see the news that the st drive has many bugs,and which cannot be detected by the pc is the most popular one,so u can update the firmware from seagate official and if still cannot repair,u can go back to me,honglake@gmail.com
Mar 15, 2009 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
Insert a new disk
Try connecting it on a different system, if it is not getting recognised you will need to format the drive.
Jan 27, 2009 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
Phillips mp3 player
Connect the player to the power adaptor and connect to the PC.
On the player press and hold "Power" & "Vol +", this should reset the player.
Wait for PC to recognise player.
If this doesn't work try the following:
Connect the HDD6330 to the mains adaptor and the PC.
Before the computer has a chance to recognise the player, press "Power" and "Vol +" to reset the player.
As soon as the player resets (screen goes blank) press and hold "Vol -" until the PC recognises the player as a removable drive.
Try to access the player through "My Computer" as you would the main hard disk.
If the computer recognises the player, then it can be restored by copying the system files directly on to the player.
Feb 14, 2008 | Philips GoGear HDD6330 MP3 Player
System not detecting hard disk
Check the position of the master/slave jumper on the drive.
Oct 06, 2007 | Excelstor Technology J880 Hard Drive
Trekstor Datastation maxi t.u SATA 500 GB SATA Hard Drive Logo
857 people viewed this question
Top Trekstor Computers & Internet Experts
Mohamed Ismail
Mohamed Ismail
Alun Cox
giarcnameloc
Level 1 Expert
Are you a Trekstor Computer and Internet Expert? Answer questions, earn points and help others
